Question about Mitsubishi VS-60609 60" Rear Projection Television
Mitsubishi HD1080 60in TV
I have a Mitsubishi HD1080 60in TV and it just stoped working. The sound comes on but ** picture! The sound will stay on for a little while than it seems to turn itself off? Dont K**w what to do Please help Thanks
  • 3 more comments
  • jasonbonnell Mar 10, 2008
    Has sound but ** picture
  • jasonbonnell Mar 13, 2008
    I ended up taking the back off and found a burnt spot on one of the boards with some liquid on it. I cleaned it all up but will this happen again
  • jasonbonnell Mar 14, 2008
    The tv still works after i cleaned up the fluid, so does the bord still need to be fixed or just the coolant leak?
  • jasonbonnell Mar 15, 2008
    yea so it did stop working again when you press the power the green light comes on and a second later it shuts back off. if i were to get this fixed about how much do you think it would run me?
  • Anonymous Mar 16, 2014
    flashing power light
    Genius:
  • 1,153 Answers
First do a self test diagnosis. you can search Mits tv or read my solutions.
Posted on Mar 10, 2008
  • 1 more comment
  • Lashawn Robinson Mar 13, 2008
    Yes, you have a leak in your coolant fluid on one of the CRT's. This is a problem. First the leak has to be stopped then the board has to be repaired. You can price another board at PTS 18008447871
  • Lashawn Robinson Mar 15, 2008
    I would say yea, in some way or form, but if it works for you then use it if you like, but probably will have problems down the line.
  • Lashawn Robinson Mar 17, 2008
    Don't know you will have to call the number I gave you. You can ask for repair or replacement price.
My wd 65837 comes on and sound then picture sometimes rd light comes on and stays on but tv goes out
that's sounds like a Mitsubishi projection tv get a new bulb that's what ya need they are mercury so be careful, and another thing make sure all screws are put back in tight safety features will stop tv from staying on or sometimes powering if just one screw is not put back in in the bulb area and on the front just saved you 100.00 bucks
Jan 02, 2015 | Mitsubishi WD Televison & Video
No picture with sound tv turns off. Mitsubishi model WD65837
are any lights lit up when it shuts down? If so which light what color is it and is it blinking or a just stays lit without blinking?
Apr 05, 2013 | Mitsubishi WD 65837 TV
Comes on with good picture. in a few minutes, the
Hold down the menu and the input buttons on the front at the same time for 5 seconds. Led will flash a 2 digit code repeatedly. reply back with this code. If the set has been unplugged after failure code will be erased.
Aug 29, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WS-65809 turns off right away
check the collector drop on Q29a002. If it is less than 16 nano amps, repl ic u12 in conver circuit. stk392-570 and pico fuses f04 and f05 24v circ
Jul 28, 2008 | Mitsubishi WS-55857 55" Rear Projection...
Mitsubishi vs-50609 wont stay powered on
Hello nicolastran,
I gave this advice to someone with this same problem so here it is again:
It sounds like your shutdown circuit is being activated. This is due to excess current being drawn. This usually happens in the High Voltage section of the TV or one of the deflection stages. Due to the nature of this problem I would suggest that you take it to a local TV repair shop or have a TV repair person come out and take a look at the issue. The HV section is dangerous and should be dealt with by a qualified TV repair technician.
Thank you,
I hope this helps
Shuttle83
Jun 24, 2008 | Mitsubishi VS-50609 50" Rear Projection...
MITSUBISHI VS-50801 50" TV
Bad convergence IC possible - It's cheap if you do it your self, expensive if you take it to a repair shop. My Toshiba finally came on and stayed on after the IC's burned completely up and smoke poured out the back. Then mine stayed on with a distorted image. A good place for parts -> http://www.electronix.com/catalog/default.php/cPath/6
Apr 29, 2008 | Mitsubishi VS-50805 50" Rear Projection...
67" rear projection Mitsubishi....
Sounds like a cold solder joint, turn the main pcb over and see if you find any cracked solder or where the solder looks like it got hot.
Dec 04, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi ws55807
does the menu show up?
Oct 31, 2007 | Mitsubishi WS-55807 TV
Mitsubishi VS-60609 60" Rear Projection Television Logo
664 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
