Question about Kenmore 98702 Stacked Washer/Dryer
Kenmore/Whirlpool 417.99170120 Laundry Center
My dryer squeels when its on. I am assuming it is either a rear bearing or dryer drum rollers. Problem, I dont see any listing for rear dryer drum rollers only part for rear central bearing. Please comment. Thanks
    President:
  • Kenmore Master
  • 2,651 Answers
5303281153 comlete rear bearing kit, should come complete with insrtuction's
Posted on Mar 10, 2008
My dryer won't spin and is squeeling
It sounds like either the belt is loose or the drum is frozen. Try the following links to see if they help.
Appliance411 Home Service Appliance Repair Manual for Whirlpool Kenmore...
This will help if you have never repaired a dryer.
User Manual Downloads
Feb 05, 2016 | Kenmore HE2 6.7 cu. ft. Gas Super Capacity...
Kenmore stackable laundry center dryer model 417-99570140 - drum seems loose and some clothes have grease or burn marks like they are getting caught. I am not sure how to fix this problem.
repair can be done at home, sounds like either the drum bearings are worn or the rollers are worn/missing/broken allowing the drum to move inappropriately. This is an indepth repair, so if you are not comfortable with it, call in a pro.
Oct 19, 2014 | Washing Machines
Dryer drum started vibrating tremendously. I verified the belt and it looks in good condition. Suspect it might be the bearing or rollers if any. How do I remove back panel to inspect? (Kenmore Laundry...
You can't take the back panel off because that is what holds the bearing and holds the drum. I can tell you the bearing is the most likely cause. http://www.repairclinic.com/ sells the bearing kit and I would go ahead and replace the belt while you have it apart. I've done it by myself a few times, but it is best to have someone help at least while putting it back together. Holding the drum in place while putting the screws in the back of the drum (on the bearing) is the hardest part of the whole job. I believe I also got the directions from Repairclinic.com also.
Oct 23, 2013 | Kenmore Dryers
Maytag dryer makes loud squeeling noise when it gets hot. Drys clothes but makes such a loud squeeling noise. Have to let it cool down to continue to dry.
Hi and welcome to FixYa, I am Kelly.
A loud squeal is usually caused by either an idler pulley bearing. a drum roller bearing or a loose belt.
Since you did not include a model number I have to respond with generic across the board information. Idler pulleys, drum rollers and belts for Maytags can be found on this link:
(Just past half way down the page) http://www.apwapplianceparts.com/Laundry+Appliance+Parts/Dryer+Appliance+Parts+/Dryer+Drive+Belts+Idler+Pulleys+and+Support+Rollers/default.aspx
You can enter your model number on this page and find your parts: (Choose model number)
http://www.appliancepartspros.com
If you do repair it yourself.... do yourself a HUGE favor and either take a picture of the belt routing or draw a belt routing diagram BEFORE dis-assembly.
Thanks for choosing FixYa,
Kelly
Jun 08, 2011 | Maytag Dryers
Squeeling noise when dryer runs
Replace the dryer rear drum support bearing.
Problem will be solved.
Feb 22, 2009 | Kenmore 62622 Electric Dryer
Whirlpool dryer drum making noise
window.google_render_ad();There are many places & parts that could be causing your Whirlpool dryer to be noisy. To find out what is causing the noises, you need to find out where are the noises coming from.
Start the dryer and let it run for a while and listen to try to pinpoint where in the dryer the noises is coming from. Once you have an idea of the area, you will need to disconnect the dryer from the wall outlet and take the dryer apart.
Below you will find the parts that you need to check when your dryer is noisy.
The drum baffles:
The drum baffles are use to tumble the clothes inside of the drum, in other words, the baffles job is to separate the pieces of laundry as the drum turns.
When the dryer is getting older and if you use the dryer a lot, the drum baffles holding screws will become loose. Loose drum baffles will cause noises. All you need to do, is to open the top panel and tighten the drum baffles holding screws.
The drum support rollers:
These dryers uses four drum support rollers, tow on the front and two on the rear. The job of the drum support rollers is to keep the drum tumbling smooth.
When the grease on one of the rollers dry out, the roller start to make squeaking noises and the roller bearing will start to wear out until the bearing on the roller is gone. When the bearing on the roller is gone, the noise will change from squeaking to a clanking noise.
The blower wheel:
The blower wheel is use to circulate the air inside of the dryer drum. The most common Whirlpool blower noises are cause by something falling inside of the blower housing and hitting the blower when the motor runs.
The Idler pulley:
The Idler pulley is use to apply the necessary tension on the belt. There are two types of idler pulleys, the pulley with the wheel and the pulley with the teflon slide. A bad idler pulley could cause a Whirlpool dryer to be noisy.
The drive motor:
Worn out bearings on the motor will cause the motor to run kind of noisy. When the motor starts making noises, the solution to this problem is to replace the motor.
The belt:
The belt on most dryers is only about1/4 inch wide. These belts work very hard making the drum tumble. When the belt stretch just 1/2 inch more that it supposed to, the belt will start slipping and that could cause your Whirlpool dryer to be noisy.
As you could see, there are a lot of parts that could become noisy in your dryer. When your dryer starts making noises, make sure to check it out before it gets worse.
