Question about Sharp EL-2196BL Calculator
Setting time & Date
How do I set the time & date on a Sharp calculator Model (EL-2196BL)
  • Anonymous Mar 21, 2008
    HOW DO I CHANGE THE TIME AND DATE
I copied this from another post & it worked for me:
To enter the date
1. Be sure to switch to "rate set" from GT
2. Enter the month
3. Press the decimal point
4. Enter the day
5. Press the decimal point
6. Enter the year
Example 3.09.2007
7. Press the button that look like a clock/calendar
To enter the time
2. Enter the hour (please use military time)
4. Enter the minutes
Example: 13.24 or 9.24
5. Press the button that look like a clock/calendar
Then change the "rate set" back to the GT setting.
Posted on Mar 24, 2008
Sharp el-2630piii calculator setting to two decimal points
Slide the "F 6 3 2 1 0" switch to the "2" position.
Feb 28, 2013 | Sharp EL-2196BL Calculator
We have a SHARP EL-2196BL printing calculator, but no user manual. We can't get it to print the answer when we are adding. It shows on the screen, but not the paper. Also, it just keeps adding up...
You can download the manual from the manufacturer's web site at
http://files.sharpusa.com/Downloads/ForHome/HomeOffice/Calculators/Manuals/cal_man_EL2196BL.pdf
Feb 26, 2011 | Sharp EL-2196BL Calculator
HOW CAN I SET THE DATE ON MY SHARP EL 1750 PIII CALCULATOR
Here is a users manual for your calculator which explains the date and time setting process.
http://www.fixya.com/support/p193843-sharp_el_1750piii_calculator/manual-5324#
I hope this helps you.
Jul 08, 2010 | Sharp EL-1750PIII Calculator
HOW DO I SET THE TAX ON THE SHARP EL-2196BL?
You can get the manual on link below it will tell you how to set the tax.
http://dl.owneriq.net/2/2f5de9b8-0a25-e1f4-d9c2-132001ba18e5.pdf
Good luck and please rate 4 thumbs for the free answer
Mar 12, 2010 | Sharp EL-2196BL Calculator
HOW DO I CHANGE THE DATE AND TIME?
Only the EL-1197PIII has time and date settings, so I assume you own this model. A link to the manual is here: http://www.sharpusa.com/~/media/96B576A9DADF49A0B1321B57CAB1741D.ashx
You can find the time and date set up process on the first page, 3rd column, 2nd paragraph, under the headline GRAND TOTAL/RATE SETTING MODE SELECTOR.
Feb 11, 2010 | Sharp EL-1197P Calculator
Setting the time and date
To set the date, make sure that you are in Rate Set. type in the date such as August 3, 2010 would be entered as 08.03.2010 then press the date time key. This will set the date. To set the time type in the time such as 4:20 PM would be entered as 16.20 then press the date time key and this will set the time.
Feb 02, 2010 | Sharp EL-1197PIII Calculator
How do you reset the date and time
Below are the steps to assist you in
setting the Date and Time on your calculator.
NOTE: The "Time Set", "AM/PM", "12/24" and "Format" associated keys are
on the faceplate above the respective key. Position the calculator so
that you can look directly over the keypad to see the notations.
Setting the date:
1. Press the CALENDAR/CLOCK Key. The default date will appear.
2. Hold the TIME SET key down for 3 seconds or until you see the first
digit begin to blink in the display.
3. Input the correct date.
4. Firmly press and release the TIME SET key. The first digit should
stop blinking and the date is then set.
Setting the time:
1. Press the CALENDAR/CLOCK key. The default time will appear.
NOTE: The seconds will disappear.
3. Input the correct time. If you need to adjust to AM or PM, press
the AM/PM accordingly.
stop blinking and the time is then set. The seconds will again be
displayed.
Follow by pressing the CLEAR key to return to the calculator mode. To
return to either the TIME or DATE, press the CALENDAR/CLOCK key to
toggle between them.
Jan 29, 2010 | Sharp EL-2196BL Calculator
Want to replace ink roller on Sharp EL-2196BL -
http://www.gorillapaper.com/univ-cal-spool-br-12-per-box.html
Universal Calculator Spool 12pk
Thank you
Oct 08, 2009 | Sharp EL-2196BL Calculator
Setting correct date
You may download a copy of the manual here. The clock setting instructions are in the middle of the first page.
Sep 02, 2009 | Sharp EL-1197PIII Calculator
Sharp EL-2196BL Calculator Logo
1,846 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
