Question about E-Machines eMachines Desktop PC
My Emachine T5212 has a loud fan constantly running
I cleaned the inside, the fans, heat sink, everything...it was running full RPM until the computer would just shut down, now it's not shutting off after I cleaned it, but still super loud. any ideas?? Thanks
also, I downloaded speedfan, but dont know how accurate it is.
RPM fan 1 = 4310
RPM fan 2 = 2897
RPM fan 3 = 0
RPM fan 4 = 0
CPU, AMBIENT, AND HD0 all read about 37 degrees C
but the REMOTE reads 79
  • labtec48071 Mar 10, 2008
    it's the intake fan on the side of the computer....HUGE
  • Robert Carmody
    Robert Carmody Dec 03, 2008
    Basically the same problem except I haven't tried to clean anything. The problem has not gotten to the point where the computer is shutting down yet but I don't want it getting to that point.
  • 148 Answers
Sounds like a fan is going out .. with the case open can you identify which fan is making the noise?
Posted on Mar 10, 2008
  • TERRI RODDEN
    TERRI RODDEN Mar 10, 2008
    you will need to replace this fan, you can take the fan out and take to a computer part store and see what they have to replace it. I would not buy anything with less rpms. There are several of online computer part stores if you know what your looking for.
My cooling fan on my HP Pavilion 23 touch screen desktop has the cooling fan running constantly now? Why would this happen all of a sudden?
It's possible that either the chip it's cooling is running hot. The heat sink inside may be covered with dust preventing the chip from being cooled. It also might be dust on the fins of the fan itself causing the extra noise.
You should have it checked out and cleaned to prevent possible damage and fan failure.
Mar 09, 2015 | HP Pavilion Computers & Internet
Emachines t5212 overheat message then shuts down
Three causes of ovheating:
1) Dust. Dust inside the computer, Dust around the vents, fans, cpu and heat sink. Take a can of compressed air and clean the dust out of the computer.
2) A Fan not working. Make sure the fan inside the Power Supply where you plug the power cord in works. Also there is a fan that sits on top of the CPU and Heat Sink. Make sure it works. Normally the system will give you an error message if the fan is not working.
3) Thermal Paste - The Thermal Paste around the cpu and heat sink has dried up or is too thin to keep the unit cool. Apply a fresh coat of Thermal Paste on the CPU and Heat Sink.
May 09, 2012 | E-Machines W Computers & Internet
Dell 370 fan runs loud and won't start
If the fan is failing the most times the computer will not start because it will overheat. There are two fans inside the system, one inside the Power Supply and one that sits on the motherboard.
Remove the Power Cord, Open the case, Remove the cover and with a can of compressed air blow out the dust inside the computer. Clean the dust away from the Fans, Vents, CPU and Heat Sink are that sits under the Fan on the motherboard.
Apr 23, 2012 | Dell Precision 370 (370TREC) PC Desktop
Emachine w3609 cpu overheating
Easy Fix.. Computers over heat because either a fan is not working, Dust has clogged the vents around the fans, CPU and Heat Sink or the Thermal Paste around the CPU and Heat Sink has become hard or too thin to keep it cool.
Remove the cover from the computer and set it aside then turn the computer on. When you hit the power button to turn on the computer make sure you hear and see the constant blowing of the fans. There will be a fan that is on the Power Supply where the power cord plugs in and a fan on top of the CPU and Heat Sink. If not, replace it. If the fans are ok get a can of compressed air from a local computer store and blow out the dust from the fans, power supply and all throughout the computer. In order to apply Thermal Paste on the CPU and Heat Sink you will have to remove the fan that sits on top of it and is normally secured by screws or some type of latching device. Once the fan is removed you can remove the heat sink and it too will be secured by screws or a latch catching device. Clean the old paste off the heat sink and off of the area it sits on. Apply a fresh coat of Thermal Paste to both and reassemble. Thermal Paste is available at local computer stores for under $20
Mar 21, 2012 | Computers & Internet
My HP Pavilion dv6 WW146AV runs hot!
