Question about NetGear WIRELESS PRINT SERVER 54MBPS W/4PORT SWITCH (WGPS606NA) Print Server
Installation assistant cannot detect print server
I'm in the very beginning of install/setup and crashed on take-off (actually taxi)
  • BrettC Apr 01, 2008
    I have same issue with my XP laptop not seeing the WGPS606 print server. Can you please explain what steps the Netgear support tech had you perform?
  • stephenstrai Apr 12, 2009
    my brother mfc8870dw will say connected on the open connection, but the braporfessional system or the computer will can not see to complete setup...I have been through the manual and inputed the requirements into the printer and downloaded the drivers, but they will not communicate
Results of attempting to connect the Netgear Wireless Print Server WGPS606 and the Canon MF6550 multifunction laser printer. I was on the phone for several hours last evening (March 9, until about midnight EDT) with a very competent support agent from Netgear (actually in the Philippines). The Netgear setup Wizard software would not connect the Print Server to my Verizon FiOS wireless G router automatically, so the Netgear support agent walked me through it manually. The Print Server connected that way, for sure. Then we manually attempted to connect the Print Server to my Canon MF6550 and subsequently, my HP 932C Deskjet. Neither printer is on the WGPS606 compatible list, nor is either on the known incompatible list. Now we know - both printers are INCOMPATIBLE with the Netgear WGPS606. I bought both the Netgear Print Server and the Canon MF6550 at Staples on Sat., March 8, 2008, based upon the assurance from Staples staff that it would all work. The question now is whether ANY brand of wireless Print Server will work with the Canon MF6550, or do I have to return this printer and get either a Canon with built in networking (ethernet or wireless) or switch to the Brother equivalent (MFC 8870DW). If I get a (multi-function) printer with built-in Ethernet networking, does the Ethernet capability bypass the USB incompatibility problem, or will the problem remain?
Posted on Mar 10, 2008
How do I install print shop 3.5 on Vista Home?
Insert the disc into the DVD drive in your computer. The installation should begin automatically or give a pop-up asking you what you would like to do. Select Run Setup.exe. Note: If the installation does not begin automatically follow these steps: Click on Start. Click on My Computer (Computer on Windows Vista and Windows 7) Right Click on the DVD drive containing The Print Shop 3.5 disc. Left Click on Open. Double Left Click on Setup.exe. The installer will now search your computer to make sure you have the required Windows Updates in order to install The Print Shop 3.5. If it detects that you are missing an update the installer will prompt you to install these now. Once the updates are complete the installer will move to the next step automatically. From here you should follow the on screen prompts to complete the installation.
Feb 12, 2015 | Encore The Print Shop 3. 0 Deluxe for...
How to turn on wifi
Configuring the optional internal wireless print server
If you purchased the optional internal wireless print server after your printer was already set up, follow these steps:
1 Install the internal wireless print server into the printer. For more information, see "Installing an optional internal
wireless print server" in the "Setting up the printer" chapter.
2 Click Start Programs or All Programs Lexmark 3500-4500 Series.
3 Click Wireless Setup.
4 Click Start.
5 Follow the instructions on the computer screen.
6 Click Finish to complete the installation.
Also here is the link to the setup guide and user manual
click here
configuring the wireless is in the setup guide
Oct 18, 2010 | Lexmark X3550 All-In-One Printer
SCSI hard disk is not detecting in IBM xSeries 346 Server
Hi
While running the windows 2003 setup (winnt.exe), it will ask for SASI driver, you have to add the scsi driver... then windows 2003 os will detect the HDD.. then it will install..
Apr 07, 2009 | IBM eServer xSeries 346
Linksys WPSM54G No Device
Do a reset on the print server. To do this, hold in the reset button on the back, unplug, then plug in and continue to hold for 10 seconds. Your setup should now detect the print server
Nov 11, 2008 | Linksys Wireless-G WPS54G Print Server
D-Link DP-301U Print Server
try to do a normal install first. once that works you'll be able to use the driver that is installed to install via the print server.
Jul 30, 2008 | D-Link DP-301U (790069251979) Print Server
Installation wizard does not locate the WPSM54G
hello!
what is the model number of your printer? if your setup cd is not detecting your printserver, try the ff:
-- while pc and printserver connected to the router and your printserver connected to your printer. try to reset the printserver for 30sec. Is it printing? If yes, do you see any IP address on the print out
-- If no, unplug the power for 5 seconds and plug the power back in of the printserver then try again to run the setup cd. you may also check your routers dhcp server table if its detecting the printserver
-- if printserver still not detected ty to connect printserver directly to your computer
-- search if you have bi admin utility on your setup cd and install it on your pc
-- manually assign static ip address on the printserver using the bi admin utility and on the pc
-- if successful, connect printserver and pc back to the router and check if you can ping the ip address of your printserver
May 01, 2008 | Linksys WPSM54G Print Server
Wireless G print server Model # WPSM54G
Reset the Wireless print server , and run the setup cd once and check..press the hold the reset button for 60 sec with the power cable connected , that would properly reset your print server and then try to install it..contact linksys support for live assistance over phone 1800-546-5797
Jan 21, 2008 | D-Link DI 514 Wireless Router (DI-514)
3 com 3crwps10075
Don't know if you have fixed the problem, but one solution is to turn off the Windows Firewall.
Jan 13, 2008 | 3Com OfficeConnect Wireless...
Zonet ZPS1001 can't detect Konica Minolta Magicolor 2400W
Persever. Change your usb points, and at the last resort get the cord from your old printer and use this type of connection. Go slowly thorugh the disc step by step and make sure you delete any previous installations of the print file in the control panel.
Oct 28, 2007 | Zonet 1-Port USB 2.0 10/100 Mbps Print...
Windows Server wont load
You need to install the raid drivers during the OS installation otherwise the setup program will not recognise it. At the beginning of the setup, just after the black screen disappears and the setup screen appears, it will say at the bottom: "Press F6 if you want to install third party RAID / SCSI drivers" or something along those lines. That's where you dive for the F6 button and install the drivers from floppy disk. I'm sure you know where to get the drivers from, if not, do reply and ask. Good luck!
Aug 31, 2007 | Celestica A8440 Server
NetGear WIRELESS PRINT SERVER 54MBPS W/4PORT SWITCH (WGPS606NA) Print Server Logo
883 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
