Question about Sony Ericsson P990i Cellular Phone
Latest firmware for 2008
Here are the specs of my firmware
Phone:
CXC162037 R9GA001
Bluetooth:
CXC162092 R6E28
CDA:
CDA162007/8 R6E28
i need to know if there is latest firmware after this... thanks i'll wait for the response....
  • ryan26 Mar 21, 2008
    I'm still having alot of problems even I have updated the latest version R62E.
    The phone still restart itself.
    Hangs when sending SMS
    Call disconnected after answering and making calls.
    charging problems
  • ryan26 Mar 23, 2008
    charging problems
This is the most recent version
Posted on Mar 12, 2008
    President:
  • 1,944 Answers
Did you format the internal memory after the software update? This could solve all your problems.
Posted on Mar 26, 2008
I can not activate the bluetooth it stays in off. after an reinstall of the new firmware 10.0 , when i select bluetooth the phone is trying to activate it but it stays off. the radio also keeps searching...
Reinstall the firmware or just reflash the phone with the current latest firmware. your problem will be solved..
PLEASE RATE THIS ANSWER, IF YOU GET ANY HELP FROM THIS ANSWER OR LIKE THE ANSWER
Apr 04, 2011 | Nokia 5610 Blue Quadband 3.15MP A2DP +...
What is the latest firmware of SE W960i?
CDA: CDA162034/17 R8A
Organiser: CXC162146 R6F41
Nov 09, 2010 | Sony Ericsson W960i Cellular Phone
Hooking up alpine hd radio unit, bt-400, which one do i hook ipod to
Niether .... do you know what you have in hand? Both those extras costed someone some cash ... OK here it is: the CDA-9884 has a dedicated input for ipod (a KCE-422i cable is needed and comes with the new CDA-9884 in the box) ... The HD radio unit allows you to recieve new HD radio signals (digital radio, and stations that have it in your area may also have extra music streams like HD TV does). The bt-400 is a bluetooth adapter to use bluetooth enabled devices with such as a cell phone. If your ipod has bluetooth you could used the bt adapter but I suggest the KCE-422i cable instead, and check out the HD radio too, it's pretty cool.
Apr 17, 2009 | Alpine CDA-9884 Car CD/ MP3 Player
MAIN FIRMWARE
You can find firmware at :
http://www.akshayy.com/sonyericsson/
Hi to all. I have seen thet flashing CID52 phones has been very often nowadays, but many people are asking how to flash their phones and there is no such tutorial around the forum, so I decided to put one icon_smile.gif.
First of all I would like to tell the advantage (purpose) or meaning of flashing icon_smile.gif. Flashing the phone is procedure of putting new firmware (software) in the phone. There are many reasons to flash our phones. Firmware upgrade, solve software problems and bugs, convert our phones to some other model (most common is K800 to K810) and etc...
Flashing the firmware is done by changing the MAIN and the FS part of the firmware (while not touching the EROM and the GDFS) which makes the flashing easy procedure that can be done with the ordinal DCU60 USB cable (the cable you get with your sony ericsson phone) icon_smile.gif.
Once we know what flashing is, we can start preparing for the flashing procedure icon_smile.gif. To flash the phone means to change the MAIN and the FS part of the firmware, which means if you want to flash your phone with new one, you have to download it. Firmware and other stuff can be downloaded from here:
http://www.sek750i.pl
http://www.iprotebe.cz
These pages are free and registration is easy and fast.
First, download XS++ flashing program.
When you download MAIN and FS files for flashing, you need to download finalization files for your new firmware. There are MAAANY finalization files (a.k.a custom files or custpacks and etc...) sorted by the phone's firmware CDA numbers. To download the right one for you, you have to check your phone CDA. CDA can be checked from the service menu (>*<<*<*) where you check the firmware version. There are letters CDA followed by some numbers like 1024, 1025 or etc... These numbers are the CDA version. You have to download custpacks for the CDA you have, and the firmware you are planning to flash your phone with.
When you have all files needed you can start flashing the phone.
