Question about Kenmore 700 sq. in. Cooking Area Gas Grill 14116325
Gas grill lights but doesn't get very hot
We have a Kenmore gas grill. It lights fine, but doesn't get very hot. Any recommendations regarding fixing the problem.
thanks,
sheldon
720.291.5500
shel@viawest.net
  • 2 more comments
  • JMC0341 Apr 13, 2008
    My "Uniflame" grill lights fine, and when I set it to high, the flames increase appropriately. But, after maybe 5 seconds, the flames die down to a very low burn. All the holes in the tubes are lit and apparently unblocked. The grill is about 2 yrs old, at most, and has always been on the covered deck, never been in the rain and has spent its winters w/ a cover. As it is about 20 feet from the road, some dust might've gotten in, but nothing looks clogged.
  • petraco16 Jun 28, 2008
    same problem... the flames for the grill are low, but the burner on the right side is very high.
  • Anonymous Jul 07, 2008
    I had a similar problem over the 4th weekend, my grill would'nt get above 250 degrees. I tried to re light it several times with no luck and even changed the tank. Then while heating it up to clean, the flame came up unexpectidly sending the temp guage out of limits damaging the the grates and stainless steel. I suspect a regulator failure of some sort, not having much help from tech line or the Sears service center.
    1-800-ForMyHome Sears Line
    1-888 -317-7642 Manufacture Hot Line...Waiting for call backl
  • Anonymous Apr 21, 2009
    I have a LPG Kenmore model 141.16324
    the main burner Lites ok but then it will like backfire.
    I check the the burner tube and the orifice and they are clean
    can I just the air flow to the burner tube... HELP
I had this same problem especially when the tank on my 5 burner 2 year-old Kenmore was about half full. The solution above fixed it. I was used to opening the gas fully, turning one burner to high and clicking the button. If I would have read the front of the grill I would have seen that this was incorrect. I turned off the grill completely, unhooked the regulator and reconnected it. With one burner on high I began clicking the button BEFORE I turned on the gas. I slowly turned the gas on one quarter turn and it lit up full flame. I slowly turned the gas another quarter turn and lit the second burner. I slowly opened the gas all the way and lit the third and so on. That did the trick!
Posted on Jun 23, 2008
  • sheilaellis
    sheilaellis Apr 06, 2012
    gas tank or front burner (turning on slowly)?
I have a Kenmore Duel Fuel, it is approx 1 year old barely used. I have alwys had problems lighing it,or when it is lit the flame is low and won't heat up.Sears came out to repair it, and Technician said to "shake the propane tank" It continued to be a problem and I stopped trying unil about 3 weeks ago, again I tried for 30 minutes, finally it was lit . Suddenly a large flame shot out from under the grill, and I call The fire dept, it burnt up pretty good, I called Sears repair again, they sent a repair person today, that wants to oder us a new fuel line? this was a 1,000.00 grill. two of the knobs are melted of and it is entirely scorched!
Posted on Apr 24, 2008
There's a good chance your LP tank isn't putting out enough propane because it thinks there's an overflow. In short, if you don't light the grill fast enough, Propane flows back to the tank and a safety feature limits further output. Shut the valve and disconnect the tank, press your ignition switch a few times, then reattach and follow the manufacturers directions for lighting the grill. This will probably fix it.
If not, check for leaks in the hose with soapy water and make sure you still have a full tank!
Posted on Apr 07, 2008
Why won't my Weber grill ignite after installing a
Disclaimer- be careful when working with gas. Starters in gas grills are just about novelty anymore. Often, they only light 1/3rd or 1/4th of the burners and they usually stop working within one grilling season. I recommend using a wand lighter. Try to light just one burner but if doesn't light in 5 to 7 seconds, turn the gas off and wait to try again. Incidentally, you are turning the gas on at the tank, right? You should hear it when you turn the burner on.
Apr 24, 2012 | Grilling
Grill slow to start, doesn't get hot
sometimes spider webs clogs the orifaces. also check your regulator .if its not making any sound give it a light tap with wooden hammer handle sometimes the diaphram sticks
Feb 24, 2012 | Viking VGIQ5323RE1N Gas Grill
I have a Kenmore Elite Model 16690. What is the best website for replacement parts for this grill?
