Question about Toshiba 65HDX82 65" Rear Projection HDTV-Ready Television
Re 65HDX82 Squiggly distorted screen
Hi Techman, I need some help finding the board. Do you know where I can get the diagram or can you point me directly to it?
I have many years of experience repairing computers when I used to troubleshoot to component so that should tell you how long that was, but if you can direct me to the component or components then i could treplace the part without a problem.
My TV started out with the distortions but cleared up for a while but not it is consistently distorted on all channels for almost a year but I cant afford to change the thing or pay someone right now, so I have to try to repair it myself.
Your help is greatly appreciated.
Geego
  • 1 more comment
  • bobrms48 Sep 04, 2008
    tv screen is jumping around it gets better after it warms up
  • Anonymous Dec 22, 2008
    I have the same issue. I was told it was the lamp bulb but not 100% sure. After the TV is on for awhile, then the problem goes away.
  • dent67 Dec 22, 2008
    I have same distortion. started out just at the top and then got better with time on, but now it is constant distortion. repair man said it was in the power chassis but he needed to take it to the shop. i would like some info on components also so i could fix it myself or maybe purchase the chassis.
    President:
  • 3,130 Answers
You are giving mr ** information on what your problem is, the model number, or make of the TV set. what are you trying to tell me?
Posted on Mar 10, 2008
There is what looks like an exclamation point inside a half vase with a squiggly line on the bottom.
I don't think it is squiggly line but water and the explanation point is a thermometer, you are overheating. Check the coolant, find out why it is on. Hope this helps.
Aug 31, 2010 | 2008 Dodge Caliber
Green squiggly line distorting picture on TV
Ur Convergence is dead.Parts and labors,about $300 dollars.
Jan 07, 2010 | Televison & Video
Toshiba 65hdx82 has a squiggly distorted side to side picture from all inputs. It gets slightly better after it is warmed up but still very bad. When you go into a menu screen that seems to be OK.
Ur convergence is the problem.U know how to solders?Tries websites.Tv repair World.com,Tvrepairkits.com for convergence kit,replaced what in the kit.
Dec 15, 2009 | Toshiba 65HDX82 65" Rear Projection...
Squiqqly lines on TV
Hi Tammy, Yes it can be repaired, most companies charge about $250.00 to repair the convergence circuit. Have them check to see if the SRS/WOW 3D pcb has been modified also!
Jun 05, 2009 | Toshiba 65HDX82 65" Rear Projection...
Card reader replacement
I suspect that it won't play any source that uses progressive scanning. The likely problem is the hyperboard or scaler board. This component allows the TV to switch from sandard definition TV to HD. Typically, the hyperboard will cause shaking and wiggly images especialy noticeable at the top of the screen. It will generally work better the longer its on. Expect to spend $400-500 to resolve this.
michtech
Dec 09, 2008 | Toshiba 65HDX82 65" Rear Projection...
Distorted Picture
the hyper module is defective needs to be repaired or replaced.
Aug 03, 2008 | Televison & Video
Distorted Picture
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Aug 02, 2008 | Toshiba 65HDX82 65" Rear Projection...
Warped picture Toshiba 65HDX82
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 12, 2008 | Toshiba 65HDX82 65" Rear Projection...
What is the life of a big screen tv?
Sounds like the veritical circuit has a bad capacitor. The cost is dependent on the servicers in your area. It can also be dependent on whether you take it to the shop or have a servicer come to your home. Look on a Mitsubishi website to find a servicer in your area.
Feb 07, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Toshiba 65HDX82 65" Rear Projection HDTV-Ready Television Logo
116 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
