Question about HP Photosmart 3210 Printer
Paper feed problem
It will not feed the paper into the machine, it reads out of paper, load paper tray. If you feed the paper into it, the machine will eventually take it and print.
  • Anonymous Mar 18, 2014
    how to feed top paper tray in machine from C2030
  • 54 Answers
Check all this-----
1.check the printer paper feed roller jam.
2.check the paper sensor, It is working or not.
3.check the paper tray(clean it)
4.service the printer, (If possible).
Goodluck
Posted on Mar 10, 2008
My Kodak printer wont grab the paper in the paper tray
Amandasplace:
There is a sensor that is located where the front edge of the paper sits when you load paper. If you take all of the paper out of the feed tray and use a flashlight to look in the throat of the paper feed area, you should see a small piece of plastic (in the shape of a blade) sticking up. If you do not see that sensor flag it may be broken off, or there may be a small piece of paper jammed against the sensor flag, keeping it from moving downward when you load the paper tray. That can happen if you pull a mis-fed piece of paper out of the machine in the opposite direction that the paper normally travels when printing. When you load the paper in the machine, it pushes that sensor flag down, telling the machine that there is paper loaded. either the sensor flag is broken off or there is something jamming the paper sensor, keeping it from being pushed down by the paper.
Nov 23, 2012 | Kodak ESP Office 2150 All-in-one Printer
Trying to change paper size from A4 to 8.5x11 on a Xerox Workcentre M123
  1. Pull out the paper tray.
  2. If necessary, slide the paper tray edge guides so that the guides are open.
    1. To adjust the side and rear guides, pinch the guide lever on each guide and slide the guides to their new position.
    2. To secure the guides in position, release the levers.
  3. Load the paper against the left-hand side of the paper tray. Paper can be loaded either short edge feed or long edge feed.
  4. If necessary, slide the paper edge guides so that they just touch the edge of the paper stack.
    NOTE: When loading standard size paper, set the edge guides onto the notches on the paper tray to match the paper size.
  5. Close the paper tray.
  6. Set the machine to detect the paper size automatically, or manually specify the required size.
    NOTE: Paper sizes detected by the machine vary depending on the Machine Administrator setting. See the Related Items below for additional information.
  7. If the type of paper has changed in the paper tray, then the paper type must be changed on the Control Panel as well. See the To modify the paper type on the Control Panel section below.
Normally just the guides need to be set correctly in the paper tray, The tray size sensing switched may be bad or the actuator on the tray may have slipped position.
Jul 22, 2010 | Xerox WorkCentre M123 Copier
We have an IR3320N that will only feed from the bypass tray - anyone run into that symptom? It was feeding from the feed trays this am.
What happens when you try to feed from one of the trays? With paper in the trays look at the display, does it show that the correct paper is loaded in the tray? Get a flash light and pull the trays out and look back into the machine and see if any paper is jammed up in the back. Also make sure all the guides are up to the paper in the trays and give it a go.
May 15, 2010 | Office Equipment & Supplies
Paper doesn't feed from inside on XD 100 work center (10 years old, lightly used). Despite a full paper drawer, I get the "out of paper" error message.  I can copy by feeding through the back.
On this machine, the feed rollers might be worn down.
Not seeing the machine and by the description. there can also be other possible problem areas, deep in the machine itself.
Does the paper feed partially out?
If it does not, are there paper black scuff marks where the rollers were trying to feed the paper.
Can you hear the solenoids feed the paper?
If the paper does feed and seems crooked, it is possible the paper tray springs need to be stretched out just a little to push the paper tray plate more on the feed rollers.
Make sure the tray is completely up in the latched position so the feed wheels will touch the paper stack itself.
If you have a two paper tray, make sure you tell the machine what size paper you have for each tray.
Run paper in each tray.
Good luck.
Jan 15, 2010 | Xerox Office Equipment & Supplies
H2 error when printing from pdf to A3 in multipurpose tray
H2 error code means that the paper size you are feeding into the machine does not match the paper size programmed into the machine. Minolta's are picky about these 2 size matching. So if you trying to print onto A3 then when you select the multipurpose tray it must read as A3.
Here is the info from the factory service manual:
H2 The length of the paper set does not
match that of the paper actually taken
up and fed in.
• Load paper of the correct size again
according to the set paper size.
• Turn OFF and ON the Power Switch.
• For copier tray: Slide out and in the
paper tray in which the size error has
occurred.
• For Manual Bypass Tray: Place paper
in the Manual Bypass Tray.
• For Multiple Bypass Tray: Unload
paper from the Multiple Bypass Tray,
then reload it back again.
Nov 23, 2009 | Minolta Di152 Laser Printer
Samsung Scx-4216f wont pick paper out of drawer
Below would be the suggested solution regarding paper feeding problems;
If Paper does not feed into the machine.
• Remove any obstructions inside the machine.
• Paper has not been loaded correctly. Remove paper from the
tray and reload it correctly.
• There is too much paper in the paper tray. Remove excess
paper from the tray.
• The paper is too thick. Use only paper that meets the
specifications required by the machine.
Below is the suggested paper specifications;
Supported Sizes of Paper
Paper Dimensions* Weight Capacity**
Letter 8.5 X 11 in. (216 X 279mm)
• 60 to 105 g/m2 bond (16 to 28 lb) for the paper tray
• 60 to 120 g/m2 bond (16 to 32 lb) for the Bypass tray
• 250 sheets of 75 g/ m2 bond (20 lb) paper for the paper tray
• 1 sheet of paper for the Bypass tray A4 210 X 297 mm (8.3 X 11.7 in.)
Executive 7.25 X 10.5 in. (191 X 267 mm)
Legal 8.5 X 14 in. (216 X 356 mm)
Folio 216 X 330 mm (8.5 X 13 in.)
Hope this helps!
Sep 10, 2009 | Samsung Office Equipment & Supplies
Paper feed
Check tray 1 there should be an arm hanging down in the center of the tray the arm goes thru a slot in the metal plate. This arm moves when you install paper in tray 1. If the arm is missing or not in the slot the machine will think paper is in tray 1 and try to feed from tray 1. You can try changing the paper size setting for tray one to something other than the size in tray 2.
For example If tray 2 is set for 8.5x11 set tray 1 for legal.
The machine should then pull the correct size based on the print job.
Hope this helps
Jan 21, 2009 | HP LaserJet 5si Printer
Will not print
This usually happens when the paper tray is set to the incorrect paper size.
This printer determines what size paper is installed in it by the little "fingers" on the left side of the tray. When you adjust the paper tray, it determines how those fingers are positioned, and therefore, how the switch reads the paper size.
If the tray setting is off, even by one little click, then the machine may read the paper size as other then letter. If this happens, you send a letter size job to the printer, and it doesnt think it has letter size paper, it will tell you to put letter paper in the MPF feeder.
If the tray is definately set to letter, but the machine still thinks it does not have letter, then the tray or the switch that reads the tray is defective, but 99% of the time it is just the tray is not set correctly.
The MPF door can be open or closed 100% of the time with NO EFFECT on how the printer works.
Oct 10, 2008 | Dell W5300N Laser Printer
Paper won't feed
Pull out the paper tray and push the paper feed roller towards the machine. Try to turnaround the paper feed roller by hand. Reinsert the paper tray.
Nov 02, 2007 | Brother MFC 420CN All-In-One InkJet...
HP Photosmart 3210 Printer Logo
1,121 people viewed this question
Seeker5211
Seeker5211
