Question about Audiovox VM9311TS
Grounding the bypass parking switch for vm9311ts
What if you connect it to the black wire and it still doesnt work..
  • 3 Answers
This is a newer product.You can't just ground that orange cable like the older modles.I posted a solution somewhere here on the forum.
Posted on Apr 07, 2008
Emergency parking wire for jensen vm9311ts
your parking brake wire from radio is pink .
1 take a toggle switch 12 volt dc and 20 amps
2 take the pink wire attach the wire to the top terminal of the toggle switch
3 take the bottom terminal and attach a black wire to it and ground the other side of wire you must have a good ground ...
then once this is done test the switch turn on dvd it a video and flip the switch up and down a couple of time to simulate the parking brake and the video should work ...
if this doesnt work email me and ill give you the relay diagram to connect a relay inline to activate video but im pretty sure it will ...
http://www.tintingbyfredjohnson.com go here to my online store and email me from contacts
Dec 28, 2010 | Jensen Car Audio & Video
Parking brake safety bypass
If you have the old firmware then all you need to do is ground the parking brake wire
if you have the new firmware(just bought the system) a toggle switch is involved:
1 - connect e-brake wire from dvd unit to the switch
2 - connect a ground wire from switch to the unit chassis(any good metal grounding surface will do)
3 - pop in a dvd, toggle the switch back and forth 2 or 3 times depending on what wire you placed where...and voilaa!! your dvd system should work in motion!!
Jun 26, 2009 | Jensen VM9510 Car DVD Player
Lanzar not playing dvd's says parking brake
what you need is a toggle switch...
put the switch between the parking brake wire, and actual ground,
the black wire will work, just extend the wire so the toggle switch is
accessible, once you do that turn your indash on,
slap a dvd in it, then once it displays the parking brake message,
hit your toggle switch once, if it doesnt get it,
try it multiple times but with a second between clicks,
that should do it and please keep the eyes on the road. :]
Jun 22, 2009 | Lanzar SD4MU Car Video Player
Difficulties in installin of VM9311TS
just by pass it with the bypass code
May 04, 2009 | Audiovox VM9311TS
Park brake bypass via switch to ground
no just ground it out on this radio you dont need a sequence just ground it out with the black wire it will work fine
Jun 24, 2008 | Kenwood Excelon KVT815DVD Car DVD Player
Jvc KDAVX44 install issue
Try grounding the parking brake wire instead of attaching it. Should bypass brake requirement for video but really should effect powering on
May 10, 2008 | JVC Car Audio & Video
How do i bypass the parking brake switch in order for my video to play
hook the pink wire to a toggle switch and ground the switch to the chassis. when the unlawfull screen comes on then turn the switch on for a few seconds then back off for a few seconds then back on and the screen should go away. I done this with mine and it works. unfortunately you have to do this every time.
Feb 23, 2008 | Audiovox VM9311TS
Parking Brake wire on Jensen VM9311TS
It may need to see a Positive....not a ground (the brake wire rests at ground and goes positive when the pedal is pressed). but to answer your question, the brake wire for your car is Light Green and is at the brake switch above the pedal.
Sep 19, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
I doesn't work
the black box may be the very thing to protect your unit from harsh electrical environment such as coil back emf which can send much higher volts than 12 to the unit. it may be possible that the unit has been zapped and killed the video section. try installing in another car or even on the bench with a car battery.
Jun 04, 2007 | Jensen VM9510 Car DVD Player
Audiovox VM9311TS Logo
115 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
