2005 kawasaki ZX-10R Logo
Posted on Mar 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sluggish in low down revs she hav been sat up for a few months i gave it a blast now i hav this problem n it wont start properly??? any ideas thanks
Anonymous
Level 2:
Sergeant:
  • Expert 314 Answers
  • Posted on Mar 16, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
314
Questions
0
Helped
106586
Points
689
Check that your fuel is getting through properly ,you may have a blocked jet .
Ts410 starts and runs but won't rev up properly. If you hit the primer it will then rev up nicely for a few seconds. So I suspect a fuel starvation problem.
If this occurred after the Saw sat a few months then Ethanol gas could have clogged the tiny screen inside the carburetor. The gas could have also dried out the Little 'paper' Fuel meter in the carb.
Jan 18, 2016 • Garden
I have a 1977 buick regal with a 350. Had previous problems with this car. Carburetor worn out. Anyway it sat for abt six months and i fixed it. Replaced a 2 bbl rochester with a 4bbl edelbrock. Had...
Hey Anon,
???.. Have you tried a TINY amount of gas through the carb to see if it will start then? If it does.. you know its fuel/carb related. ( I don't care for starting fluid personally).. Did you accidentally hit the distributor (move it/break something) so the timing is very far off?
Starts ok, although seems to be missing slightly, sluggish throttle response and wont rev beyond 4 thou ,
Check plugs, may be fouled> When storing bikes in my old mans garage, the plugs always foul
GROANING & SLUGGISH SEWING MACHINE
it would be a good idea to have a sewing machine technican
check the machine to see why it sluggish
Dell UltraSharp 2005FPW shut down wont power up.
You can have the board repaired for $50 or you can inspect it first for bad connectionc, bad caps, etc.
http://www.lcdrepair.us/2005fpw-power.html
1helpful
Engine hard to start wont idle sometimes wont idle down when shifting or stopsd
Won't idle down: look for dry/rusted/frayed inner throttle cable. Look for sluggish fuel flow from tank for starting problem. May have to clean the carburetor(s) and fuel filter. Are the spark plugs clean and gapped correctly?
I have a 1988 GMC Sierra 1500 thast wont stay running
Use a gage and check proper fuel pressure. With tbi fuel injection, the fuel pressure is 9--13 psi. I have seen fuel injector spray pattern that looked good to me, but, the fuel pressure was half of what it should have been. 5 psi may show a good spray pattern, but, it won't start and run a v8. In my opinion.
Any applicable trouble codes? Your obd1, you should be able to check some codes yourself, if there are any.
Frozen Phone...
try to reformat your sd card...
Top kawasaki Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Bob G
Are you a kawasaki Expert? Answer questions, earn points and help others
