Vertical hold adjustment
1992 model number CS3515R mitsubishi tv. The vertical hold needs to be adjusted, but I can't find where to adjust it.
  • sjs1 Mar 27, 2008
    1989 sanyo tv picture went to a thin line across the screena dn thats it, its very expensive to fix, could i fix it myself and is there documentation to help me ?
    Genius:
  • 1,694 Answers
Loss of vertical sync or any other problem with your Mits is
likely caused by bad power supply capacitors....they are made by Rubicon and are notorious "leakers"......very tedious and
expensive to fix...................good set back in the day.......T.
Posted on Mar 10, 2008
I have a 1999 Mitsubishi Projection TV and the vertical hold wont adjust. How do I reset it.
Put it back to the mid point of it's adjustment range.
If the V hold won't stop the picture rolling at some point in its adjustment range then the circuit that it affects has drifted out of tolerance. The defective parts in that circuit need to be replaced.
Sep 10, 2014 | Mitsubishi Televison & Video
I have a Mitsubishi VS 50605 projection tv that needs to have the vertical hold reset. How do I reset it.
If the V hold won't stop the picture rolling at some point in its adjustment range then the circuit that it affects has drifted out of tolerance. The defective parts in that circuit need to be replaced..
Sep 10, 2014 | Mitsubishi WD Televison & Video
The picture is moving up and down in every 3 sec
Vertical hold needs adjustment. Check for vertical hold preset and adjust. If no preset present in the P C B of the TV, try through service mode adjustment. Service mode adjustment possible only by the authorized service provider.
Jul 10, 2010 | Haier HTF20 20" TV
I need to find out about model CS-3115R Mitsubishi tv. I need to fix a vertical roll
it is very possible that if you have to continuously adjust the v-hold on your tv ( which would only be in older models) then your problem would be in your sync circuits and need a qualified service tech to repair . most of the time it is a cap problem
Nov 04, 2009 | Televison & Video
Vertical picture problems on my 1993 mitsubishi vs-50va2
Can you provide a more detailed description of the vertical problem you are seeing? There are a number of defective parts that can cause different symptoms. Few vertical problems are adjustments. Most are either poor solder connections or defective parts. The parts cost should be minimal.
Please confirm you model number here and try to provide more details on the problem.
Thanks,
Dan
May 11, 2009 | Mitsubishi VS-45605 50" Rear Projection...
I have lines like vertical hold is off but can't find ajustment
Thank you to "TheScreenGuy". He replied with an answer that says the vertical sync is automatic and that I need to replace the SSB. Thanks!!!
Mar 23, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi CK-3526R TV
not sure what light picture has to do with problem  but no there is no  vertical hold control  prob bad electrolytics invertical feed back circuit, need tech..
Dec 07, 2008 | Mitsubishi WS-55807 TV
Mitsubishi rear projection tv
replace vertical IC and shadows/ghosting the problem is either electrolytic capcitor or video IC or convergence adjustment
Aug 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Vertical hold on tv
no control over the remote..but impossible not to have vertical hold control in the TV itself. it should have one maybe at the back.
Apr 07, 2008 | Audiovox AVT-1475 13" TV
Mitsubishi cs27403c tv problem
kindly...see first the flyback and adjust the screen if the horizontal line still there adjust the fucos....
Jan 08, 2008 | Mitsubishi CS-27405 TV
Televison & Video Logo
528 people viewed this question
Top Televison & Video Experts
