Question about Whirlpool WFW9400S
Washing Machine Stops shortly after turned ON
The screen shows F20. Followed all instructions according to the Manual but the problems persists. What can I do next?
Thank You
Please more about F 20 error keep coming up , i dont know what to do
Posted on Dec 19, 2008
  • s_smid Dec 19, 2008
    where can I get a extra copy of owners manual for WFW94000SU00 for Whirpool Duet , please I need help What is error F 20 i cannot wash my cloths , every time i start to wash this error keeps on showing
    Genius:
  • 3,587 Answers
Hmmm...not too cool...how long this been happening?
Posted on Mar 10, 2008
  • Patrick Michaels
    Patrick Michaels Mar 10, 2008
    Seconds later, the washer stopped displaying a code F20, which means insufficient water.
  • Patrick Michaels
    check to see that your load and water levels are good, and that there are ** blockages in your lines.
What can I do to reset may washing machine showing an error word of f20
F20 is a water inlet problem not sufficient water supply. Select power/cancel twice to cancel cycle unplug washer or disconnect power
Check both hot and cold are open completely
All screens a
Jul 14, 2015 | Maytag Washing Machines
My washer stops &and F-20 appears on viewer. Whats wrong with my washer
water problem check screens in hoses and valves !! rrors F1, F11 and F20
  • Error F1 indicates a communication error between the computer and the washer. Unplug the washer for a minute and plug it back in, as this may correct the problem. Error F11 indicates a motor control error. It can be caused by improper voltage. Unplug the washer and check the connections. This may fix the problem. Error F20 indicates lack of water entering the machine. If there is no water in the washer, check that the water valves are turned on. If there is water in the washer, press "Stop" twice to drain the washer. Unplug the machine and check the hose connections.
Read more : http://www.ehow.com/info_12006668_error-messages-kenmore-he2-plus.html
Feb 21, 2015 | Kenmore HE2 Plus Front Load Washer
F20 error
If you remove the bottom panel, there is a drain plug and that would allow it to be opened. There is lots of water there though
Jan 05, 2014 | Whirlpool duet Washing Machines
I am having trouble with my washer. It is showing the F28 error code and then when I get that fixed, it shows the F20 error code. Can you please tell me what to do to get it running again. Thanks
F20 I believe is low water flow. On the intake fitting on the back of the machine where the hot and cold hose hook up there is a fine screen inside the fitting on the machine. My cold water screen was clogged from stuff in old pipes. Cleaned it and no more e F20
Feb 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Showing code F 20
f20 code means no water is entering the machine. make sure your water hoses are connected properly and that the water is turned on. could also be a problem with your pressure switch.
Feb 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Shows f20 and stop working
F20 No water detected entering machine. Tech sheet is in the bottom. Remove panel. Duet Service Manual34409e2.jpg
Aug 30, 2010 | Kenmore HE2 Plus Front Load Washer
Code F20 is appearing on me washing machine
http://www.fixya.com/support/r3608632-f20_error_code
May 27, 2009 | Kenmore HE2 Plus Front Load Washer
F20 Error code
be sure to ck fill hoses make sure both are turned on all the way ..remove hose at washer end ckd screen inside inlet for sand/rust/gunk pull screen out to clean and be sure to reinstall it or you're asking for trouble down the road..also ck faucet end just in case someone installed one there 2..by the way just having cold water only on will cause same problem
Aug 26, 2008 | Kenmore 46462 Front Load Washer
HE3t f20 error
washing machinge will not start when start buttin is depressed (for several seconds)
May 05, 2007 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Whirlpool WFW9400S Logo
Dan Webster
Dan Webster
Sal De
