Question about LG Studioworks 45 14" CRT Monitor
Horizontal and vertical adjustments
My lg studioworks 454v's horizontal and vertical adjustments are not working.
I tried to replace 3 potentiometers but it's still not working....
Help please...
Thanks...
  • kaervek Mar 28, 2008
    thanks dude for the info...
    i'll try it now...
    hope you can help me with monitor related probs next time!
    GODBLESS!
My monitor model- studioworks 500g
problem-width of screen high ,i cannot adjust, pls help me
Posted on Mar 13, 2011
  • 151 Answers
Check components related with pots thats adding command ic to pots.If they are ok then change command ic with new one.Before this you can check horizantal hold transistor that is placed on hitsink of eht.small in size and check two small transistor placed near it on pcb.Hope this solution works .If not then i am here
Posted on Mar 15, 2008
Monitor Reset Problem
Id try a different monitor to start with.
What program are you using when it blanks out?
Feb 12, 2014 | LG Studioworks 563N 15" CRT Monitor
Blue vertical bar Left side and yellow,red vertical bars are seen both side of screen cause images are not readable
Hello
If the monitor displays these vertical bars, after a service has been done to it, and if LOT has replaced, there is a mismatching problem with replaced LOT and the defelction yoke.
Dec 18, 2011 | LG Studioworks 700S 17" CRT Monitor
563A horizontal too wide unable to adjust, how to fix?
I HAVE LG CB563G MODAL15'' MONITOR HORIZOLY EXEED SCREEN I CANOT ADJEST WHEN ON MONITOR 1.1/2 HOUR IN
H/S C5803 TRASITOR FILES PLEASE HALP
Jan 15, 2010 | LG Studioworks 563N 15" CRT Monitor
Menu button of my monitor is not working properly
Try to fix that on display setting under windows display setting set it on lower setting. You can do that alternatively by booting on safe mode. Then readjust your display setting.
Mar 08, 2009 | LG Studioworks 563N 15" CRT Monitor
How do i identify the wires of the lg 710s?
Vertical signal wire is yellow colour wire
Horizontal signal wire is White colour wire
Nov 22, 2008 | LG Studioworks 700S 17" CRT Monitor
LG 17" MONITOR MODEL 700E (COLOUR & SHAPE PROBLEM)
THE PRESCRIBED ARROWS ARE FUNCTIONING WELL FOR INCREASING THE VERTICAL SIGE OF THE DISPLAY OF THE MONITOR.BUT THE HORIZONTAL AROWS WHEN OPERATED ARE NOT ABLE TO INCREASE THE HORIZONTAL DISPLAY OF THE MONITOR TO FULL SIGE. PLEASE GIVE APPROPRIATE SOLUTION.
THANKS
Aug 14, 2008 | LG Studioworks 700S 17" CRT Monitor
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Remove dry solder at Vertical IC if problem not solves replace VERTICAL IC and pf104
Darshan
Jul 05, 2008 | LG Studioworks 552V 15" CRT Monitor
Problem with Studioworks 563 monitor
LG Studioworks 563N Monitor horizontal width is exceeding out of screen and not able to adjust it along with pincushion through menu. IRF S630A Transistor replaced, no effect. Pl. help.
Nov 18, 2007 | LG Studioworks 563N 15" CRT Monitor
Monitor lg
easy ,red,green,blue and ground first, then find vertical and horizontal sync,then ddc pins you can solder and test with your compuiter on.
Mar 06, 2007 | LG Studioworks 700S 17" CRT Monitor
LG Studioworks 45 14" CRT Monitor Logo
237 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