You need to have installed flash drivers for your phone. For beginners, flash drivers installation guide is included here:
http://www.esato.com/board/viewtopic.php?topic=150098
When you have the flash drivers installed, you can run XS++.
Before that, prepare you firmware files in one folder (I mean the MAIN and FS file unzipped in .mbn, .fbn format or whatever it is) to have them easy for accesing and navigation.
Turn off your phone. Remove the SIM card. Run XS++ and then press the "Connect button"
Then connect the phone to your pc using the USB cable while the phone is turned off. When connecting the phone to pc, hold pressed the "c"button (on the phone) pressed down. This will connect your phone to XS++, where you can start flashing it.
You will see folowing window:
New window
Press the flash radio button (As number 1 shows) if needed only. That will guide you to the flashing panel of XS++. Here you can select which firmware files you will use to flash your phone with. So check the FLASH MAIN and FLASH FILESYSTEM check boxes. Then press browse and locate MAIN and FS firmware files. When browsing from MAIN navigate and select the MAIN firmware file you have downloaded, and when browsing from FILESYSTEM, do tha same for the downloaded FS firmware file.
Then press the "Flash" button.
Now you have to wait while your phone is being flashed.
Once flashing is done, you will be prompted to unplug the phone. Then you can turn on the phone. You will get this error:
"Configuration error, please contact network operator for information". This means that your phone is not finalized. Finalizing the phone is done by uploading a pack of files into predefined folder inside the phone's filesystem structure. That pack of files is called finalization files also knows as custom files, cestpacks and etc...
Use XS++ to upload these files (you downloaded before) into this folder:
tpa/preset/custom
Use the XS++'s FSX feature to upload these files.
Here is a tutorial how to upload files to phone filesystem using XS++
http://www.esato.com/board/viewtopic.php?topic=153863
WARNING: EVERYTHING YOU DECIDE TO DO WITH YOUR PHONE IS AT YOUR OWN RISK. ME OR ANYONE ELSE IS NOT RESPONSIBLE FOR THE DAMAGE MADE TO YOUR PHONE DUE TO UNPROPER USING THE PROGRAMS INCLUDED IN THE GUIDE!!!
Hope this guide will help most of the people who are runing around the forum and asking the members for step by step flashing tutorial icon_smile.gif.
Mar 13, 2009 | Sony Ericsson K550i Cyber-shot Smartphone
Garmin nui 360
Please tell me what the version of bluetooth firmware is showing up in your unit. You can access this by pressing the wrench symbol, then the gear symbol, then "about". The latest bluetooth version is v3.4. If it shows up as 0.0, then you need to reflash the bluetooth firmware.
One note: Everytime you update the bluetooth firmware, it erases your pairing information with your phone, so you will have to re-pair your phone with your Nuvi.
Best wishes,
- Jim
SHARCNET-USA
Dec 11, 2008 | Garmin Nuvi 360 Bilingual GPS Navigator...
My Bluetooth interation suddenly stopped working
Many problems related to pairing can be corrected by verifying that the latest firmware is loaded to the GPS unit and the phone. To update the firmware on the GPS, please use the WebUpdater program. To make sure the phone has the latest firmware updates, please contact the phone service provider for more information.
One additional tip is to always pair the phone with the GPS from the phone itself. Do not attempt to pair to the phone from the GPS unit.
Oct 07, 2008 | Garmin Nuvi 660 GPS Receiver
Can the firmware on a in dash kenwood dvd be change
Visit www.kenwoodusa.com for latest firmware updates. Some of the updates are specific to map software (Garmin for KNA-G510) or bluetooth (Parrot for KCA-BT200) only.
Aug 10, 2008 | Kenwood DNX7100 Car Video Player
Bluetooth wont work on my palm treo 750
try master resetting the phone or updating the firmware on the treo
Jun 25, 2008 | Cell Phones
Samsung yp-t9
i cannot down load driver from your site for my ipod which model no-is yp-t9j and it capacity is 2 gb .
please give me advise how should down load this driver for my pc.thanks
May 29, 2007 | Samsung Yepp YP-T9 Digital Media Player
Sony Ericsson P990i Cellular Phone Logo
119 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