In order to address this the unit must be taken apart, remove fan and clean with compressed air, next remove the heat sink, four spring loaded screws turn one "small amount" go diaganal do the same and the next two until removed from the processor ic, blow out any dirt, next remove old silicon grease with rubbing alcohol, apply fresh thermal grease to the ic and heat sink "small amount" and assemble.This will solve most issues.
Mar 05, 2012 | HEWLETT-PACKARD Computers & Internet
My cooloing fans are running full speed all the time which is very loud and annoying. how can i fix this?
Firs thing you need to do is to find our why they are running full speed. My guess is that your computer is dirty inside and it is overheating, thus causing the fans to run full speed trying to cool it off. Disconnect everything from the pc and take it somewhere to clean it out. Remove the side panel an use a can of compressed air or an air compressor to blow all dust out the interior of the pc. Pay close attention to the heat sink on the processor and the cooling fans. When blowing around the fans hold the fan in place with a pencil to prevent it from spinning as this might damage the fan. You need to clean out the inside of a pc sitting on the floor every 6 months. If you have cats or dogs that shed living inside then every 4 months. If it is sitting up high and you have no animals then every year may be good enough.
Oct 05, 2010 | HP Pavilion a1010n (PS563AA) PC Desktop
Desktop computer fan runs constantly
Desktop fans do run constantly, you cannot avoid this.
The reason they get loud is because there will be a build up of dust on the fan blades.
To rectify this problem turn off the computer and remove the power cord from the rear. Then you need to remove the side panel from the base unit to expose the motherboard.
You will see that inside the case it is full of dust. Look at the CPU fan (the fan on the motherboard) also take notice of any case fans too, they are at the back.
To clean the fans and the case you can use a clean dry paintbrush or compressed air.
Once the inside of the case is cleaned you will see a noticeable drop in noise.
Regards.
Jul 03, 2010 | HP Compaq Presario SR2150NX PC Desktop
Fans on Mac Intel Tower
I would suspect it needs a good internal cleaning. The accumulated dust will cause the computer to overheat. Disconnect all cables and take the unit to a place where you can clean it. Remove the side panel and then with a can of compressed air or an air compressor blow all dust out of the unit. Pay special attention to the heat sink on the processor. Make sure you clean the power supply fan. Be sure and not touch any internal components without first grounding yourself to the chassis. It is best to do this outside as the dust will fly everywhere. You should clean the inside at least once a year. Merry Christmas.
Dec 15, 2009 | Intel Mac Pro Tower Desktop
Very loud fan!! Sounds like jet engine and make the computer shutoff.
In side you're ZV5000 are two fans. These fans sit on a spindle which spins. The spindle may be worn which is giving you that loud noise. (Or a fan blade could be bent or warped from heat).
The fan it’s self may be loose & can be tightened.
The only way to check if the spindle is worn would be to dissemble the ZV5000. With the correct instruction you can check the fans. (And also clean the fans & copper heat sinks).
Here is a link to do this you're self, including pictures.
http://www.instructables.com/id/Cleaning-Your-Laptop-Cooling-System/
It's worth taking a look & saving you're self a few bucks.
Good Luck & take you time!
Mike
May 17, 2008 | Computers & Internet
Cleaning the fan and heat sink
I would first check for any trojans, virus's and spyware, and any programmes running at start up you don't need, as that can cause overworking of the processor, then instead of stripping down the notebook, which i don't recommend,look around any vented area of your notebook and hoover out the vents gently, this will remove any dust blokages. Give your system a good clean out with this excellent free tool called ccleaner and you can also dissable any startup programmes you dont want with the programme also. Download it here, fre and free updates and spyware free, click link and then on the right of link click download latest version. http://www.filehippo.com/download_ccleaner/
Jun 22, 2007 | Sony VAIO K45 Notebook
E-Machines eMachines Desktop PC Logo
1,587 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
