Question about GE GSH25JSTSS Stainless Steel Side by Side Refrigerator
GE Ref #ESS25LSRCE SS
Help...My fridge (GE ESS25LSRCE SS) works good....but every now and then the LED display (temp control and water/ice) will go out for 2-3 days. It still makes ice but will not dispence anything (ice or water).....Any ideas? Thanks, Yomer@aol.com
  • 770 Answers
Are you sure it is not a GSS or a PSS model i have the manual on that post your email and i will send it to you
Posted on Mar 15, 2008
  • Leo Acosta
    Leo Acosta Apr 08, 2014
    yes it is a pss
My "Adora" DSS25KSRA SS intermittently
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Sep 22, 2011 | GE Adora DSS25KSTSS Stainless Steel Side...
It is a GE GSS25WGMC model. The green LED on the icemaker is on (not Blinking) When you call for ice, you hear the motor trying to turn, but the 2 prong lever that should turn the spiral in the ice...
NOTE: This
Leo Ponder
imufo2
Sep 18, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
GE profile performance fridge, model TPS24BPCE BS..... water dispenser not working. Ice ok. Water coming into it from main line, but doesn't appear to be getting into filter (replaced filter). Any...
NOTE: This
Leo Ponder
imufo2
Sep 15, 2011 | GE Profile PSF26NGW Side by Side...
Ice maker not making ice. ( GE Adora mod DSS25KSRE SS .)No water in ice mole.
NOTE: This
Leo Ponder
imufo2
Sep 12, 2011 | Refrigerators
Hello, I have a GE Monogram refrigerator (model ZFSB26DNA SS), which is about 8 years old. Recently the Ice/water dispenser on the door stopped working. I already replaced the front panel (Dispenser module...
NOTE: This
First I would check the fan in the freezer. Listen to see if it is running
Leo Ponder
imufo2
Sep 10, 2011 | GE Monogram ZISS480DRSS Stainless Steel
My ice maker is not working. The Green light is on and the water dispenser is working. Is there a way to trouble shoot it. I recently moved and not sure if I did something to it. GE Model GSS25TSRE SS
NOTE: This
http://www.applianceaid.com/procedures.html
I'm
Leo Ponder
imufo2
Aug 24, 2011 | GE GSS25SGSSS Stainless Steel Side by Side...
Model zfsb27d ss .. has no water toice tray or drinking water dispenser. No water flowing thru valves in back of fridge, can can not hear relay engagings in back of fridage on water valves
NOTE: This
If its leaking same part needs replaced.The water valve at the bottom rear of fridge
.I'm including my article on Refrigerator Repair for your help and convenience.;
Leo Ponder
imufo2
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 01, 2011 | GE Monogram Side by Side Refrigerator
Can't control the Temp. too cold/Ice-Machine over flow
sounds like you have a sensor problem or a open damper ,staying open,so it keeps freezing in the frig...call if need more input...michael..doctor airr appl.repair..843-384-8474...
Apr 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE French Door Control Panel LEDs Off if Fan is on.
Solved my problem. Replaced the motherboard. P/N WR55X10552. Purchased on Ebay, $70.00
Oct 21, 2007 | GE Refrigerators
GE GSH25JSTSS Stainless Steel Side by Side Refrigerator Logo
419 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
