Question about Dryers
Whirlpool Duet Sport Dryer PF code
I've looked up the PF code on this site and people say simple power failure. Most people who explain the problem say this trips the breaker. Mine is not tripping my breaker. It happens when I use timed dry over 30 minutes.
The support guy came out, replaced the control board....did not check temp sensors or anything else. Said if the control board didn't fix it, it would be time to call electrician. I think it's an issue with the dryer. The grate on the back of the dyer (the silver one) looks rusted or scorched and I've had temp issues before. Like I said, it's not tripping the breaker either, the machine is resetting itself. Any ideas?
  • 6 more comments
  • mommaladybug Mar 10, 2008
    They are *supposedly* qualified. They are the name Whirlpool always gives me when i call in for warranty/extended warranty. Then again, not so sure if they are qualified.....they've been out on my duet washer 7 times now and the issues are still unresolved. Fighting for a replacement. Can an overheat cause a power failure? When I do check it if I get a PF right when the cycle ends, it seems super hot.
  • dmarshall05 May 15, 2008
    I'm in the troubleshooting phase, but my same model has the PF code displaying. It is NOT tripping the circuit, but will go back on after pressing Cancel button on control panel. However, we're running on the "Normal" mode (which is defaulted for 35 minutes). I haven't waited at the drying to determine how far into the 35 minutes that the PF code displays. I don't want to call an electrician if the problem is a dryer problem. The dryer was purchased on 3/15/08, so it is virtually new.
  • jeffreym May 21, 2008
    dryer runs for about 20 - 25 mins and then it shuts off and display says f70?
  • cshannon24 Oct 20, 2008
    Bought dryer in Feb 08, within one month I was having the consistent PF without any breaker being tripped, the dryer would shut off and reset itself. My previous dryer worked fine since the condo was built 5 years ago. I had technicians come out numerous times and they replaced the power board three times. Finally Oct 1st I got a replacement...now I'm having the same problem!
    I've had three different electricians come out, the whirlpool repair company tested the lines first before they would replace the dryer. After the new one had the same problem I called an electrician, everything was fine. The next day the whirlpool repair guys A&E Factory Service came out and said there was no power going into the dryer. That same day I had another different electrician come out and he tested everything and said it was fine. I had him replace the outlet regardless.
    I also have noticed a consistent low buzzing noise when the dryer is on or off.
    Has anyone had any luck fixing the problem?
  • bjwollaston Dec 04, 2008
    I have recently started getting the PF error code on my dryer. Model WED8300. Which I purchased in April 2007 along with the matching WTW8300 washer. I've had problems with the washer after about six months. But dryer has worked awesome until about 2 weeks ago. Every couple of loads I notice I'm getting the PF code I just cancel it out and restart. Not sure what is causing that problem. I don't think it is any wiring problem in my house or the circuit breaker cause if it was, I would have to reset the breaker. Has anyone heard of a defect in the machine?
  • Anonymous Jan 08, 2009
    I just bought this washer dryer set and ran the washer once (worked fine) and put the clothes in the dryer only to come down to find the dryer off with the PF on the display. It consistantly goes to PF after only a few minutes. I'm sending them back today for a better set since I'm still within the 7 day period you can exchange
  • jenniferhick Feb 02, 2009
    I'm having the same problem!? So, when is Whirlpool going to realize that there is a problem with the unit? WOW...I've read so many posts on different blogs, and everyone has the same problem, so truly is it really all of our electrical boxes or the unit!? I never had this problem with my first dryer!!!? And I, too, have had my electrical company out to inspect the circuit and all, and they said it was all fine and it had to be the machine. so what next?
  • rob_bennie May 04, 2009
    My dryer has done all of the things these other posts have indicated. I am on dryer number 2 now after the repair man replaced just about every component and circuit board - some twice. Finally he agreed that there must be something funny with that particular dryer and Sears provided me with an new one. Now the new one is failing the same way - We have had it for a grand total of two weeks and it indicates PF every time you try to use it. Our repair man suggested an electrical problem with the ground for our house wiring but I have checked that out and everything is normal. After reading these posts I am convinced it is the dryer. The repairman also suggested getting a universal power supply as the circuitry could be sensitive to power surges. However, my computer isn't shutting off so I don't believe that there have been any power surges at all. Furthermore if the stupid thing is that sensitive to any fluctuation in house voltage it is a huge design flaw. My old dryer worked fine - now I wish I had .kept it instead of "upgrading" to something more energy efficient!
After ranting and raving about similar issues with my own Whirlpool Sport, with no success from a ton of repairs and technicians, I decided to check the exhaust vent from dryer to outside - thinking that the dryer must be sensing an overheating problem to trigger internal shutdowns without tripping the house breaker. Sure enough the vent flap on the outside of the house had become stuck, instead of flipping open when the dryer is working. I fixed the vent flap and the problem was solved. So check all aspects of the venting - a squashed flex hose, stuck or partially closed vent flap, something covering the vent. Sometimes the simplest solutions are the correct ones.
