Teac television we have a teac tv and it seems to be set on widescreen, the picture doesnt fit on our screen it cuts off some parts of the picture and writing. Can u tell me how to make the picture smaller or off widescreen? I have lost our manual. thanks John bmi59124@bigpond.net.au
  • Anonymous Jun 07, 2008
    heads and subtitles cut off picture too big for screen
  • kyle_dover Jan 11, 2009
    same problem heads and subtitles are cut off.
SOURCE: Image cut off of Samsung LCD TV picture
IF YOU'RE USING A TV CABLE BOX, USE ITS REMOTE TO ADJUST THE PICTURE, NOT THE SAMSUNG REMOTE. CHOOSE "NORMAL", AND YOU'LL SEE EVERYTHING THAT'S BEING BROADCAST.
GOOD LUCK!
Posted on May 02, 2008
SOURCE: screen size
YOU MUST GO INTO YOUR PS3 VIDEO SETTINGS MENU AND SET YOUR HDMI TO 1080P AND YOUR PICTURE SHOULD BE OK
Posted on Nov 02, 2008
SOURCE: Sony Bravia - picture don't fit the screen
I have a Scientific Atlanta cable box w/ Time Warner. I followed the instructions below for the cable box. Somehow it reset my picture and I can now read the ticker at the bottom of the screen and the different picture sizes seem to work properly. Good Luck.
http://newteevee.com/2007/12/15/six-steps-to-get-more-hd-from-your-scientific-atlanta-set-top-box/
Posted on Jan 31, 2009
DRebel
  • 19 Answers
SOURCE: TV picture doesn't fit in screen no matter what the setting
Ok, so I think I have your solution :)
You're actually my first when it comes to this site, so hopefully this fixes your problem!
Step 1 - Turn off the cable box, but leave the TV on
Step 2 - On the front of the 8300HD, press the "guide" button and the "info" button at the same time
Step 3 - Choose "HD" for High Definition, or "SD" for standard definition. (Sounds like you're HD?)
Step 4 - Choose the aspect ratio 16:9
Step 5 - Choose "progressive scan" if it asks you.
Now press the "power" button on the box, does that fix it?
Posted on Apr 03, 2009
  • 135 Answers
SOURCE: We have a widescreen plasma (Panasonic TY ST05-K).
Hi there! If picture is smaller top to bottom with blank section on top and bottom then check your aspect ratio settings. If blank at the bottom only the Bottom Y-Drive board may be faulty. If blank at the top The Top Y-Drive may be faulty. If blank on the Left (TOP TO Bottom) then the Right X-Drive Board and on the Right, the Left X-Drive Board. May also be bad connections on the cables or flexible ribbon cables. Best Wishes and Good Luck, JUS004
Posted on Aug 23, 2009
Samsung television LE40A559P4F i cannot expand the picture to fit full screen whena picture is broadcast in 4.3 foremat ive tried the picture settings but cannot get the picture to fit the whole screen
When in 4:3 format you cannot generally change that setting.. unless your TV gives you a widescreen "Over-ride" as the aspect ratio is "Set" in programming as the signal is decoded...
Jun 03, 2011 | Televison & Video
Picture seems to big for TV.cant read bottom words on screen and words are cut off on side also. Cant see scrores on any sports or read peoples names on bottom of the screen
Using the menu or settings button on your remote, access the TV's menu and find the area for picture settings and zoom. You're likely set to a zoom mode, so cycle through the options until you find the zoom setting that sizes to your TV best. (On most widescreens, the best picture is often on the setting 'panarama.'
Mar 12, 2011 | Vizio L37 Television
My screen does not cover the whole screen. It is not on widescreen mode, but it is a shortened picture and some of what I am watching is cut off.
A lot depends on what the TV station cuts off also.
If they are transmitting a 5 X 4 picture, your TV will try an reproduce it giving cut off edges or top and bottom. It won,t fit properly.
Hope that helps to explain it.
Jan 22, 2011 | Sharp LC-32SB24U 32 in. LCD TV
Picture Size
Keep in mind that not all programs and show are in widescreen format. When set to normal, you will get those black bars on the sides because the program is sized for the older TV's. Some TV's will have a zoom option, but that will cut off some of the top and the bottom of your picture.
Until everything goes widescreen, you are stuck in normal with those black bars or widescreen with the fat people.
I hate distortion in my TV image, so I am perfectly fine with my TV on normal.
Good luck.
Jul 14, 2010 | Philips Magnavox 42MF521D/37 Television
The picture does not fit the screen. The top and bottom of the picture go beyond the screen
you may need to adjust the aspect ratio of the picture, there is typically an "aspect" button on the remote that will adjust the picture from widescreen, super widescreen 16:9 ratio and sometimes you can zoom in. try that
Sep 20, 2009 | Samsung Televison & Video
Picture in wrong position, too big for screen
Hi
maybe the system settings is not set in default mode
Thanks!
Mar 05, 2009 | JVC AV27F476 27" TV
My tv zooms in and changes the format.
This is normal - you are zooming in on the picture. Most people use the zoom feature to "stretch" a widescreen movie so it will fit the screen.
Dec 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
CT-F683 TV fault
Press setup on your foxtel remote, go to systems settings, and look for "TV Type" menu, you can change settings there, your TV is a 4.3 (square) not widescreen. Its not a telly problem your just giving it the wrong signal.
Feb 17, 2008 | Televison & Video
Durabrand 21" tv picture distorted
To properly diagnose this problem,access to the servicer menu will be important.Also,the service literature for the horizontal and vertical circuits may be needed.Contact a tech who can help you that is familiar with Durabrand.
Sep 25, 2007 | Durabrand DU1901 TV
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
