SAMSUNG HLS4676SX UNEXPECTEDLY SHUTS DOWN DURING USE. PILOT LIGHT (GREEN/LOWER RIGHT CORNER) BLINKS FOLLOWING SHUTDOWN. PROBLEM CAUSE? SERVICE MANUAL COVER THIS PROBLEM?
  • Anonymous Feb 27, 2009
    same problem here!
Posted on May 19, 2009
Engine runs for about 30 seconds and shutdown like an electrical shutdown as opposed to a fuel related shutdown.
Engine fired up, ran normally for 30 seconds, then shut down ...
www.thedieselstop.com > ... > 7.3L IDI Diesels (Not Power Strokes)
Sep 25, 2012 - Engine fired up, ran normally for 30 seconds, then shut down. ... it fired up and has been running since... if it just ran out of fuel jump it, and keep ...
Viewing a thread - cummins m11 starts then dies - AgTalk Home
talk.newagtalk.com/forums/thread-view.asp?tid=332921...flat...1
Sep 24, 2012 - 9 posts - ‎9 authors
98 KW with a cummins m11 will start and run for 5 seconds then dies. ... anything else like that, because it would run for 30 seconds and then die, not 5. ... The engineprotection system will not shut down the engine unless the ...
[PDF]John Deere Engine Safety Shutdown with "Black Box" (prior ...
www.tuckerbilt.com/.../John%20Deere%20Engine%20Safety%20Shutdo...
John Deere Engine Safety Shutdown with "Black Box" (prior to Tier II ECU ... Ifengine fails to start in 30 seconds, the Low Oil ... Test #1 (Engine not running).
1800 RPM for 30 sec before shut down [Archive] - Pilots of America ...
www.pilotsofamerica.com > ... > Pilot's Lounge > Technical Corner
Jan 01, 2016 | Cars & Trucks
How to shutdown windows 8
hi dear please follow
If you don't see the power button on the Start screen, here's how to shut down:
  1. Swipe in from the right edge of the screen, and then tap Settings.
    (If you're using a mouse, point to the lower-right corner of the screen, move the mouse pointer up, and then clickSettings.)
  2. Tap or click Power, and then tap or click Shut down.
Jun 19, 2014 | Computers & Internet
Tv shuts down
Unit has gone into a shutdown status. You need a technician to come out and troubleshoot the set and determine the problem. Could be as small as a cold solder joint or as bad as a large short.
Apr 21, 2014 | Samsung PN64E8000GFXZA - PN64E8000 64 3D...
My XPS 200 keeps shutting down and power light blinks
During when does your computer shutdown? Please check the diagnostic lights at the back as well which ones have light on it during the time it would shutdown.
Since you said that the light is blinking yellow it just says that your power supply is running outside its normal operating range. So most likely you would need a change of power supply. Maybe a higher wattage would be better.
Apr 28, 2010 | Dell XPS 200 PC Desktop
How reboot my satallite pro laptop
To reboot a windows computer with Windows XP, click the Start button in the lower left corner, then click Shutdown, then Shutdown again in the popup box.
For a Windows Vista machine, click the windows Orb in the lower left corner, then the small arrow next to the lock on the bottom right of the start menu then click shutdown.
If you need to manually power off, hold the power button down for 5-10 seconds until the computer itself shuts off. This is only for when traditional methods do not work.
Jan 12, 2009 | Computers & Internet
I am 56 years old computers are not my generation. just got a new computer. and am trying to close it but it would not close . what I did is close the the monitor. and then pressed the button off of the...
You have to click the Start button and choose "Shut Down " and click the mouse on that. If that does not work, try pressing Ctrl + Alt+ delete simultaneously. What they call the task manager will come up. choose Shut down and click on it. It should shut down
Nov 08, 2008 | Acer Computers & Internet
Rca model d52w19
blinking light indcate a processor shutdown.. the processor has detected a problem in safety circuits and shut down the set. common problem are flyback and horizotal ouptut transistor. the processor has a error log file. technicians can plug a specail computer and read those to determine problem
Oct 28, 2007 | RCA D52W19 52" Rear Projection Television
Receiver Shutoff
That may be a clue to your shutdown problem. Disconnect that speaker and see if the unit still shuts down. If it does not, then there is a problem with this speaker,or the wiring going to this speaker. If the unit still shuts down, disconnect each speaker at a time to see where the problem is. If none of the speakers seem to cause the shutdown problem, there is na major fauly in the amp circuit, so the amp will need serviceing or replacement. Good Luck
Apr 08, 2007 | Kenwood VR-4090 Receiver
Comp won't start
Your MotherBoard has 2 LEDs in the lower right corner, each designating a power condition. They are labeled LED14 and LED21. LED14 lights when there is a power source connected. If this is the one blinking it likely indicates a failed power supply. If you have an alternate power supply available that is comparable in power supply capabilities I would try that. LED21 lights when the system is powered on. Replace the power supply.
Dec 03, 2006 | Abit IS7-E2G Motherboard
Televison & Video Logo
941 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
