Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
LG Tromm Water filling
I have a new LG Tromm Steam washer and when I turn it on everything starts out OK but when it starts to fill with water it has several rapid on and offs that shut off so fast that my plumbing in my house sounds like the pipe are banging together very loud, I am a bit worried.
  • 2 more comments
  • rt031108 May 06, 2008
    same problem live in a condo, and boy sounds almost like a gunshot going off....worried about leaks...
  • jrgottdank Jul 06, 2008
    Pipes bang on initial filling of water to washer.
  • nikibabs Dec 25, 2008
    I just bought htis same washer and same thing. When I start the wash cycle,the banging fro the hot watr pipes is terribly loud. Just to make sure I used cold water only and no banging. I'm afraid something will break.
  • Anonymous Mar 17, 2009
    My LG washer does the same thing- we got the two water hammer arresters which screw right onto washing machine pipes- it still bangs- any other suggestions or should we try a different arrester model?
  • 3 Answers
Water hammer valve at home depot fixes problem for like 20 bucks
Posted on Mar 21, 2008
    New Friend:
  • 60 Answers
The on and off is normal while it's filling and calculating how large the load is. More then likely you have rather high water pressure and that's causing the "hammering". They do make "anti-hammer" devices you can install in the line to take up that pressure surge instead of making the pipes bang. Check with Lowe's or Home Depot.
Posted on Mar 18, 2008
  • mumdey Feb 22, 2011
    I had the same problem - fixed it by getting rid of my new LG washer
What does it mean when my lg tromm WM2487HRM front load washer slowly fills the tub with water when the washer is off?
most likely water fill valve is defective and leaking. hot water or cold water? replace which ever is leaking
May 21, 2016 | LG Washing Machines
My LG TROMM Hot water continually fills even after machine is turned off and unplugged. I have to shut off water supply to stop it.
Unplug the washer removing all electrical power from the machine. Turn the water back on and confirm that water is still entering the machine.
If the condition is true no power to washer and water enters machine it is very likely that the fill solenoid has failed.
this part is not that difficult to replace.
Water Inlet Valve part 5220FR2008F LG Washer Repair
Dec 31, 2015 | LG Washing Machines
LG WN1832CW does not fill with water
The fill valve may be defective or there may be a controller malfunction that prevents the fill valve from operating.
Nov 22, 2013 | LG WM-1832C Front Load Washer
Washer is filled with water after running it completely damaged my blanket because it got soked in water!!!
your pump motor is out, whats your model number and serial number, i could probably source the pump motor part number for you......if your washer is filled with water, and not draining, your motor is out........these LG motors go out fast....
Feb 09, 2010 | LG WM2688HWM TROMM SteamWasher
Own LG Tromm Wm2277hs
may be the sensor? I have the same model and I changed the sensor now it fills.
Jan 17, 2009 | LG WM-1485FHD Front Load Washer
Lg washing machine error code is ie
IE = inlet error. Washer has not detected enough water after 8 minute fill time. Check screen at inlet water valves where hoses connect to machine for blockage. Look for kinked hose(s). Make sure there is water supply reaching machine. If all OK, most likely next thing is the water valve itself.
Sep 02, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
1,367 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
