Question about Sanyo DS25390 TV
Buzzing sound from Relay
The relay just after the input transformer is buzzing loadly (oscillating) when the power button is pushed. The TV video and audio is fine. The bussing is not coming throught the speakers. The 6W resistor between the transformer and relay is also getting very hot with just the set plugged in but not turned on. Does anyone have a solution? Thanks....
  • 1 more comment
  • Anonymous Mar 22, 2008
    fixed mine too. thanks
  • Anonymous Mar 29, 2008
    I spent 12 bucks for a 470uf 250 volt cap put it in and the relay still clatters. ?????????????/
  • Sean Nelson
    Sean Nelson Dec 27, 2012
    The original voltage rating of the cap was 25 volts. Purchasing a 250 volt rated cap is overkill. If the relay still clatters, did you install it correctly and observe polarity?
  • 373 Answers
The problem is a capacitor at location C622 470mfd and must be changed. Use equal or better voltage rating
Posted on Mar 16, 2008
Why does my 42 inch lg tv make a buzzing sound that flickers high and low and even when the power is off
Sounds like a relay or transformer that is on its way out. I would suggest taking the set to a TV service Agent and getting it sorted before it dies altogether.
Apr 06, 2016 | LG Televison & Video
Samsung hlp6163w dlp there is a buzzing sometimes after the tv is on. When you shut the tv off the picture goes out but the buzzing continues for a few seconds more then shuts off ?
Fault with its main board itself. After a duration of proper working, the horizontal oscillation shuts off, while the main power supply voltage is there, for some time, [that is why you hear the buzzing sound; generated at its SMPS transformer]. A loose solder terminal at tthe main board can cause this. Even though, there might be some other reason too. The troubleshoot to this kind of fault is, somewhat skilled one. It will take some time to reach the exact fault point; even for an experienced service technician. It will be best to seek assistance from any experienced service technician. Electro help
Nov 03, 2014 | Televison & Video
Westinghouse tv power box making buzzing sound
Hi I'm Peter, There is a bad connection and most likely the buzzing sound is a relay going bad internally.
Apr 19, 2014 | Westinghouse Televison & Video
I have a goodman gup0753a furnace that is making a loud buzzing sound when it kicks on. I'm pretty sure it is the relay that is next to the transformer. Can I replace just the relay or should I replace...
Is the buzzing happening during the COOLING mode? If so that realy is turning on the fan blower.
You should be able to replace the relay itself. They are generally on a socket and there is realy nothing else mechanical in the box except for the wiring of the unit.
try www.graingers.com
Aug 01, 2011 | Goodman Heating & Cooling
WON'T START,BUZZ SOUND WHEN I PUSH THE START BUTTON
Sounds like a bad battery or a bad starter relay. Take the battery out and take it to an automotive parts house. Ask them to load test the battery for you.
If the battery test good, reinstall it in the bike making sure your connections are good. Press the start switch and listen for the buzz. Look for the starter relay. It's a one inch plastic cube. When you find it, press the start button while holding the relay. Is this what is making the noise?
If all you feel out of the starter relay is a simply click, and the buzzing is coming from the starter, you're solenoid may need new contacts installed in it or your solenoid might be bad.
Good Luck
Steve
Aug 22, 2010 | 2004 Harley Davidson FXD - FXDI Dyna Super...
AC unit with ''test'' plug; test shows ''green'', but AC doesn't work
Hi, and no this buzzing is not normal. If the test button does not trip, its not to major. It sounds as though you have a relay, fan, compressor, or some other relay that has worn contacts that buzz when power is put to it. If the unit operates and its not to the point it is driving you insane, you can take it apart to locate which relay is the noise one and replace it if you have the skills to tackle it. If it fails completely, not knowing the sequence of operation unless you can read a ladder schematic, you will have problems locating the one that was buzzing. I would remove the front cover if its a wall or window unit to find the control section and locate this buzzing relay to replace it.
Best of Luck to you,
Shastalaker7
Jun 05, 2010 | Heating & Cooling
Sanyo tv ds25390 buzzing sound
I had the same problem with the same model.
The solution was to replace a capacitor, C622, which is located near
a small blue rectangular plastic component.
This component is a relay that is controlled by C622. I paid $2.39 for
the part, $8.99 for S&H for a total of $11.38. This fixed my problem!
May 26, 2008 | Sanyo DS25390 TV
Buzzzzzzz
Hello to all you buzzers, I have the answer to your problem. First this is what's happening. The buzzing is coming from the power relay. It vibrates at 60hz because the power supply filter capacitor is not doing its job hence you have a rough d.c. pulse going to the relay.To solve the problem remove back of t.v. slide circuit board out (you will have to disconnect white wire from degauss coil,located on left front) look for a blue box approximately 3/4"x1 1/2" this will be the power relay. Now look for capacitor location #c622 near the relay. This capacitor should be 470uf 25v. Remove and replace with 470uf 35v capacitor, connect white degauss wire temperarily put back on and give it a spin. Hope this solves all the buzzin,robert
Jul 12, 2007 | Sanyo DS24425 24" TV
Televison & Video Logo
159 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
