Question about Bosch 23 in. SHU 8805 Built-in Dishwasher
Bosch shu9905 the wife **ticed water level was **t emptying...thought i left dishwasher on ...so continued and then ** water was coming out and burn smell ..did a test and the scrub wash lite = water filling fault (over or under filling)
    Novelist:
  • 131 Answers
Check the drain pump. First, manually initiate drain by pressing the second and fourth buttons on the keypad at the same time. If it pumps out, disregard the rest. If it doesn't at least hum, check for power at the motor.
Remove lower rack, lower spray arm, and screens in bottom, remove all water inside. Check for debris under pump cover in bottom of sump. The drain pump suction is through the hole on the left.
Behind the toe panel on the left is the drain motor, If no debris was found inside, the drain pump may have failed. Remove outer door panel (you may need to remove the two screws on the sides of the control panel.) Remove the metal panel across the top of the motor area , disconnect hose in front of pump, disconnect wires to pump, press tab at top of pump and rotate clockwise to remove pump. The impeller could be loose on the motor shaft, or the motor windings failed.
Posted on Mar 10, 2008
Water not emptying
check if the dishwasher is level. designed to drain correctly under level conditions.
Apr 21, 2012 | Bosch Dishwashers
How do you check for error codes on a Bosch SHY56A05UC/23 Dishwasher? My dishwasher runs continuously in the drain mode and the "cancel drain" feature does not work.
what is happenig i believe and has happened to me 2 times is that the water level float that is on the left side of dishwasher is stuck.
Either remove side panel and flick lever or pull dishwasher out and tap lower portion of panel and this will cause the level to move and then see hat happens
Jan 29, 2011 | Bosch 24 in. SHY56A05 Stainless Steel...
I need a user's manual for SGS5302 bosch dishwasher. Otherwise would you tell me exactly how the aquastop works? Is there any method to bridge it? What goes on the wires? Signals from or to the...
Please rate this solution if you find it helpful. Thanks!
The Aqua-Stop function is a flood protection feature. You really don't want to be "bridging it"!
It works by using a float switch to detect when the water level gets too high in the wash compartment. It over-rides any wash programme and starts the pump to empty the water out.
Also if water leaks into the bottom of the dishwasher (under the washing compartment) the float will rise with the water level and when it reaches a critical point, it will over-ride any washing programme and run the pump.
However, the pump cannot remove water from under the washing compartment, but as it over-rides the wash programme, it prevents the washer from continuing with any wash cycle, thus preventing any more water from leaking into the bottom of the washer and flooding your house.
For this reason, you should never attempt to "bridge" (whatever that means) modify or disable the aqua-stop feature. If it's been activated, you have a problem which needs to be resolved before you continue to use the washer.
Here is a direct link for downloading your manual from Bosch (free):
http://www.bosch-home.co.uk/quick-links/customer-service/download-product-manuals.html
Oct 16, 2010 | Dishwashers
Bosch SGS5332GB dishwasher. drain pump runs all the time
There is a float under the machine that tells the pump to shut off. If the float is stuck or bad, the machine will keep draining. I am including a web site that might help. Bosch Dishwasher That Will Not Stop Draining Hunker
Nov 06, 2017 | Bosch Dishwashers
Bosch Dishwasher continuous fill/drain
Have same problem with 2 second cycling. I resolder at the point of heater relay. Thought I had solved the problem of running forever on 1. Now have this "new" problem that you have described.
Nov 11, 2009 | Bosch SHU5315UC Dishwasher
Bosch dishwasher not taking in water
May be open circuit water valve. Appliance will go to error mode if water level has not reached a certain height after a preset time. Check coil continuity with a multi meter. Should be looking for about 200 ohms.
Nov 11, 2008 | Bosch 24 in. SHU5305UC Built-in Dishwasher
My bosch exxcel dishwasher will not drain after wash cycle
That is because the water level switch activated by the floating sensor is stuck.
You probably need to have the water level switch replaced.
You can find parts on websites below:
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
May 26, 2008 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Bosch milliniem shu9905
call tech support
Mar 11, 2008 | Dishwashers
Bosch 23 in. SHU 8805 Built-in Dishwasher Logo
422 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
