Question about SanDisk Sansa e200 MP3 Player
Can't turn on my MP3
I Can't turn on my Sansa MP3.When I hold the power button on the screen Load Main Image failed Switch to recovery mode appears. What do I do?
    Novelist:
  • 141 Answers
1-866-726-3475 Sandisk Customer Support
www.sandisk.com
click on support at the top; click on MP3 players,
find your Sansa and click on it there’s a lot of info
Posted on Mar 27, 2008
Sansa 260 R load main image failed message
The Sansa e260 Rhapsody could be recovered by resetting the player.
How to reset the player :
1. Player switched on.
2. Press and hold the power button for approximately 30 seconds.
3. Put the player back on.
When the fault is not resolved a firmware update / reinstallation needs to be made. There are 2 steps needed for getting new firmware on the player.
Step 1: switching the player into recovery mode / MSC mode
1. Turn off the player.
2. Slide the Hold/Lock switch on top of the player so an orange color is showing.
3. Press and hold the REC button and connect the device to the computer.
4. A message will appear on the device display screen confirming the connection and a memory partition will be viewable in My Computer.
5. Release the REC button.
Step 2: Update the firmware ( updating firmware always in MSC mode, see Step 1 )
Use next link for updating the firmware:
http://kb.sandisk.com/app/answers/detail/a_id/306
The Sansa updater installation on the computer should be the easiest way to update firmware.
Need more help ? Just post a comment.
Dec 17, 2009 | SanDisk Sansa e260 MP3 Player
My screen is black
Download the Sansa Recovery Tool for the Sansa e200 series and run the official Sansa Recovery Mode
or
Run Windows Recovery Mode
Try this: disconnect the player from the computer, turn it off, hold in the REC button, and reconnect the player to the computer while holding the REC button in. Keep holding the REC button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
-Tha Mp3 Doctor
Mar 16, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e200 load main image failed
If this happened after updating your firmware, the Sansa FAQ from here http://www.sansa.com/support/sansa_e200/faqs says try this -
03. "Load image failed" appears after updating e200 firmware Applies to the following Operating Systems:
  1. Windows XP, Vista
This error may be caused by the firmware failing to load or the file system is corrupted.
STEP 1 – Reset the player
  1. Press and hold the Power button for approximately 30 seconds.
  2. Turn the player back on.
If the error persists, proceed to steps 2 and 3.
STEP 2 – Connect the player in Recovery Mode
  4. A message will appear on the device display screen confirming the connection and a 16MB partition will be viewable in My Computer.
STEP 3 – Download and update the firmware
  1. Download the firmware from the Sansa Forum.
  2. Open the zip file
  3. Extract all the firmware files to the 16MB-FORMAT drive.
  4. Disconnect the player.
  5. Slide the Hold switch to the unlock position.
  6. Turn on the player
Dec 29, 2008 | SanDisk Sansa e200 MP3 Player
Sansa player wont turn on
To get it in recovery mode. Put the Hold switch into the lock position. Then hold REC and Power for about 10 seconds.
You need to hook up your cable after that and you can reset the firmware.
Nov 17, 2008 | SanDisk Sansa e200 MP3 Player
Load main image failed switch to recovery mode
follow the above steps but turn on the power button if nothing is happening. It's the only way I got my e280 to recovery mode
Sep 23, 2008 | SanDisk Sansa E280 MP3 Player
Problem starting
Get the Sansa Recovery Tool from the sandisk website
Jun 28, 2008 | SanDisk Sansa e270 MP3 Player
Recovery mode
a back door to recover the system With the power off, switch hold to on (and leave it on) and press and hold the record button on the left side. Now turn on your Sansa while still holding the record button. The unit will power up in recovery mode. Now connect to your PC. A folder 16mbFORMAT will appear under 'My Computer'. Call SanDisk technical support for the most up to date firmware files.1-866-SanDisk
Mar 17, 2008 | SanDisk Sansa e250 MP3 Player
My sansa e250 ask me this
Solution:
1. Put Lock on.
2. Push and Hold Both Rec and Power buttons while the power is off.
Then message should show saying: " Welcome to Recovery Mode"
Sansa e260
You need to do the following:
1. Go to recovery mode by setting the hold mode to hold ,then press record button and power/menu button.
2. Connect to computer with USB cable as per meassage on sansa
3.Download an mi4 file from http://daniel.haxx.se/sansa/mi4.html for your model
4. copy this mi4 file to the 16MB partition that appears for your sansa.
5. Disconnect then power down and on again.
Jan 17, 2008 | SanDisk Sansa e250 MP3 Player
My Sansa e280 forze
Try plugging the player into the computer and formatting it. This will erase the music from the player, but you have a copy of the music on your computer as well. I think this will solve your problem.
Good luck.
Nov 08, 2007 | SanDisk Sansa E280 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
47 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
