Question about JVC HD-52Z575 52" Rear Projection HDTV-Ready Television
Projection LCD flickers to black and white
Just recently my lcd projection TV (JVC) started to turn black and white for a few seconds then back to color. Then repeat itself. The connection is from digital cable box with S-video to back of tv. When i turn to regular coaxial cable the color is stable and ** changing. I have **t moved the tv unit at all in the last few months.
    Genius:
  • 1,153 Answers
If the S-video cable is not completely in it will do this. You need to remove and clean tips on S-video cable/ replace, this is your problem.
Posted on Mar 10, 2008
When I turn on my 61 inch, rear projection HDTV, a picture comes on for about 3 seconds before going off. The two LCD lights on the front of the T.V flash on and off. I hear the fans in the back of the TV...
very temper mental these things if it isn't the bulbs it could be one of the control boards that operates the pic and sound, but sometimes you have to keep messing around with the bulbs
Aug 03, 2011 | JVC HD-61Z575 61" Rear Projection...
I have a JVC-HD projection TV model 56G786 and all of a sudden it will not power on. When you try to turn it on the blue light on the power button goes on but after a few seconds it starts flashing and...
The JVC 56G786 users manual will not give you a clear or specific answer about confirming bulb failure with the LED lamp or power indicators located on the front of the TV.
If the TV was operating normally for an extended period of time (months or years) and will not start, the problem is almost always bulb failure. If the "Lamp Replacement" warning previously appeared "On-Screen" and the TV will not start, bulb has failed.
The first step in a "no picture" situation with a JVC LCD Rear Projection TV is bulb replacement. There is no way to measure the bulb. Sometimes the bulb is visibly broken or damaged when it fails. Remove the lamp cage and have a look.
The JVC Lamp Gallery has all the JVC models and lamp numbers listed. There is also a link to DIY JVC bulb and lamp installation.
If a good bulb is installed correctly and the TV still does not start, you need a technician. There are no user serviceable parts other than the bulb. Failure of ballasts, power supply boards or controller boards is rare in these TVs.
easyab
May 05, 2011 | JVC HD-56G786 56" Rear Projection HDTV
Jvc 52" hd tv screen yellow
Have crack screen sign?Not fixable only require LCD changing,not buy able LCD screen only can buy it new from the tv compannies,but only sell as new tv only.
Jan 08, 2010 | JVC HD-52G787 52" Projection Television
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
Sony LCD Projection TV turning OFF.....help!!!
This is most likely a bad lamp and the lamp is easily replaced. Simply find the lamp replacement instructions in your owners manual.
Apr 02, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Television
there will be 2 convergence ICs that you can access from the front. take the grill off in front(screws behind door and on side in back of tv)and take the panel off. then the board right in the front with the black heat sinks is the convergence power board. take the board out or position it comfortably and replace the 2 large ICs(stk392-110) and any burnt resistors you can see. after fininshed check alignment in the regular tv menu.
Feb 18, 2008 | JVC AV-48WP74 48" Rear Projection...
Picture blacks out after a few seconds after turning on the tv
Anytime an LCD has a shade of pink, that means the CCFL lamps are about to go out. Now that you have a black screen, I'd say you just need some new bulbs.
Dec 07, 2007 | JVC LT-32X576 32 in. LCD Television
Green Picture
I guess it's missing blue. Even if you see the blue crt working it's not enough and focalised. replace the coolant in it and also check if you have some coolant leak on the crt pcb.
Apr 10, 2007 | Samsung HCN436W 43" Rear Projection...
JVC HD-52Z575 52" Rear Projection HDTV-Ready Television Logo
83 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
