Question about Mitsubishi WD-62525 62" Rear Projection HDTV
My tv the letters are blurred like theres 2 letters
I dont know what to do ,, the letters have a white shadow
  • 42 Answers
Is it like a haze? The convergence can be the issue too... Before you call in a tech, try to go into the menu and reset everything to default. Next, clean the filter and then if you are willing, take the cover off just below the on set menu buttons. the panel pops off... behind that on the left side is the lamp box, you can check to see if there is a lot of dust, if the set has been off a while, even unscrew the screws and pull the DLP bulb out carefully and inspect it. The only thing you are looking for is burn areas in the lamp. It would be on the top of the bulb and is caused from excessive heat.
My official guess is probably to say the set needs serviced by way of a proper cleaning, and convergence adjustment.
bob
Posted on Mar 12, 2008
    Genius:
  • 1,153 Answers
You need to do a convergence reset
Posted on Mar 10, 2008
White shadows
Usually it is normal but if contrast set way too high that can also cause it.
set bright at about 70% and contrast a bit lower.,
Mar 12, 2012 | Mitsubishi WD-62525 62" Rear Projection...
Color shadowing on white lettering
This is called convergence.
If the TV has auto convergence or 'Flash Focus', run it. All projection TVs have customer controls for minor adjustment. Give it a go with the menu or the remote convergence controls.
If not, this is a common adjustment made by a technician on a house call.
If the error is really big, say the colours are curved or you can see clear separate letters and things, you will need the convergence repaired. Get a quote - Usually about $300- $600 in home service.
Mar 29, 2010 | Televison & Video
My RCA 54 in projection tv shows a blurred picture
On the RCA - Color Wheel Encompass Parts Distr look up online or call them 1-800-638-3328 Other TV could have Bad capacitors pull back off if any of the caps are puffed up on top then they are Bad 1000uf 16v , usally find 2 or 3 bad
Oct 08, 2009 | RCA HD50LPW175 50" HDTV
Blue shadows on my philips projection tv
You have possibly contaminated fluid in your blue picture tube if it has a hazy look.Blacks and whites look bluish and whites have a blue bloom to them.The other problem could be bad convergence amps.This would be double image around letters on the screen.
Jan 13, 2009 | Philips Magnavox 51MP392H Rear Projection...
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Red shadows to picture and letters on Sony TV
its most likely a warped lcd plate in the optic block if thats the correct model number which would require a optic block change out
Jul 05, 2008 | Sony KDF42E2000 42" HDTV
Green shadows all over the screen
You didn't say how old the set was and how much it's used, but the shadows you're describing sound like a bad green picture tube.
Hope that helps...
Geno
Apr 25, 2008 | Hitachi 53UWX10B 53" Rear Projection...
IM HAVING A SLIGHT PROBLEM
You need service. Sounds like the convergence is out of adjustment. As the picture is formed by a tri- gun arrangement (one for each colour), if any of them is not correctly aligned, you will see shadows on any sharp line like text, or blurring on a picture. The shadow or blurring will often be one colour i e. red, blue or green.
Mar 27, 2008 | Mitsubishi VS-45609 TV
Images are blurred on screen.
You may have a defective dynamic focus circuit or or the Hi Voltage transformer. if your not a tech it is advised that you call in a trained tech as this is not a place for an experimenter to be. TO MUCH HI VOLTAGE and will make you cry if you live!!!!Good Luck
Aug 03, 2006 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
