Question about Kitchen Ranges
How to get the bottom element in stove to work
  • Ron Coons
    Ron Coons May 11, 2010
    manufacture and model would be helpful
  • 26 Answers
Take a meter and check the continuity first then inspect the wiring and the selector switch
Posted on Mar 10, 2008
Kitchenaid superba stove baking element does not heat
There has to be a baking element. Find it and replace it.
Aug 19, 2017 | KitchenAid Kitchen Aid Superba Series...
Tip
I'm wondering if my Jenn-Air Model JER8885QCS needs a new probe or not. It's a...
As oven probes age, they can sometimes generate error codes on kitchen ranges and render them inoperative. The error code varies between models, but can be found with the technical documentation that comes with your range. Most manufacturers place a tech sheet somewhere along the back of the range, or inside the console for qualified technicians to use as a troubleshooting aid. Refer to this if an “F” code is displayed on your operator console. The probe may also exhibit other symptoms without generating an error code. You could have undesired heating results (too hot or too cold), or slow preheat times.
The location of the oven probe can vary on different models as well. It will be mounted on the back or side of the oven wall (usually in the upper right or upper left corner). If you suspect you have a bad oven probe, a resistance check can be performed to determine if the probe is good. To accomplish this, unplug the range and remove the back panel. There are still dangerous voltages present even when the oven is not on. There will be two heat insulated wires coming from the oven probe behind the oven. Disconnect the wires and perform a resistance reading across both wires at room temperature. If the probe is good, it should read around 1100-1200 ohms*. If the reading is too low (shorted) or too high (open), replace it. However, I would take a good look at the interconnecting wiring FIRST. If you have a connector plug on the oven probe, often the plug pins will oxidize and not make good contact. This gives false readings and can lead to erroneous error codes. Some manufacturers recommend cutting the connector plug off completely and hardwiring the leads together by using heat resistant ceramic wire lugs. This provides a more permanent and reliable connection. The lugs can be purchased at most hardware stores. A new oven probe roughly costs about $35 - $45 and can be found on line at several appliance parts websites. Higher end model prices may be more.
To replace the oven probe, simply remove the mounting screw from inside the oven cavity, disconnect the wires and pull the probe out. Insert the new probe by feeding the wires through the opening in the back of the oven first and out the back through the insulation (a long screwdriver can assist you in making a visible hole through the heat insulation to feed the wires easier). Once you have the wires through the back of the oven, reinsert the mounting screw and connect the wires leads together. Reinstall back panel.
*NOTE: Keep in mind resistance readings will be higher if the probe is hot. Make sure you check the temperature at room temperature.
I hope this information is helpful..
on Mar 31, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Boil element caught on fire and melted.
If element caught on fire, I would suspect stove needs cleaning. Do that then elements should not smoke for long. (I hope all moisture was removed from stove!!!)
Feb 11, 2014 | Kenmore Element Stove Burner Frigidaire,...
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
My Tappan stove oven bottom heating element is not working. How do I fix it?
The element is probably bad. Remove element after unplugging stove and check with ohm meter. If you do not have one take element with you to parts store and they will check for you. Good luck. Hope this helps.
Mar 09, 2010 | Tappan TEF242 Electric Kitchen Range
The oven does not heat up on my GE Spectra XL44 but the broiler and stove work fine.
Might be the bottom element is bad. Not too hard to install a new one.
I am no electrician but if you unplug the stove, remove the bottom element and use an ohm meter attatched to each end, it should show if the element is broken through lack of continuity.
Just an idea from a landlord.
Oct 30, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Bottom element in oven not working
bake%20element2.jpg Bake element Most times it is easy to see a failed oven element. Their will bea hole or a welded mark somewhere on the element where a piece ofcheese fell on it and caused a hotspot. You can also check elementswith a meter or simply apply some wall current to them using a cheatercord to see if it gets warm. If the element gets warm that means itwill work and is not bad. If the element ain't coming on but you havechecked it out, of course then that would be the thermostat. HEADS UP: When fooling with the stove always be sure the power isoff. Pull out the bottom drawer and most of the time you can unplug thepower cord without moving the stove. To make it easier to work on most stoves the oven door can beremoved. I set the door at the broil position and gently ease up on thedoor, remove it, and set it to the side.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 22, 2009 | Maytag Kitchen Ranges
Kenmore electric stove oven top element (broiler works but bottom element will not heat
the element is easy to change. just slide out the stove from the wall. take off the rear cover and just unplug or unscrew the leads from that element and replace. first make sure you unplug the stove it's self from the wall. it does have 220 volt and will hurt you.
Sep 05, 2009 | Kitchen Ranges
The bottom heating element in the oven has stopped working
It isvery easy to replace just unscrew the bottom heating element (unplug stove first ) take it to home depo or appliance store and get a replacement and screw it back on......then plug stove in ...
Jul 13, 2009 | GE Spectra JBP78 Electric Kitchen Range
The bottom element stopped working on my stove. The element when tested is still good. The broil element still works and there are no error codes showing. The stove is a Frigidaire PGLEF385C02 made in...
If the element is good then the problem must be the thermostat /switch is not working (a common fault) or you have a wiring fault which is rare. Check out the thermostat/switch controlling the bottom element and replace if necessary.
Oct 17, 2008 | Kitchen Ranges
Kitchen Ranges Logo
53 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
