Question about SanDisk Sansa m240 MP3 Player
Shuts off right away
I replaced the battery but when i turn it on, it stays on for about 2 seconds, then it says powering down... how do i dic this?
  • scub123 May 01, 2008
    I have the same probelm. I have formatted the player in MSC mode & replaced battery with a fresh one but when started in just initializes and then goes to the powering down screen.
Bad battery
Posted on May 20, 2008
    Problem Solver:
  • 9 Answers
Is it possible that you aren't holding the button long enough?
Posted on Mar 27, 2008
System is frozen. Wont shut down or go to start screen.
Here are two things to try:
I- Using the Power button:
1 Press and hold the Power button for at least 4 seconds.
2 Swipe-down the shutdown confirmation screen to the bottom
edge of the display to turn off the tablet.
Using Charms:
1 Swipe-in from the right edge of the display to access Charms.
2 Touch Settings
Turning Off the Screen
Press the Power button to turn off the screen.
Using Charms:
2 Touch Settings
NOTE: If your tablet is in a standby state (tablet is on, but screen is off), press the Power button or Windows button once to turn on the screen.
12
Setting Up Your Tablet
? Power
? Shut down to turn off the tablet.
II- Unplug the battery, wait 30 seconds, then install the battery again.
Sep 04, 2015 | Dell Venue 8 Pro Tablet Computer
My LG pdp42x3 plasma doesnt turn on.
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Oct 02, 2012 | Cell Phones
It wont stay power up;and screen stays black; and shuts down after a second' please help'''''
try to power drain pc first. to do that, turn pc off, remove battery and ac adapter. press down power button for 15-20 sec, then but all back in and try to turn pc on. if still no go, you may need to replace battery or ac adapter, f it still wont work, possible motherboard replacement is needed.
Mar 29, 2010 | Dell Inspiron 1501 Notebook
My rm laptop when powered up flashes the hard drive light then the cd light then just sits and the fan hums away
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Oct 28, 2009 | Computers & Internet
My A215 wont stay powered up. It shut down and
Try running the computer on the Battery power and check if the power sustains. If not, then disconnect the power cord and remove the battery and leave it for a few hours then try turning it on.
If the problem exists then the power supply unit is required to be replaced. You may contact service center to get the power supply unit replaced.
Oct 01, 2009 | Toshiba Satellite A215-S7422 Notebook
Toshiba satellite M55 not turning on
Either the battery is faulty, or the charger is faulty.
Check the fuse in the mains plug, or even the power point you are using could have a bad connection.
Test using a lamp that you know works or a radio or something and try the charger in another outlet to find the fault.
May 24, 2009 | Toshiba Satellite M55-S135 Notebook
Dell e770 Monitor
It sounds like the picture tube in the monitor has burned out. Time to replace.
Feb 03, 2009 | Dell E770 Monitor
BATTERY LOW, POWERING DOWN! SANSA M240
Hey,
Try these steps, if they aren't of any help, you may have to have the vendor replace your mp3 player.
SOLUTION 1 - Reset the device.
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
SOLUTION 2 - Power cycle the device.
STEP 1 - Remove the battery
STEP 2 - Power cycle the player
1. Connect the device to the PC.
2. Leave the device connected for about 2 minutes.
STEP 3 - Turn on the device
1. Disconnect the player from the PC.
2. Insert a fresh AAA battery into the player.
3. Turn on the player.
Jan 16, 2009 | SanDisk Sansa m240 MP3 Player
Turns Off by itself
Causes for this problem can be any of the following:
1- CPU gets overheated. solution: clean dust from fan and heatsink assembly and donot forget to replace the heatsink compound, this is very important.
2- Memory problems. solution: use a program called MEMTEST86+ from the site http://www.memtest.org/ . It is a free and great program.
3-Power problem. By time the capacitors of the power supply gets dried. Causing them to not be able to fulfill power demands. solution: try working with power supply without battery. As the power supply has to run computer and charge battery. We reduce the load. If everything is fine. repair power supply by replacing deffective capacitor.
4-Battery problem. Try operation without battery.
5-Dried solders on motherboard or a component problem on the motherboard. Solution: no solution except replacing motherboard.
Eng. A. Jarabaa
Aug 28, 2007 | HP nx9110 Notebook
SanDisk Sansa m240 MP3 Player Logo
42 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
