Question about Disney Mix Max Digital Media Player
Error free 4mb of space to build music library and disney mix max won't play any songs?
  • Tiff6425 Feb 16, 2009
    My disney mix max won't let me listen to my songs,videos,or pictures! it keeps on sayning "free 4mb of space to build music library"
    Scholar:
  • 93 Answers
The memory may be corrupt and it can't read the music files correctly. Open your My Computer icon and plug the player into your computer. You should see a new removable disk called Mix Max appear. Right click on the disk and choose Format from the pop up menu. At the Format window make sure that the File System is set to FAT32 and click Start. At the next window click OK to proceed. You'll then need to add the songs back to your player but it should correct the problem. When adding the songs to the player again make sure that you leave at least 4 megabytes of space available so it can create the library file.
Posted on Mar 17, 2008
How do i download music on my mp3 player?
How to Put Songs on Disney Mix Max
The Disney Mix Max portable media player is capable of playing audio files in the MP3 format. It can also play videos formatted as WMV and display photos formatted as JPEG. You can convert audio files into MP3 using the Disney Mix Max software -- Mix It Plug-in. The plug-in works with Windows Media Player 10. This software CD came with the player and is not available online. To download music to the device, you can use Windows Media Player 10 or Windows.
Things You'll Need:
* USB cable
* Mix It Plug-In installation CD
Instructions
Convert Non-MP3 Files
Install Mix It Plug-In. Insert the Mix It Plug-in installation CD into the computer's optical drive. Click "Install Mix It Plug-In" when prompted. If no screen opens, double-click on the "My Computer" icon. Double-click on the installation CD icon. Then double-click on the setup or installation file; this file is often formatted as EXE. Select to have the program saved to your desktop. Then double-click on the desktop icon -- "disneymixitplugin" to open the setup wizard. Click "Next" in the setup screen. Follow any additional setup prompts.
Open Windows Media Player 10 and create a playlist. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Open Mix It Plug-In. Select "Yes" when asked to save analysis information for your music files. The software will analyze each track's compatibility with the Disney Mix Max player.
Press "Go!" to start the conversion process. Once the process is complete, an inactive "Go!" will be displayed. All music that has been converted is still listed in your Windows Media Player 10 playlist. You are now ready to download music to the player using Windows Media Player.
Open Windows Media Player 10 on your computer.
Remove the USB jack cover located on the bottom of the Disney Mix Max. Insert the compatible end of the USB cable into the USB port on the Disney Mix Max. Insert the other end of the cable into the computer's USB port.
Click "Library" and click a playlist name. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Select the "Sync List" tab and choose "Sync List" from the menu.
Verify the items to be synced to the Mix Max, or right-click on a song title and select "Delete" to remove it. Click "Start Sync" to download music to the Mix Max.
Windows
Insert the USB cable to the Disney Mix Max USB jack. Connect the player to the computer with the USB cable.
Click on the desktop "Start" menu and choose "My Computer."
Double-click on the "Removable Disk" that corresponds with your connected device.
Drag songs saved on your computer with your mouse into the Removable Disk folder.
Tips & Warnings
If you converted files using the Mix It Plug-In, you will need to use Windows Media Player 10 to sync them to the player.
Mar 11, 2011 | Disney Mix Max Digital Media Player
What's free 4mb of space mean?
if your device tells you that it is a 512Mb that is the total space on the device, if it is telling you 4mb of space it means there is only 4 more mega bytes available for you to store music, information, etc. some songs take up to 9 or 10 Mb so just do your math. and that is the number of songs you can load to your device.
if it works for you, don't forget to rate me
thx
Jun 02, 2010 | Disney Mix Max Digital Media Player
DISNEY MIX MAX
thank you sooo much for all of your help i did get it fixed and now my daughter can listen and watch again
thanks again
Jul 02, 2008 | Disney Mix Max Digital Media Player
Free 4mb of space error , now NO SONGS
Try formatting both the internal memory and the SD card. It's possible that the SD card isn't formatted correctly for the Mix Max to read it. Depending on the size of the card you may need to format it in FAT32 instead of FAT.
Apr 11, 2008 | Disney Mix Max Digital Media Player
Can't do anything without message
It has to make a library file of the contents on the player. It uses that file to display the titles and artists when scrolling through the menus and what not. You'll have to format your player in order to clear it up. This will erase everything and then you can put your songs and stuff back on it. Just make sure that when you do you leave at least 4 megs of space for it to make that library file. Here's a link to the manufacturers instructions on how to format the player.
http://digiblue.com/customer-service/faqs/disney/mixmax/06.html
Mar 06, 2008 | Disney Mix Max Digital Media Player
Mixmax froze
Mix max
After getting the 4MB Playlist error, I decided to play around a little bit with my 8 year old niece's Mix Max. I think I found a few tips that will help others. First off, go into my computer and right click on the drive letter that corresponds with the Mix Max. It will probably be something like E: or F: Format it for FAT32...quick format worked for me. Next, make sure you have the most current firmware. Its downloadable from
http://www.siukoon.com/~williamchan/PD6020/MixMax_RecoveryTool_v1_0_2_fw_v1_4_000_20070512.exe
Install that, and run the program from your start menu. Make sure your Mix Max is turned off and hold the + sign as you plug it into the USB cable. It will guide you through a reset. Once you complete this, you should be able to process a sync through Windows Media Player 10 or 11. Hope this helps! I've also noticed that some songs will fail during the sync. If you remove those, it seems to help with the error as well. Might just be a coincidence.
Jan 07, 2008 | Disney Mix Max Digital Media Player
Reading a card
Jan 01, 2008 | Disney Mix Max Digital Media Player
Driving me nuts
Dec 26, 2007 | Disney Mix Max Digital Media Player
Disney Mix Max Digital Media Player Logo
131 people viewed this question
Top Disney Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
Rick
Are you a Disney Audio Player and Recorder Expert? Answer questions, earn points and help others
