Question about Chieftec (ADX-01GNDU/SPX-02GNF) ATX Mid-Tower Case
Chieftech HPC-360-102 Power Supply dead
The Chieftech Power Supply HPC-360-102 that came with my Chieftec ATX Mid-Tower Case bit the bullet. I need to replace it, but I would like to go to a higher wattage PS. Can I use any ATX PS on the market, or does this PS which has a connection to the front panel of the case for on/off rule an equivalent PS?
  • 781 Answers
Check the size of power supply most are a standard size some from propriety manufacturers are smaller. most are fitted top of case at the back and take up the space across the back about about
6inch wide 4 inch high 6inch deep if yours is this size its standard and most should fit get one that is rated at least 400 to 500 watts
ensure it has at least 6 4pin power sockets floppy power socket and the same motherboard sockets as your old one
Posted on Jul 18, 2008
What name is given to a power supply whose case has the following features: ATX Mid Tower, ATX, Micro ATX compatible form factor, 2 Extenal 5.25
If you need a PSU you need to do a google search to find the exact match.Micro ATX,ATX, and ATX Mid as the name are the size of the PC case.
Apr 18, 2012 | Computers & Internet
Power supply compatibile with ats mid tower
Every standard ATX psu will do, just select the correct power rating for your components.
Feb 10, 2011 | Cooler Master (CAC-T05-UW) (CAC-T05-UWA)...
With a case branded CAC-T05-UW (ATX Mid-Tower Case) what power supply would you recommend?
If you are adding any graphics card to your machine, then you can buy 400w SMPS, that would be enough....
If you use any graphics card then better go for 600w or 800w depending upon the need...!
Feb 08, 2011 | Cooler Master (CAC-T05-UW) (CAC-T05-UWA)...
I need a motherboard that will fit in a Raidmax ATX1072BP Mid Tower ATX Computer Case!
Most desktop computer cases have a range of standard mount holes, standard offs.
I suggest you select a motherboard that suits your requirements.
To be sure that the motherboard will fit your case, take the motherboard mount base with you to the computer shop and place the motherboard of your choice on the base to see if the mounting holes line up.
You may need to upgrade the switch mode power supply to a higher power unit if the total power requirements is near the maximum the existing unit can deliver.
Dec 03, 2010 | RaidMax ATX1072BP MID TOWER ATX COMPUTER...
On a lighting tower i turn on 1 light and it draws 9amps when i turn on 2 they draw 30 amps and blow 15 amp fuse why ?
Why are you blowing a 15 amp fuse or why is your machine drawing so much current?
1:The fuse is blowing because you are drawing enough current to blow it.
2: Your computer, no matter what make or model should not be drawing that much current, your wall outlet is typically 15 amps.
Your power supply is most likely the culprit and may have damaged other components of your machine i.e the motherboard.
Disconnect the computer from the outlet, open it up and inspect it for burn marks, sniff for odd burnt smells.
I think you need a new power supply at the very least and maybe more.
Sep 03, 2009 | Chieftec Dragon - Lighting Yellow...
My fans and lcd have quit working
pc doesnt power up? flaky PSU,memory or mainboard
http://www.aa1consulting.com
Jul 26, 2009 | XG Viper 2 ATX Mid-tower Gaming Case...
I need to find a power supply compatible with the Cooler Master CAC-TO5-UW ATX Mid Tower
I guess a generic ones will do. As long as the wattage can support all of what's will be put inside. (e.g. for pentium 4's, 350 watts is needed including the fans, etc.)
Mar 04, 2009 | Cooler Master (CAC-T05-UW) (CAC-T05-UWA)...
Chieftec (ADX-01GNDU/SPX-02GNF) ATX Mid-Tower Case Logo
407 people viewed this question
Top Chieftec Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Chieftec Computer and Internet Expert? Answer questions, earn points and help others
