Question about Sony KP-53S65 53" Rear Projection Television
I HAVE A SONY KP-53S65 PROJECTION TV AND I HAVE NO PICTURE OR SOUND. THE POWER STAND-BY LIGHT BLINKS BUT NOTHING ELSE COMES ON. I HAVE READ THE MANUAL WITH NO RESULTS. COULD IT BE THE LAMP? IF SO WHERE DO I FIND THE LAMP AND HOW DO I CHANGE IT? TKS
  • 15 Answers
A lot of times when that problem happens, its most likely not the lamp, when the lamp is the issue you can still hear a sound on your TV but no picture, most likely where looking at a problem with your power supply board or ballast, there might be something wrong with them that keeps from sending voltage to the lamp and audio parts, but on the other hand if you wish to change your lamp, depending on the model it can be on the back or sides of the TV, there is a little door with 4 screws that leads to the housing where the lamp is, you just need to pull out the housing and take it apart, its a actually a very easy task, you can have it done in like 5 min. an easier way is to purchase the whole lamp with the housing and just pull the old one and insert the new one in, less than 5 min!! If you have any other question don't hesitate on asking.
Posted on Mar 16, 2010
Testimonial: "TKS FOR YOUR ASSISTANCE."
    Problem Solver:
  • 6 Answers
A common problem with this particular model is capacitor c514 tends to over heat and fry out. if you look at your board in the back of the tv it might even be charred a little. its a 390 micro-farad 2000V blue cap. and the transistor mounted on the heat-sink next to it labeled "D2348", also goes bad. Replace those 2 components and it'll solve your problem. I am not responsible for any damage done to your tv or if you get shocked. These repairs should be made by someone with experience or a tech.
hope that helps.
Posted on Jun 01, 2010
If adjustments didn't work, try checking the supply volts to the convergence board. I have come across some with overheated low ohm (typically 4 ohms) in approx 24v supply line.(Look for a burnt resistor or PCB). If it has volts one side, and none on the other, it's open circuit.
Posted on Mar 17, 2010
Testimonial: "Tks for the suggestion I will look into it."
  • 90 Answers
There is no Lamp in a KP-53S65. You could have a bad High Voltage Transformer (flyback) or just replace the Power/Deflection Board.
Posted on Apr 19, 2010
SOURCE:
The tv has no power its a sony kp-53s65 no light or nothing
hello you may to check the glass fuse inside the tv it will be in the power supply if it's black in colour it's blown make sure you put in the same rated fuse back in the value will be at the end of the fuse or on the fuse holder on the power supply board but beware if it blows again then you have a dead short inside the tv someware good luck
regards
shaun
Jul 29, 2010 | Sony KP-53S65 53" Rear Projection...
Sony KP-41T65
is there a cadence to the blinking timer light?
Jul 17, 2009 | Sony KP-41T65 41" Rear Projection...
Tv screen will not stop blinking
It sounds definitely like a faulty power connection via the video cable from the inside. If it blinks a while then turns black then shows the picture, it would have to be that it's not screwed on properly, thus taking more time for it to get a full charge and then properly function. If you still have the warranty, any electric repair/retailer shop can fix it for you.
May 04, 2009 | Sony KP-53S65 53" Rear Projection...
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony KP-53S63 problem
how many blinks pause then blink?
Mar 17, 2008 | Sony KP-53S65 53" Rear Projection...
Sony kp-53s65
i have a sound no picture
Aug 07, 2007 | Sony KP-53S65 53" Rear Projection...
Cant fix my sony KP-53S65
If the TV will not turn on and the red light blinks on the front of the set, it means that the microprocessor has detected a problem in the set and shut the set down. It then blinks the red light a certain number of times, and the number of blinks is the code for why the set has shut off. How many times does the red light blink before repeating?
Standby timer light blinking, tv will not turn on
Check out Ceramic Capacitor C514 by the horiz. output transistor (burned/shorted?) My question is how do you find the specs of the capacitor and where do you buy one?
Dec 11, 2006 | Sony KP-53S65 53" Rear Projection...
Sony KP-53S65 53" Rear Projection Television Logo
1,150 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