First, since it's a Sears house brand, I'd start online with Sears Parts Central. Depending on which parts you're looking for, you can also try Appliance Factory Parts http://www.appliancefactoryparts.com/gasgrillparts/brands/kenmore/
Keep in mind, Kenmore doesn't manufacture anything. It's just a house brand name for Sears appliances. Actually NexGrill manufactures the Kenmore Grill line. So contacting them 800.913.8999 is also a possible source for parts.
Hope this helps you and thanks for choosing FixYa. Happy Grilling!!
Sep 20, 2011 | Kenmore Elite 900 sq. in. Cooking Area Gas...
Our Kenmore Gas Grill Elite (bought in 2007) has not worked in 3+ years. It ran out of its warranty and then the problems began. It was converted to natural gas and from one day it was really hard to...
Question, when you pull off the knob do you see a screw on the front of the valve? Since the grill was converted, there are times where manufacturers use gas specific valves and the screw is there as an adjustment. Let me know.
Mar 22, 2017 | Kenmore Grilling
How do we fix a gas grill that doesn't cook evenly
Usually if you're have hot and cold spots, it's the burners that need to be removed and thoroughly cleaned. In addition, cleaning the venturi valves while the burners are out, is equally important. The Venturi valves are part of each burner. You will see them near the open end of the burner (looks like 2 slots cut into each side of the burner) where it fits over the burner orifice. While the burners are out, closely inspect each one for corrosion or rust thru. If you find severe corrosion or rust thru, the burner(s) should be replaced.
Hope this helped you troubleshoot and solve the problem. Happy Grilling!!
Jul 04, 2011 | Weber 3820301 Gas Grill
I have a kenmore gas grill that has the side burner. Up until recently, it has been working great. However, now the main grill won't light when pressing the ignition button but the side burner lights...
More than likely, the electrode spark ignitors on your main burners need to be cleaned. They will get covered with grease over time. Also check the wiring from the ignitor module to each spark ignitor being sure that all wiring is firmly in place. To clean the electrode(s) ... a cotton ball dipped in alcohol will work fine.
Hope this helped you solve the problem and Happy Grilling!
Apr 09, 2011 | Kenmore 700 sq. in. Cooking Area Gas Grill...
I have a KBNU367TSS and I am having problems with 3 of the 4 ignitors. Two of them will not work at all and one of them gets red but not hot enough to ignite the gas. The rear burner ignitor works fine....
One problem with glo plug ignitions is the loss of voltage across the glo plug. Each glo plug has to have the correct amount of current to get hot enough to light the gas. If the current is to low, the plug will glow, but not light the gas. You have to open the grill up and check the wiring, etc for shorts, bare spots in the wires insulation, etc.
Mar 19, 2011 | KitchenAid KBNU367TSS Gas All-in-One Grill...
Replaced the tank but now gas wont flow from tank through to the grill... dendendeerhunter@yahoo.com
Hopefully this will fix you up.
  1. Turn off the gas at the propane tank
  2. Disconnect the gas line from the tank
  3. Open the grill lid
  4. Turn all control valves to high
  5. Wait for about a minute
  6. Turn all control valves to off
  7. Reconnect the gas line to the tank
  8. SLOWLY turn on the gas at the tank
  9. Light the grill normally
Your grill should now heat normally
Nov 07, 2010 | Kenmore 16225 Grill
I have a Kenmore natural gas grill, model # 141-17227. I need the woners manual. The side burner will light but very low flame, cannot get the grill to light.
owners manual can be gotten through the internet- Sears.com find parts,type in model# of item, select manual sounds like valves are clogged- propaine and natural gasses are dirty gasses-no filter, it comes up out of ground,through dirty pipes, all the way to peoples homes- and thats why they have to replace valves on hot water tanks/furnuces........
Jun 19, 2009 | Kenmore 505 sq. in. Cooking Area Gas Grill...
Weak Flames on Propane Grill
It is possible that your burners are clogged. Clean the burner ports with a paperclip (not a toothpick).
Jun 01, 2009 | Kenmore Elite 644 sq. in. Cooking Area Gas...
Kenmore 700 sq. in. Cooking Area Gas Grill 14116325 Logo
8,735 people viewed this question
Top Kenmore Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
