Question about Philips 15PF9925 15 in. LCD EDTV
Philips tv model 15pf9925/17s
I pressed the av button on the television, and **w, I have a black screen. When I press the power button, the light is red, and the monitor is black. I have called tech support, but they could **t help. I have pressed all the buttons on the front several times, but ** help.
SOURCE: Red Light Flashes and monitor won't come on
Philips 42FD9934/17S Red Light Flashes (monitor won't come on).
For a while I could unplug the monitor and after several tries it would come on. Now it will not start. Would like info on what part(s) should be replaced and where to get them.
Posted on Mar 21, 2008
SOURCE: Phillips 42FD9954 plasma will not turn ON
I have a Phillips 42FD9954/17S and every time I try to turn it on I also get the power red light blinking and sometimes it will try to turn on with a bunch of clicking noises and it will be green for a while then turn red. What I do and its very weird but works, put a blow dryer on hot and blow it under the tv on the side of the power button for about 10 minutes and it will turn on. I took it apart and there is a heat sink that if i put the blow dryer directly onto it on heat it turns on in less than a minute. Can someone tell me how I can fix this heat sink? I cant take it off. I want to put some thermal compound to see if that works. Give it a try I promise it will work. The Red Light has to be on put the heat on it and then press the power button, if you hear it clicking and green then back to red you are almost there. Keep putting heat on it and it will turn on.
Posted on Mar 31, 2009
  • 128 Answers
SOURCE: My tv keeps reverting to the Philips TV Menu
If that TV has a 'menu' button on the front of the set, make sure nothing like coca-cola has spilled into where that switch is located. I would try a different remote in case the remote is getting flaky....
Posted on Oct 22, 2009
  • 8457 Answers
SOURCE: Philips 42PF9631D 42 in. Plasma Television
Philip have alot power problems with their tv.Check power board for puff up parts like Capacitors,or rust in cracks or soldering.Changes parts or the whole power board.
Posted on Jan 08, 2010
SOURCE: Dear recipient. I have a
I just posted a similar issue with a similar model television and he said it might just need a new inverter...
Posted on Jan 27, 2011
My 42 inch philips (42PFP5532D) has blank screen but blue light to show its on but nothing on screen :(
just let me know if their is a sound when you turn on the tv then the only problem is black screen. if you can get sound tried to press the channel up/down button let see if you can get a channel. if you hear that receive channel that was mean the problem is either the screen back light get busted or the power inverter is defective. hope this can help good luck.
Nov 02, 2012 | Televison & Video
Monitor goes black - green light stays on
My screen is black, why do I not have a picture?
Answer Antenna is not hooked up to television.
  • Make sure that the antenna cable is correctly connected to the television. If it doesn't work there appears to be no signal.
Problem is caused by television broadcast
  1. Push 'INFO' button.
  2. If the screen shows channel number (1, 2, 3, etc) try another channel. Not all channels broadcast at all times.
  3. You may have a signal problem. Contact cable provider or local broadcaster regarding the specific channel.
Television is in EXT or SIDE mode, and there is no external source provided, so screen mute (black screen) is activated.
  1. Push NEXT SOURCE button on the remote.
  2. On the screen appears all sorces.
  3. Press the UP button to switch to the TV mode.
If you are using an accessory device (DVD, DVR, or VCR), be sure the device is on and running.
Blank screen when connecting to the accessory (DVD, STB, PC) device via HDMI to HDMI.
Answer
  • Make sure the cable is well connected .
  • To check which connection is selected, Press the i+ button on the remote control.
  1. When you see Blue mute / blank screen and the i+ display does not indicate any video resolution indication then there is no valid signal detected.
    • Make sure the HDMI output of the accessory is valid by changing the video output resolution to a resolution which the TV can handle.
  2. When you see a blank screen and the i+ display shows a video resolution indication then the connection is correct.
    • The blank screen is caused by the accessory device and not by the TV.
    • To detect and remedy the problem caused by the accessory device, check the instruction manual of this device.
