Question about Kenmore 63942 Dryer
Belt busted Kenmore dryer 70 series, i bought the exact same belt but it seems to long, thats probably because when i opened the dryer a part was laying on the ground it looks like a black metal arm with a white roller, i tried finding where it attaches but i am lost.
  • Anonymous Jun 08, 2008
    cant figure out how to mount the tension arm
  • johndgreat Sep 21, 2008
    belt is on tub but tensioner is laying on the bottom of dryer
    but has way to much slack in it now
    President:
  • Kenmore Master
  • 2,651 Answers
Lets see what we can do. wrap the belt around hte tub assy. the little white roller w/ metal arm (called the tension pulley) needs to be installed .there should be a few ****s directly under ther motor pulley on floor of unit.two sets of ****s you wanna use the set to ther rear of unit. insert the prongs into the left rear **** and then pull the roller portion to the right.(it should hook the back prongs of idler into the rt side ****s. tension holds this into position so it will fall out if you let go) theres an opening in the metal under the roller mounts, e**ugh room to slide the belt through.heres how it works, install the idler as described above, feed the belt through the opening in the idler from the left and under roller through hole pull hte roller and pulley hard to the right.(its springy and as long as installed correctly ** worry of popping out) and loop around the motor pulley.let go of the pulley. and the belt should remain tensioned. it will only go on on way. GOOD LUCK
Posted on Mar 10, 2008
Kenmore gas dryer drum does not rotate
The most probable cause is that your motor went bad....
Check out this tip...it will help you..
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Mar 29, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer wont start.
can you hear the motor or does the unit humm or vibrate when it is turned on
if yes then have a look at the belt
if not it's time sor a service call
Aug 04, 2009 | Kenmore 700 6972 Dryer
Motor runs but drum doesnt spin
The belt may have broken, you must open the dryer case and check the belt. If broken, you'll see it laying on the bottom
May 18, 2009 | Kenmore Dryers
Belt on my Kenmore series 70 dryer broke. How do
broken belt......simple fix.......remove lint filter from top 2 screws remove.........insert screwdriver between top & front push down to pop top......1 screw on each side holding front on at top remove them....front will then pick up off the 2 remaining clips at the front bottom.....spin door around to the side belt should be laying in the bottom of the dryer or around the tub but broken.......hope this helps......check back.......
May 05, 2009 | Kenmore Dryers
Fabric looking belt came out of dryer. when i try to dry clothes it makes a loud noise and smells like something is burning and my clothes get twisted. how do i fix it? I have a kenmore 70 series dryer
Stop using your dryer in its current condition. That fabric looking felt is probably your drum seal. They commonly wear out. I will need your dryer model number in order to confirm how your dryer is configured and give you accurate advice on part numbers and directions on how to replace. The model number should be listed on a name plate around the door opening.
Apr 22, 2009 | Kenmore 63942 Dryer
Belt and assembly trouble. Please help!!
Yes, there is a tension pulley but I"m at a loss as to how you're burning the belt, if not routed around the tensioner... seems to me you'd have a world of belt slack.
You might check and see if you can freely spin the drum, or if it seems to be locked-up. There may be an obstruction, keeping it from rotating... it shouldn't require so much effort.
Just a suggestion... Good luck.
Mar 05, 2009 | Kenmore 62722 Electric Dryer
Kenmore Electric 70 series dryer making noise
can spin motor w/ hand ,,if so pull side by side if no noise ,, inspect rollers,and idler
Dec 28, 2008 | Kenmore 65942 Electric Dryer
Makes squeaking noise after running for about 10 minutes
there are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
Nov 16, 2008 | Kenmore 67082 Electric Dryer
Kenmore 63942 Dryer Logo
185 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