Posted on May 04, 2009
We just had the same problem. have your power company come out and check for a neutral ground problem coming into the house. I know it sounds silly but the machine needs full power. Our machine started doing the same thing the other day. I called the power company and they came out and checked the neutral ground and there was a connectivity problem. the machine would just go to PF during cycle changes. this solved the problem. Had these units for 3 years and this is the first problem but we just moved into a newer house and there you go.
Posted on May 10, 2009
  • 4 Answers
Click here for the answer to your PF problem.
https://sites.google.com/site/duetsportpfpowerfailure/
You can repair it yourself in under an hour and for less then $30.00.
Posted on Apr 19, 2009
Dmarshall05 again:
Two technicians have been out (new guy & experienced guy). First tech didn't take lower panel off, but 2nd tech did and found that drying vent tube (4" tubing) had disconnected. I replaced the rigid vent that came with it to vent to the left side instead of the back. That was 6/3 and today is 6/6 and it hasn't happened since. It was happening every load where it would run 3 minutes and shut off, then cool off for 5 minutes, run for 3 ....
Check you vent tube. I'll post again if this turns out not to be the solution.
Posted on Jun 06, 2008
    President:
  • Dryers Master
  • 2,651 Answers
Yea i would reccomend having a Qualiified Whirlpool tech come out and have a look at that one. PF is def an indication as to a power failure. although ive ***** seen this particular problem on this particular unit.A call to the tech assistance line by the service guy while in home should prove quite helpful.
Posted on Mar 10, 2008
  • Ron Coons
    Ron Coons Mar 10, 2008
    Although quite familliar with this particular product a PF is not a problem ive EVER seen on this particular unit, which would immediatly make me wanna call the tech assistance line. i really dont know passed that.sorry couldn help further. You can request another service company as well you dont need to use the same company, ask if they have anotherservicer for your area
2 Suggested Answers
  • 4 Answers
SOURCE: Whirlpool Duet Sport Dryer PF code
I just posted this webpage that has the answers to your problem.
Posted on Apr 18, 2009
PF code comes on
Check all the wiring to the dryer and even the wires in the wall socket. Sounds like there is a loose wire since you keep getting the power failure (PF) code on the dryer.
Dec 27, 2011 | Whirlpool GGW9868K Gas Dryer
Whirlpool dryer duet sport MOD WED8300SW error message
I have a whirlpool duet sport electric dryer with an error code of F 26.
Mar 02, 2010 | Dryers
Whirlpool duet dryer error code pf
The error code means that the unit suffered from a power failure.just make sure that all the wiring is good there is nothing loose and the circuit breaker is in good shape you should be able to turn off the dryer unplug it for a few minutes and the plug it back in this should clear the fault code.
Feb 26, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a Whirlpool Duet sport dryer that came with the house I bought a year ago so I have no manual. What does it mean when the display says PF? Clothes were dry but display waid PF
The only PF I am aware of means power failure. Try unplugging the unit for awhile then try it again. This may reset the computer.
Feb 14, 2010 | Whirlpool Dryers
Error code pf
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 01, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Dryer kicks off circuit breaker, pf code is on dryer. now won't let me do anything
pf is for power failure. sounds like You may have a short somewhere. Be careful of electric shock.
Apr 21, 2009 | Dryers
Whirlpool duet gas dryer PF error will not reset as per manuals
Mar 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
PF Code on Duet Electric Dryer
just press cancel ..pf means power failure ..if still not clearing probably control
Aug 15, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool Duet Electric Dryer will not get hot
Here are the source codes that pop up on the dryer with the "fix" PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display. E1 Thermistor open Replace thermistor if found defective E2 Thermistor shorted Replace thermistor if found defective
Sep 12, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Open Questions:
Kenmore Elite Dryer HE4 Quietpak 9, has 4 dim lights showing on the console display but won't start or respond, I have bought brand new and replaced all sensors. Replaced heating element. looked like the original heating element. Pack came with new sensors. I did not test with a multimeter. My plan is to measure continuity on all the old sensors. Then do the same on the new ones. The electronic board looks good, does not smell burnt or old burnt smell. I cleaned all the lint in this dryer but unfortunately the motor has some lint in it which I surfaced cleaned. The only way to get to the motor is to remove the drum. So far I have soent $40 on all parts and a week works of troubleshooting as a novice. On the main display read, it shows two small dim lot red lines, wish I could send you a picture. Also when the fuse is off I plugged in the dryer and all the lights turned on normal. All looked in working condition except of course it did not turn on, I have not replaced the switch and with the new fuse, by the way, I bought 5 to 6 of the same fuses thinking I was burning them, that's why I bought a multimeter to retest them to see if they are not burnt. When I plug in the fuse it goes black but the door light works. I have held down the start button, nothing, held down the cancel button, nothing, I have done the crazy push all buttons even shook the machine a bit just in case something was causing whatever myth I was conjuring. I am about to give up and just buy a used one from someone else but I think I can fix this, it should be very simple to fix.
Aug 20, 2018 | Kenmore Dryers
Dryers Logo
8,909 people viewed this question
Top Dryers Experts
Marvin
Marvin