Feb 09, 2009 | Whirlpool LER4634J Electric Dryer
KENMORE DRYER
Hello ENRIGHT11 Welcome to Fixya
My name is Huum,
You said,
DRYER MAKES VERY LOUD NOISE WHEN RUNNING. ALTHOUGH IT HEATS UP AND BEGINS TO DRY, IT STOPS RUNNING COMPLETELY AFTER ABOUT 5 MINUTES. IF YOU WAIT AN HOUR, YOU CAN START IT AGAIN, BUT IT AGAIN SOUNDS VERY LOUD (ALMOST A RATTLING SOUND) AND THEN SHUTS OFF AFTER 5 MINUTES
Faulty Blower Wheel
If you hear a great deal of noise coming from the blower area of the dryer when it is running, then the blower wheel could be defective.
The are many different designs for blower wheels and just as many unique failure modes. Vanes (fins) can break off the wheel and bounce around in the blower breaking more pieces. The blower can break around the coupler with the shaft. This can cause the blower to spin loosely on the shaft. The blower can form cracks which cause it to vibrate, etc.
You should also not be surprised to find foreign debris in the blower. The occasional bird, rodent or squirrel has been known to bypass the out vent cover. If they crawl into the exhaust tube the first thing they come into contact with is the blower wheel.
If the blower wheel is not spinning, or if it is missing vanes, it is not moving air efficiently. As a result, heat is not removed from the heat source and it can trip the high limit switch or blow the thermal cut-off.
Worn Belt
A worn belt can stretch and/or become brittle with age. The belt can then slip on the drum or motor to cause squeaking. If this is the case, the solution is to replace the worn belt.
The belt is not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, worn drum glides or worn drum rollers depending on brand and style.
When replacing the Belt is is a good idea to also change the Drum Support Rollers, Drum Glides, Idler Pulley and Clips. All of these items are economical easily changeable when replacing the belt. The upside is that your dryer will operate like new.
Recent Customer Symptoms:
Dryer makes loud noise when turned on. Dryer works and heats up OK but makes too much noise.
Worn Drum Glides
Some dryer models are equipped with Drum Glides. The front of the dryer rests on these glides. They provide a low friction surface on which the drum spins. After time however, this glides wear down. Much like an automobile brakes, these glides make a load grinding noise when they wear thin. This griding against the drum usually leaves a bare metal stripe that is visible at the point of contact. If the glides are worn, the solution is to replace them.
The drum glides not the only items that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, a worn belt or worn drum rollers depending on brand and style.
When replacing the Drum Glides it is a good idea to also change the Drum Support Rollers, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new.
Worn Rear Drum Bearing
Some dryer models are equiped with a Rear Drum Bearing. The rear of the drum rests on this bearing. It provides a low friction surface on which the drum spins. After time however, this bearing will wear down. If the bearing is worn, the solution is to replace it.
The rear drum bearing not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum glides, a worn belt or worn drum rollers depending on brand and style.
When replacing the rear drum bearing it is a good idea to also change the drum glides, drum support rollers, drum belt, idler pulley and clips depending on make and model. All of these items are economical and easily changeable when replacing the rear drum bearing. The upside is that your dryer will operate like new.
Worn Drum Support Rollers
Some dryers such as Whirlpool/Kenmore brands are equipped with Rear Drum Support Rollers. The weight of the dryer drum rests on these rollers. They provide a low friction surface on which the drum spins when in operation. After time however, these rollers wear down. When they wear, often times they begin to elongate and form a non-round 'cam' shape. The result is that when the dryer is turned on it creates a rumble that sounds as though you are trying to dry a pair of tennis shoes. This sound is usually the drum being forced up and down on the non-round wheels. If the rollers are worn, the solution is to replace them.
When replacing the Drum Rollers it is a good idea to also change the Front Drum Glides, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new. Whirlpool
Kenmore models have a dryer maintenance kit that contains all of these items in a single kit.
Thank You For trusting us with your question
Please remember to leave a
solved rating before you leave!
Jan 21, 2009 | Kenmore 63942 Dryer
Kenmore Dryer makes Noise Model 86671100
Very few of the tubs are true to round. You stated it has made the sound since you've owned it. Observe and listen to see if you can determine the closet area to the noise. Usually moveable parts get louder over time. Your problem could be a number of things. I would start by adjusting the bottom leveling feet and be sure it is level front to back as well as left to right. Other items could be drum seal gasket bearing, rear felt seal, rear drum support roller, belt tension pulley, blower wheel, blower wheel housing, front drum glide bearing, shaft drum support roller, bracket for drum support roller, front ring bearing kit, pully on the motor, or even lose cabinet housing bolts.
Use the below link to refer to on how to get inside:
http://fixitnow.com/2003/11/appliance-tip-of-day-dryer-disassembly.htm
Nov 07, 2008 | Kenmore 22422 Top Load Washer
What is the noise coming from my dryer?
your bearing is going out, basically there are two types , look on the back center of unit ad see if there's a bearing screw or something (actually the bearing screws in from the inside , but screws are visible ) this is a center bearing type, the other is a glide system front glides and rear rollers are what carries the drum weight i have seen rollers go out and the drum actually scraping a hole in the side of the cabinet.
Mar 30, 2008 | Kenmore 62602 Electric Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
449 people viewed this question
Sal De
fordexpert
Robert Rankin
