Question about Kodak Easyshare M753 Digital Camera
KODAK M753 LENSE ERROR 122,1,0,0
MY DAUGHTER DROPPED HER KODAK M753 DIGITAL CAMERA FROM A TABLE ONTO THE FLOOR.THE TELESCOPING SHAFT OF THE LENS WOULD NOT RETRACT AND THE CAMERA WOULD NOT WORK.THE LENS WAS A LITTLE BIT COCKED AND I WAS ABLE TO STRAIGHTEN IT UP WITH SOME PRESSURE FROM MY HANDS.AFTER STRAIGHTENING THE LENS UP IT STILL WILL NOT RETRACT AND THE CAMERA DOES NOT WORK AND IT FLASHES LENS ERROR 122,1,0,0 WHEN I TURN IT ON.ANY SUGGESTIONS?
  • 8 more comments
  • purps Mar 11, 2008
    same error and same model of camera. i did not drop the camera though, it was inside my bag, maybe it was accidentally turned on and since it was still inside the camera bag, the lens did not fully expand, now it wont retract. When i tried to turn it on, it still won't retract and the Lens error 122,1,0,0 showed up.
  • Anonymous May 15, 2008
    my camera fell off the table and it has the same lense error...the lense is squished down in one corner
  • Anonymous May 19, 2008
    Checked battery. May need new battery
  • Anonymous Oct 30, 2008
    i just had the same exact problem. i was taking pictures and set it down and it turned off like normal when it hasnt been used for a few minutes and then the lens stayed out and now it wont go back in..when i turn it on it says lens error 122, 1, 0,0 and has a black screen! what can i do????
  • Anonymous Nov 06, 2008
    i tried to pull it out and it wont work
  • Anonymous Dec 04, 2008
    same exact problem with my camera
  • kayleedeck12 Dec 07, 2008
    i need to fix my camera, it has a lense error
  • Hersheycrazy Dec 08, 2008
    When I  dropped mine on the floor, it said LENSE ERROR 122,1,0,0 problem and I didn't know how to fix it so could you please help me !!!
  • cherryices Apr 30, 2009
    My lens is stuck and cockeye and camera won't go on. Please help.
  • Anonymous May 13, 2009
    Hi all! :) I'm from Russia, so excuse me for my english. 20 minutes ago i solved this problem (KODAK M753). It was the sae error. My girlfriend dropped camera. I opended it. When i put out the lens, i start to turn all round parts manually (camera do this automaticly when you turn it off). So i heard some sound (like something was broken). AND ITS WORKING. BUT, now all my photos ARE VERY BRIGHT? What is means? :(
Thank you guys It worked this way!!!
Posted on Nov 13, 2008
Posted on May 13, 2009
Camera dropped on floor, lens crroked and lens error message like above. Like above, I gently "pulled" the lens out, and it clicked. Turned the camera on and it worked fine.
Posted on Nov 24, 2008
Posted on Nov 19, 2008
I had this problem too, my camera just randomly stopped working and shut off. When I tried to turn it on again it said the whole 'lens error' bit and then shut of. The lens looked a bit crocked so I just gently tried to straighten it out and ta-da! Good as new!
Posted on Nov 03, 2008
That just happened to me,
all i had to do was find the spot where it was stuck,
and pull on it a little,
my cameras as good as new now!
Posted on Jul 11, 2008
  • 477 Answers
I hate to tell you but unless you can get every thing back in alignment you need a lens replacement. I replace lenses on camera's all the time due to several problems but it sometimes cost just as much as a new camera. check out digital camera repair their are several places out their like mine @ www.digitalcamrepair.com
Posted on Mar 18, 2008
Problem with Kodak EasyShare M753 My camera was working just fine before but then i try to turn my camera on and i get camera lens error 122 1,0,0 the lenses look crooked and after i try to turn it on it...
You can try to pull and twist on the lens as you turn it on. Sometime this will work. Do it carefully.
Sometimes the lens jumps out of the track, and may be able to be put back with some careful help.
If not, sell as a used as is or repair camera on a site such as Amazon on Ebay.
Jul 10, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
Lens error 10e,1,10- Kodak EasyShare M753
this is an hardware error. I'm sorry but you can't fix it by yourself. You've to contact kodak for a repair.
Oct 16, 2009 | Kodak Easyshare M753 Digital Camera
Lens error, so camera isnt' working at all.
Have to replace lense barrel. You can buy parts on e-bay if you like to fix it yourself or check out the repair services there.
Apr 18, 2009 | Kodak Easyshare M753 Digital Camera
Hershey, take a small pair of needle nose pliers and try and wiggle the lens and it should work! I just did it with my daughters camara
(Same camara, same error message) Good luck!!
Dec 08, 2008 | Kodak Easyshare M753 Digital Camera
Kodak Easyshare M753 Camera LCD vertical purple lines bad focus
There is no hope for the display..Plan on spending about 50 - 70 dollars for a new TFT display.
Nov 23, 2008 | Kodak Easyshare M753 Digital Camera
LENSE WON'T CLOSE
try charging the camera. to full capacity. then turn it on.
could be a dead battery
i would not try to push the lens in, it might cause more harm than good.
if that doesnt help you might have a broken gear in the lens retracting mechanics.
Jun 04, 2008 | Kodak Easyshare M753 Digital Camera
Lens error 122
ok,white screen is LCDproblum or flex conecting pro,error 122 is ur lens barrel stuckup or mechanical gears problum this is repareable u try ur local repairer
Mar 03, 2008 | Kodak EasyShare M853 Digital Camera
Kodak Easyshare M753 Digital Camera Logo
610 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