  3. If the problem remains : reselect the HDMI external source input by changing to the other HDMI input and back to the connected HDMI :
    1. Press AV on the remote
    2. Press up and then ok
    3. Press AV again
    4. Press down and ok
    5. The compatibility check process between TV and accessory device will start over again.
  4. Reset (switch off and back on) the TV and also reset the accessory device.
Mar 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
Sony Bravia KLV-40X250A power indicator blinks once but screen is black
um u should turn your tv off for like 10 minutes , i think yourr tv is a internet tv so let it cool sometimes sony internet tvs freeze with black screen so try it out.
good luck :)
Aug 06, 2012 | Televison & Video
I have problem with our Magnavox TR2510C101. My toddler press everything and now it turns out there is black screen (square) cover the image. Do you know how to fix it? thanks!
You have accidentally gotten the Closed Caption turned on....
Here is how to turn it off....
1) Press the MENU button either on the front of the TV or on the original TV remote.
2) Use the Volume + or Volume - to highlight "SET"
3) Use Channel - or Channel + to highlight "CLOSED CAPTION"
4) Press Volume + to access the CLOSED CAPTION menu.
5) Press Channel - or Channel + until OFF is highlighted.
6) Press Volume + or Volume - to confirm selection.
7) Press the TV/AV/EXIT button on the remote to exit or the MENU button on the front of the TV.
GOOD LUCK and please rate this solution...
Jan 14, 2010 | Philips Magnavox 27MS343S 27" TV
My Philips plasma only shows half the screen. The other half is just blacked out.
This model has PiP (Picture In Picture), find the button on the remote or check manual, this mode is most likely turned on and is being shared with one of the AV channels, or try turning on a plugged in SCART device to see if this picture shows on the other half of screen.
Sep 14, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
Help unlock child lock on tv.
The solution is so simple!
Press the POWER (RED) button and the TV/AV button simultaneously - hey presto! the child lock will switch off and you will have your TV back working properly.
May 29, 2009 | Philips Magnavox 27MS343S 27" TV
Universal remote works for basics but won't change input
Rich,
good day , what button can you see infront of your TV screen?
Not familiar with this model but if you'll manage to locate a button marked as "TV/AV" or "AV" press this button until it the display switch to A/V mode (audio/video). Or if this is a really old model, from Tuner mode or channel model. set the channel station to 1 then press the " - channel " button and see if it will change from tuner mode to A/V mode
cheers,
mark
Jan 31, 2009 | Toshiba 32A33 32" TV
Screen is dark
AV/TV Button
Press ¡° AV/TV¡± button,the will be some word show on the right top
of the screen, press ¡° PROG+/-¡± to select the AV source, and then
press ¡° VOL+/-¡±to enter AV mode.
TV
PC
SCART
http://www.denver-electronics.com/UploadetFiles/154/25/DFT-1504_Black_English.pdf
The Tv is starting or going into PC mode Or scart mode set to TV mode. Hope this helps Please rate me. The link is to all of the setting for the TV. Blue light is pc led.
Dec 21, 2008 | Hisense LCD1504 15 in. Television
CHILD LOCK LOCKED!!
1 Press MENU to show the on-screen
menu.
2 Press VOL+ or VOL- repeatedly until
SET is highlighted.
3 Press CH+ or CH- to highlight CHILD
LOCK.
4 Press VOL+ or VOL-
to choose ON or
OFF.
Choose ON to disable all the buttons on
the front of the TV. CHILD LOCK ON
will appear briefly on the TV screen each
time you press a button on the front of
the TV.
You can still operate the TV with the
remote control.You can still use the
POWER button on the front of the TV,
but only to turn off the TV (not on).
Set CHILD LOCK to OFF to cancel this
feature so you can use the buttons on
the front of the TV again.
5 Press TV/AV/EXIT to remove the
menu from the screen.
Jun 06, 2008 | Philips Magnavox 27MS343S 27" TV
Philips 15PF9925 15 in. LCD EDTV Logo
318 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
