Question about HP Pavilion A730N (PJ510AA) PC Desktop
Front panel Nothing on the front panel works...ie...USB plug ins,cd rom, sd smart card, microphone plug in jack, printer not reading or working from CPU either. Puzzled in TX
  • 99 Answers
Go to Bios setup,and choice the default setup.the factory settings,and run the cd driver of your motherboard,so that all the necessary driver will put to your system.
Posted on Mar 10, 2008
Can you play sd card reader in tv
Plug the reader with a sd card install into a USB slot in the back of your tv. Go to input source from tv menu,USB/media should be highlighted.This would only work with a smart TV.
Jan 10, 2015 | Vizio Televison & Video
Front 4 usb ports and microphone and headphone jacks don't work but the rear usb and speaker jacks do work. I've had the computer new since 2009 and they have never worked.
it sounds to me like the wires from the front panel connectors are not connected to the motherboard inside the computer case, open the case up find the front connectors wires inside and find out if there are any connectors on the motherboard to plug them into.
the reason the rear ones work is because they are soldered directly to the motherboard.
good luck.
Jun 28, 2014 | Acer Aspire E380 ASE380-UD500A PC Desktop
I can't find where my microphone goes
Is your computer a laptop or a desktop? How old is it? Which make/model of computer do you have?
For an older desktop, the microphone input will be on the back of the computer. There are usually three 3.5 mm jacks for audio connections. The pink connector is for the microphone. The black connector is for Line In and the green is line out (speakers). Often they are towards the far side of the motherboard connections from any PS2 (keyboard and mouse) ports. Otherwise, they will line up with one of the card slots.
Newer desktop computers often have additional audio ports for surround sound. However, the pink jack for the microphone is standard. If the computer has front audio ports, you may find that the same color labels the jacks. Otherwise look closely at the icons next to the ports. These will be in addition to the back audio ports.
Laptops can have the audio ports on the front, back or side depending on the model. There will be a small icon with a stand microphone indicated for the microphone port.
If you have one of the newer USB microphones, plug it into an available USB port.
If the computer has no working audio ports, either get a USB microphone or add a sound card.
I hope this helps. If you add a comment with your computer's brand and model number, I'll try to provide the exact audio port details. (There are some computer motherboards that do not have on-board audio and you will need a sound card.)
(on Windows computers, you may have to change the default audio input. Click Start > Control Panel > Hardware and Sound > Sound > Manage Audio Devices. (for Windows 7) For other versions of Windows, you may find slightly different titles in the Control Panel.)
Jun 24, 2011 | Compaq PC Microphone (Black or Beige)...
Does DELL Inspiron 6400 has a inbuilt microphone? If it does how to make it work?
I am sorry to say but, the 6400/E1505 does not have an internal mic. You need External. Sorry. Specs only show a MIC connection. I/O Ports IEEE 1394 4-USB 2.0 (Universal Serial Bus) compliant 4-pin connectors Flash Memory Slot - Secure Digital (SD) and SD/IO compliant 5-in-1 Combo Card connector - reads MS, MS Pro, SD/SDIO, MMC, xD CD type I/II, & IBM Microdrive through ExpressCard adapter Video: 15-pin monitor connector S-Video: 7-pin mini-DIN connector Audio jacks: Stereo headphones/speakers mini-connector (same as line-out), microphone mini-connector
Dec 09, 2010 | Dell Inspiron 6400 Notebook
No telephone service
Hi, I checked the specs for this pc and it only has a Ethernet port. See specs below.
Specifications CPU1 : AMD Athlon™ II X2 dual-core processor 235e
(2.7GHz, 2MB L2 cache) Operating System2 : Genuine Windows® 7 Home Premium 64-bit Chipset : NVIDIA® GeForce® 6150 SE Memory3 : 6144MB DDR2 dual-channel (2 × 1024MB + 2 × 2048MB)
Expandable to 8GB
4 DDR2 slots (total), 0 DDR2 slot (available) Hard Drive4 : 750GB 7200rpm SATA Optical Drive : 16x DVD±R/RW Supermulti drive
Write max: 16x DVD±R, 6x DVD-RW, 8x DVD+RW, 8x DVD±R DL, 5x DVD-RAM, 48x CD-R, 32x CD-RW
Read max: 16x DVD-ROM, 40x CD-ROM Media Reader5 : Multi-in-one digital media card reader
CompactFlash® I & II, CF+ Microdrive, Secure Digital™ (SD) Card, miniSD™ Card, MultiMediaCard™ (MMC), MMCmobile™, MMCmicro™, Reduced-Size MultiMediaCard™ (RS-MMC), xD-Picture Card™, Memory Stick®, Memory Stick PRO™, Memory Stick Duo™, Memory Stick PRO Duo™, Memory Stick Micro™ Video : Integrated NVIDIA® GeForce® 6150 SE graphics Audio : 8-channel (7.1) high-definition audio
USB Speakers Communications : 10/100 Ethernet LAN (RJ-45 port) Peripherals : eMachines® PS/2 keyboard and optical mouse Ports/Other : 6 - USB 2.0 (2 front, 4 rear)
2 - PS/2 (keyboard and mouse)
1 - VGA
6 - Audio jacks
1 - Headphone jack
1 - Microphone jack
1 - RJ-45 Ethernet Dimensions : 14.2" H x 7.1" W x 16.2" D Weight : 18 lbs. (system unit only) Warranty6 : 1-year parts and labor limited warranty with toll-free tech support Software :
  • Genuine Windows® 7 Home Premium 64-bit
  • Adobe® Flash® Player
  • Adobe® Reader®
  • eMachines® Recovery Management
  • Google Toolbar™
  • Microsoft Office Home and Student 2007 (60-day complimentary trial period)7
  • Microsoft Works® 9.0
  • Nero® 9 Essentials
  • Norton Internet Security™ 20098
  • WildTangent® demo games
http://www.emachines.com/products/products.html?prod=ET1331G-03w
Here's a quick and easy solution to their problem buy a usb external 56k dial up modem.
721f40f.jpgHere's the link to buy it.
http://www.google.com/products/catalog?sourceid=navclient&rlz=1T4ADFA_enUS363US363&q=external+modem+for+dial+up&um=1&ie=UTF-8&cid=5167627218834893159&ei=RPRnS8-JFIrEsQOC8OT3BA&sa=X&oi=product_catalog_result&ct=result&resnum=3&ved=0CCYQ8wIwAg#ps-sellers
Let me know how it went.
WBTech
Feb 02, 2010 | Computers & Internet
Open the back of tascam gtr1 to fix the input jack
0. If available, use grounding wristing band to prevent ESD damage.
1. Remove SD card and battery.
2. Remove 2 screws in battery compartment.
3. Slide back panel upward towards top of unit and it snaps off.
4. To remove front panel, gently pry two tabs at top between microphones and front panel pops off (jog dial and washer will also pop off).
5. Microphone jumpers must be disconnected from PCB headers to completely remove top panel. (Note: guitar jack solder pins are accessible without removing microphone jumpers, may be able to re-solder directly. )
Jan 01, 2010 | Tascam Audio Players & Recorders
I only get audio sound out of one speaker using my lambda
the mic. cord that is in it you might need to twist and push in harder
Feb 11, 2009 | Lexicon Lambda Usb Desktop Recording...
HP Pavilion A730N (PJ510AA) PC Desktop Logo
70 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
