Question about Sony Cyber-shot DSC-W55 Digital Camera
Did your camera issue resolve?
Just checking in on your premium issue
The solution for my issue referred to a Service advisory issued by Nikon but my camera isn't listed. I plan to go to a local Wolf Camera to see if they know if this one is covered.
Posted on Mar 10, 2008
As far as I know my printer is coneected (HP209 Photosmart), but it won't print. It will copy but not print, what's wrong?
This Utility program resolve all the printing issue for HP Printers ( Network and USB connection )
This Utility will Resolve :
1. Check Connectivity between the Pc/laptop and HP Printer
2. Check if there any Documents stuck in Queue
3. Check if all the software/Drivers are correctly Installed
4. Check if the HP Printer icon is the default icon to print
5. Will Resolve Printer Spooler Issue and few more issue
This Utility program will fix all these issues.
Download the file on Desktop and Run the program ( Ex. File name = HPPDU.EXE )
Click here to download the Utility and save on Desktop location
Run the HPPDU file and follow the instruction on screen to fix.
This is very useful tool for your future assistance too. This will resolve your issue.
Regards,
Ron
Nov 04, 2010 | HP Photosmart Premium C309g multifunction...
This camera displays an error that reads: PROTEC. ESCR
Some memory cards have a Write Protection switch on them.
To check this please remove the Memory card from the camera. Check if there is a "lock" switch on the left side.
Slide this switch to the "Unlocked" position, and reinsert the card into the camera.
This should resolve the issue and the error should go away.
In case the issue persists, it could mean the the write protect on this card was perhaps set by mistake while it was connected to the computer.
You will need to use the computer to cancel the read-only setting.
Please connect the card to your computer through the camera or a card reader and cancel the write protect on the card.
This will resolve the issue you are facing.
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
I will look forward to your feedback and positive rating.
Sep 10, 2010 | Olympus Stylus 1010 Digital Camera
I have a sony cybershot DSC-W210 and just recently the flash wont work when its on any mode to take a picture it has the flash symbol on the screen flashing and the code E:91:01 underneath also flashing...
Perform the following troubleshooting steps to check whether the issue is resolved.
1. Remove the battery from the Camera for 1 minute. Re-insert the battery in the Camera and check if the issue is resolved.
2. If the issue is not resolved, then try initializing the Camera.
The Initialize option is listed in Setup or Settings option in the Camera.
Aug 06, 2010 | Sony Cyber-shot DSC-W70 Digital Camera
Camera won't trun on or charge.
Follow this procedure to troubleshoot if the power will not turn on.
Ensure you are using fresh or fully charged batteries. Check if the battery using is NPBG1 (supplied)
  1. IMPORTANT: Batteries discharge more quickly when used in cold weather conditions.
  2. Attempt to turn on the camera.
  3. If the issue is not resolved, try replacing or recharging the batteries if available.
  4. Attempt to turn on the camera in Playback/Edit mode by moving the mode switch to the Playback/Edit mode or by pressing the playback button.
  5. Switch the unit to camera mode and attempt to turn on the camera.
  6. If the issue is not resolved, try connecting the AC power adapter to the camera and a working electrical outlet. (Skip this step if the camera being used does not support the use of an A/C adaptor.)
  7. Attempt to turn on the camera.
  8. Try power resetting the Camera. (Remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the battery after 1 minute and check if the Camera works normally.)
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required. If you're located in the U.S, online repair request can be created for getting the unit serviced at the Factory service center by clicking the link below: https://eservice.sony.com or else by selecting your country from Sony Global webpage.
Jul 25, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
My camera says that there is a card read error and to insert a memory card why does this happen when i have a memory card in it?
This may happen if the Memory Stick is formatted in the Computer.
You may try formatting the Memory Stick in the Camera itself by using the FORMAT option in it.
If the issue persists even after formatting the Memory Stick in the Camera, then check whether a different Memory Stick works in the Camera.
If the other one works in your Camera then it must be the issue with the previous Memory Stick.
If the Camera does not work with a new Memory Stick, then you may try initializing it to check whether it resolves the issue.
Initialize option can be found in Menu items in the Camera.
If that does not resolve the issue, you may try removing the battery of the Camera for atleast one minute.
This should resolve the issue.
Jul 21, 2010 | Sony Cyber-Shot DSC-S40 Digital Camera
Camera switches on its own while looking at photos
You may try Initializing the Camera to check whether the issue is resolved.
The steps to Initialize the Camera:
Press the HOME button.
Select the "Settings" option.
Select "Main Settings"
Select "Main Settings1"
Select "Initialize".
Now select OK.
Jul 14, 2010 | Sony Cyber-shot DSC-H9 Digital Camera
Systerm is slow
hello,
you have so many options to resolve this.
  •  scan your c drive for viruses or malwares
  • end your unwanted files on task manager
  • check your hardware configuration
  • increase your ram speed.
please, you just specify the exact configuration of your pc and needs. then only, we have to resolve this issue as better.
thanks,
May 11, 2010 | Microsoft Windows Vista Home Premium with...
My camera keeps turning itself off and the amber light keeps flashing
Please check whether the battery is fully charged.
Please try using a different battery.
If the issue still persists after changing the battery try Power Resetting the Camera which should resolve the issue.
To Power Reset the Camera, First, please turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the POWER button on the Camera for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
Jun 15, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Windows xp slow internet explorer slow c:drive
My name is ArmyMason, might I suggest trying ccleaner www.ccleaner.com and see if that resolves the issue. CCleaner cleans out registry and could resolve some issues. Here is a link that shows registry tweeks to help with speed issues also. http://pcs.suite101.com/article.cfm/speed_up_internet_explorer
If this doesnt work might I suggest checking out our premium service and chat live with a tech.
Thanks,
Armymason
Feb 24, 2009 | Microsoft Windows XP Home Edition
Sony Cyber-shot  DSC-W55 Digital Camera Logo
24 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
