Question about Samsung SGH-X830 Cellular Phone
U600 unable to dial number
Hi there
i am unable to dial a certain number, it says "Change by SIM" and then automatically redirects to me Messages?!
i tried to delete the number completely from my SIM or phone memory and jus dial normally, but everytime that comes up, i can't even call that number.
i must've pressed something accidently?
please help.
thanks.
Doesnt work =(
Posted on Mar 28, 2008
    Brigadier General:
  • 7,752 Answers
Typed *2767*3855# this should manu reset the entire main-board.
Posted on Mar 27, 2008
What does Fixed Dialling Numbers mean?
Fixed Dialing Numbers or FDN list is a SIM card based security feature which allows the phone to be "locked" so that it can only dial certain numbers, or numbers with certain prefixes.
A PIN2 code (numeric password) protects the allowed list of numbers from being changed by any person who does not know the PIN2 code.
In FDN mode, your device will restrict outgoing calls, except for the numbers stored in the FDN list.
To activate FDN mode,
1.) In idle mode, open the application list and select Settings ? Call settings ? Fixed Dialling Numbers ? Enable FDN.
2.) Enter the PIN2 supplied with your SIM or USIM card and select OK.
3.) Select FDN list and add contacts to be used in FDN mode.
To De-activate
1.) In idle mode, open the application list and select Settings ? Call settings ? Fixed Dialling Numbers ? Disable FDN.
Warning: PIN2 is a serious SIM-based security feature of the handset. If you are not sure of your PIN2, please do not enter random PIN2. When you access a menu requiring the PIN2, you must enter the PIN2 supplied with the SIM or USIM card. Contact your service provider/ Network for your PIN2. If the wrong PIN2 code is entered three times in a row, PIN Lock(PUK2) will be automatically activated.
Oct 31, 2011 | Samsung I5500 Galaxy 5 Unlocked Android...
Xperia x8 handset i hv n m unable to send text messages need quick solution for this hectic problem
Please, use another Sim with the phone, if the Sim can send messages, definitely sounds like an error in the SMS centre number. You can change this by following the below steps:
1. Open your dialer and dial: *#*#4636#*#*.
2. From the menus which appear, select Phone Information.
3. Scroll down to SMSC.
4. Enter the SMS center number given by your provider in this box.
5. Select Update.
This will then change the number and hopefully resolve the issues you are experiencing or you can also contact your service provider and the problem will be resolve for free.
Regards
Jul 18, 2011 | Sony Ericsson XPERIA X8 Cell Phone
Phone keeps saying invalid sim
Messages When You Turn on the Phone
  • When turning on your phone you may find a message requiring you to take a certain action before you can use the phone. If the message says "INSERT SIM," make sure the SIM card is installed in the phone or that it hasn't become loose. The SIM card is located in the battery compartment. Remove the battery cover and the battery. The SIM card should be located near the bottom of the phone under the metal hinge. Insert or secure the SIM card with the contacts facing down, reinsert the battery and batter cover, and turn your phone on again.
    If the message reads "PHONE LOCK," the SGH U600's automatic locking function is enabled. Enter the phone's password to unlock the phone.
    When using the phone for the first time, you will be prompted to enter a PIN. The PIN is given with the SIM card for your phone. Enter the PIN number exactly as given. You may also have the "PIN Check" feature enabled on your phone, which will require you to enter the PIN every time the phone is powered on. You can turn off "PIN Check" in the "Settings" menu.
    A message asking you to enter a PUK means you attempted to enter the PIN number three times and failed. You must contact your service provider to get a PUK.
  • Read more: Samsung SGH U600 Troubleshooting ' eHow.com http://www.ehow.com/way_5408527_samsung-sgh-u600-troubleshooting.html#ixzz11rVbifG3
    Oct 09, 2010 | Samsung SGH-U600 Cellular Phone
    Unable to connect voice dial
    Hi marrick,
    Voice Dial:
    Important: Be sure your phone supports the voice dialing function andthat it is activated. Record at least one voice tag. (Please refer tothe instructions in your phone’s user manual.) Note: Voice dialingentries must be stored in the phone’s memory, not on the SIM card!
    1. Press the Accept Button (1) for 1 second.
    2. A voice dial beep will be heard on the kit to prompt the user to say the voice
    tag of the contact to call.
    3. Say the voice tag exactly as how you recorded it.
    4. The voice will be played back to you, and then the phone will dial the number automatically.
    Her's a .pdf file of the user manual, which you can save to your computer:
    http://www.blueantwireless.com/downloads/supertooth_light/supertooth_light_manual.pdf
    Hope this helps :)
    Season's Greetings!
    Chris (ziraffa)
    Nov 21, 2008 | Blueant Supertooth Light Bluetooth Speaker...
    Unable to save message in memory card
    You probaby dont have enough memory on your card or your messages are being automatically saved to your SIM which i think you can change by going to messages options
    Nov 02, 2008 | Sony Ericsson W200i Cellular Phone
    Unblocked sgh-u600
    you need to go to your network settings n change the band
    Sep 15, 2008 | Nokia 1100
    Unable to go on the web
    I HAD SAME PROBLEM FOUND OUT WRONG SOFTWARE IN PHONE RING SAMSUNG ON 08702420303 THEY SORTED IN LESS THAN THREE MINUTES AS IT IS THEIR PROBLEM NOT SERVICE PROVIDER---HOPE YOU HAVE THE SAME SERVICE
    May 24, 2008 | Samsung SGH-U600
    Retrieve messages
    To connect with your answering system:
    1 Dial your telephone number from a touch tone phone. 2 When the system answers, enter your Remote Access Code. The system announces the number of messages and begins message playback. 3 Listen to your messages
    Change remote access code Press [*] [#]. Follow prompts to set new code.
    Apr 01, 2008 | AT&T 1818 Corded Phone
    Still need help on this!
    reflash the phone with latest firmware
    Mar 27, 2008 | Samsung SGH-X830 Cellular Phone
    Samsung SGH-X830 Cellular Phone Logo
    67 people viewed this question
    Top Samsung Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
