Question about T-Mobile Dash Smartphone
Mini SD card
I guess I'm a dummy. How do I access the car via the Dash? How do I tell programs on the Dash to access files on te Mini SD Card? Thanks-
  • newdashgrl Mar 20, 2008
    Thanks ZeroShift!
Goto the Start Menu, then down to File Explorer. Hit the menu Softkey and scroll down till you see Storage Card. The other way is if you hit the Up softkey while in /My Documents (where file explorer defaults to), just scroll down and you should see Storage Card. It's easy to tell because it has a small pic of a MicroSD card on the folder. Hope this helps!
Posted on Mar 12, 2008
Is there a sd card reader on my gateway laptop
Examine the laptop along the edges and look for a **** about 2cm long (about 1 inch). As you look around the edges (left, right, front) try reading the markings.You might see something like SD. Access to the port may be covered with a dummy card which you press with the finger to make it pop out to open the port.
Apr 05, 2012 | Canon ZR200 Mini DV Digital Camcorder
How to find the file manager in sony ericsson xpera mini e10i
i need to open the memory card folder to view all the things in my memory card ( in the phone itself )
Jan 06, 2012 | Sony Ericsson XPERIA X10 Mini E10i...
One day my SD card was fine and full of pictures and now when I put into my computer it says that the SD card is corupt and can not read it. Can you help me recover the pictures from this SD card?
You may need to try some photo recovery software to rescue the pictures, here are some for your option. You may not recover all the pictures, but will recover most of them.
Photo Recovery (for Windows)
Photo Recovery for Mac
Both programs are able to recover pictures, videos and music files.
Note: Before your files are recovered, do not attempt to save more files to the memory card or stick in case the original lost files are overwritten.
Nov 07, 2010 | Lexar SMC TIGER ACCESS MINI GBIC 1000BASE...
I have fitted a sd memory card for my n97 mini but can't seem to access the files that I have dropped onto the card. Does the card need to paired to the device?
as far as you can access the memory card through your file manager, all you need to do if the memory card is not faulty is format it ussing the phone
Nov 02, 2010 | Nokia N97 mini Smartphone
MicroSD atchment write protect
The microSD card has no visible write protect tab that you can access: you need to use a Micro-SD to SD/mini-SD adapter that usually comes with your Micro-SD card and use the ON/OFF sliding tab on the adapter to disable or enable the wiite protection on your Micro-SD card: test the access via the adapter card before removing it.
Hope it helps: let me know how you go!
Mar 07, 2010 | Cameras
I have a T-Mobile G1 with a micro sd card; trying to sync??
most mini sd cards come with a full-sized sd card adapter that the mini slips into. You can then slip that in your computer if you have an sd slot or sd reader.
You can also buy very inexpensively, a usb port mini sd reader that you can plug directly into your usb port on your computer. Then after you'v dragged and dropped the files, you can put the mini sd back in your phone.
Jun 16, 2009 | SanDisk 2GB microSD Memory Card
Im trying to put songs on a mini sd card for my phone how do u put them on a sd card
format the card in tools, then with the micro SD inserted into your computer, access the card from the "my computer", create a file titled MUSIC, then drag drop files onto card. MP3 FORMAT ONLY
Apr 24, 2009 | LG RUMOR Cellular Phone
Using wmp to sync to mini sd card for a moto ve240 mp3 player
the device has to format the card. at this time the phone will create folders for music, videos, images, and what not. now when you insert the card into your computer you will open the card and copy the files to the music folder. this will allow access to the files from the handset visual platform.
Good Luck and please rate this solution!! :D
Mar 19, 2009 | Motorola Cell Phones
Installing the memory card in my Treo 650 cell phone
there's a card slot on top of the device - see pic attached (which shows both - SIM card and memory card slot opened). To open it press down and release dummy card, thenn pull it out and put SD card into slot (pushing it slightly deeper)5deba98.jpg
You can back up your Treo to either your PC or your SD
card. If you back up to your PC via hotsync, then there is a nice freeware which
can be installed to your Treo that is called SyncAll (all one has to do is right
before the sync, open the program and click "force all to sync"), and it will move
all the files, including preferences and such that don't normally get sync'd. If
you backup to your SD card, there are numerous programs for accomplishing this. It
is important that the number of backup-to-SD programs are limited for the Treo 650
due the NVFS file system. You can try THIS ONE for example - it's free.
Apr 26, 2008 | Palm Treo 650 Handheld
Data access problem with SD card for rx 3715
SD cards can be tricky. One good program that I like is pocket mechanic..... http://www.pocketgear.com/software_detail.asp?id=12178&associateid=373.
Sep 14, 2005 | HP iPAQ RX3715 Pocket PC
T-Mobile Dash Smartphone Logo
94 people viewed this question
Top T-Mobile Computers & Internet Experts
ismael castillo
Marvin
Marvin
Edward Talavera
Edward Talavera
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
