Question about Microsoft Xbox 360 Console
Xbox live connection: My NAT
My NAT for my Xbox(360)LIVE is moderate and it wont get open. It has been open for a long time but then it just went moderate. How do i make it open?
  • ed004v8555 Jul 26, 2008
    hi i have a linksys wrt54gr router recommended by xbox . But can only get a moderate connection , any ideas thanks
  • Anonymous Jul 26, 2008
    xbox nat is servire and i need to open it
Its likely your router needs to have port forwarding setup on it, or you could try setting up your Xbox ip address as a DMZ on your router.
however some routers simply wont work, I had a voyager 105 using port forwarding but it still never worked till i changed to a Draytek
post more details of your router and what you have tried.
also you cant go far wrong visiting here
http://www.xboxlivetheguide.co.uk/XBoxLiveTheGuide2.php?department=Home
Posted on Mar 11, 2008
My xbox is telling me that my router's NAT setup is on moderate. what does that mean? and how can i fix it?
Here is Microsoft's definition of a moderate NAT and their suggested fixes.
http://support.xbox.com/en-US/xbox-live/connecting/nat-type-strict
Dec 24, 2011 | Microsoft Xbox 360 Console
Every time i try to join my friends game it says session is ureachable and it is really annoying. We live at different IP addresses and could connect before. We all have the same DLCs and it is only me...
make sure you and your friends have open NAT, you need to port forward certain ports for xbox live on your router, try to check if ubisoft also has specific ports need to be open. if still the same contact your ISP, they might be having problems.
Mar 23, 2011 | Ubi Soft Assassins Creed: Brotherhood for...
I went on a trip and connected to a network with a moderate NAT type. When I got home I tried to connect back to my original network which is usually open and it didn't switch back to open. I connect using...
var YAHOO = {'Shortcuts' : {}}; if (typeof YAHOO == "undefined") { var YAHOO = {}; } YAHOO.Shortcuts = YAHOO.Shortcuts '' {}; YAHOO.Shortcuts.hasSensitiveText = false; YAHOO.Shortcuts.sensitivityType = []; YAHOO.Shortcuts.doUlt = false; YAHOO.Shortcuts.location = "us"; YAHOO.Shortcuts.document_id = 0; YAHOO.Shortcuts.document_type = ""; YAHOO.Shortcuts.document_title = ""; YAHOO.Shortcuts.document_publish_date = ""; YAHOO.Shortcuts.document_author = "ross.haller@yahoo.com"; YAHOO.Shortcuts.document_url = ""; YAHOO.Shortcuts.document_tags = ""; YAHOO.Shortcuts.document_language = "english"; YAHOO.Shortcuts.version = "2.10.0"; YAHOO.Shortcuts.annotationSet = { "lw_1299607050_0": { "text": "http://www.xbox360forum.com/xbox-forum/threads/51908-How-To-Open-NAT.-xbox-360", "extended": 0, "startchar": 286, "endchar": 363, "start": 286, "end": 363, "extendedFrom": "", "predictedCategory": "", "predictionProbability": "0", "weight": 1, "capAbtScore": 0, "abtScore": 0, "csScore": 0, "prismaScore": 0, "spectrumResolutionScore": 0, "conceptScore": 0, "type": ["shortcuts:/us/instance/identifier/hyperlink/http"], "category": ["IDENTIFIER"], "wikiId": "", "relatedWikiIds": [], "relatedEntities": [], "showOnClick": [], "context": "http://www.xbox360forum.com/xbox-forum/threads/51908-How-To-Open-NAT.-xbox-360", "metaData": { "linkHref": "http://www.xbox360forum.com/xbox-forum/threads/51908-How-To-Open-NAT.-xbox-360", "linkProtocol": "http", "linkRel": "nofollow", "linkTarget": "_blank", "visible": "true" } } }; YAHOO.Shortcuts.annotationSetID = "1eac068650c8d27415163f15165866e5"; http://www.xbox360forum.com/xbox-forum/threads/51908-How-To-Open-NAT.-xbox-360
This is what I did.
Feb 19, 2011 | Microsoft Xbox 360 Console
My nat settings for my xbox 360 is set to strict, I am connected to xbox live from my laptop, my laptop is connected to my linksys router, how do i change my nat settings to open if my connection is set up...
You'll need to log into the linksys router and find the setting for UPNP. Please make sure this is enabled. That should allow your NAT setting to at least Moderate, if not Open.
Mar 12, 2010 | Microsoft Xbox 360 Console
I cant hear people talking on my ax 180s but my mic doesnt work i have 360 help
ou should check your NAT type [the think that lets you connect, talk, hear, and play with people on Xbox Live]
Go to the Xbox Dashboard, Network Settings and Test Xbox Live Connection.
In the bottom of the tests, it will say your NAT Type
Strict= Bad
Moderate= Sucky
Open= Works Fine
If its Open, then you know thats not the problem.
If its Strict/Moderate, go to More Info and they will tell you more about it and give you a website that will help you out. Source(s): Experience
P.S. [That website that will help you out]
www.xbox.com/setup
P.S.S. Have you checked the batteries? Sometimes when the battery of a wireless is low, it won't allow you to speak
Jan 05, 2010 | Microsoft Xbox 360 Console
Nat Is Moderate Xbox Live
So let me get this straight; you have your XBox plugged in, via ethernet, to the modem, and are testing the connection?
Jun 15, 2009 | Microsoft Xbox 360 Console
Switching from moderate NAT connection to an open NAT connection
yo tengo problema co el asistente de conexion del linksys
Feb 10, 2009 | Linksys WRT160N Wireless Router
How do i change my NAT connection from moderate to open
This one is simple. Find the IP address that your Xbox is assigned by your router, then put it into the DMZ. This also goes for PS3 users who are having trouble with internet access.
Microsoft Xbox 360 Console Logo
373 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
