Question about KDS Valiant 5350AS (KN5350AS-01) PC Notebook
Monitor problem Vertical lines on half the screen. I did updates and a system restore and the lines vanished only to reappear in about four days. Suggestions?
  • bryanimo Sep 03, 2008
    I was doing some reading on the net and then suddenly half of my computer screen was covered by multicolored vertical stripes. i waited a while and cold booted the computer but the stripes still remained. I'm not sure what caused this. It's a vista notebook. I've restarted many times and allowed the laptop to rest but still half of my screen is hidden.
  • 3 Answers
I did not
Posted on Mar 10, 2008
My iMac has had a reappearing yellow vertical line down the left of my screen for at least two months now!
Maybe the video card. Try to spray with electronic contact cleaner the connections (pc cable to monitor).
Aug 01, 2012 | Apple iMac Desktop
Emachines t5274 vertical blue lines during startup/XP.
It looks like you've got two issues. If you tried a different monitor and it too have vertical blue lines your video card might be bad, but hold that thought. I'm thinking you need to reload the operating system because you can't boot all the way up which is the second issue.
Have you tried to boot up in Safe Mode and do a System Restore? Turn the computer off, then turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Select the Safe Mode option. When it boots, if it boots successfully things will look different in Safe Mode. The screen will be darker and icons bigger, but that's normal. If you get into the desktop successfully, click Start/Programs/Accessories/System Tools/System Restore. Select a restore point (date and time) that is before you started having problems. If the system tells you that you have no restore points, then you will have to either Reload the Operating System or do a System Recovery. By the way, System Restore does not lose your data, documents, music, pictures, videos, or programs unless the program was installed after the restore date. System Recovery LOSES EVERYTHING, it sets your system back to when you first purchased it.
Mar 26, 2012 | eMachines T5274 Desktop PC
Half side has vertical lines
Turn the computer OFF and just turn the monitor ON if the vertical lines are still present then the issue is your monitor, but if there are no lines on the monitor alone turn the computer ON then go into the BIOS either keep on tapping del key once you turn the computer ON or keep on tapping f1 to get into thew BIOS screen.
If the vertical lines are present in the BIOS the issue is the Monitor but if not and the lines are present in windows the issue is your video card.
Replace the video card, if you don't have a video card and you use the built in video card on the system then the motherboard needs to be replaced.
Sep 01, 2011 | LG Flatron Ez T710BH 17" CRT Monitor
Monitor displays half screen sometimes and goes back to full screen later. Some days you get the full screen but today it is half screen one time and then full screen another time. It finally quit...
The monitor have problem in vertical section of the board.Maybe the vertical output or any parts around the vertical ic is loose connection circuit,what we called,cold solder so its better to resolder the board at the vertical section.
Jul 11, 2011 | NEC PlasmaSync 61MP1 61 in. Television
Intermittent problem a vertical red band (6-inch wide) appears on the monitor can last from minutes to hours before disappearing; then will reappear hours, days, or even weeks later.
Welcome to FixYa,
One of the top reasons for causing these "lines" running across the screen are :
  1. Corrupted video driver
  2. Changes in hardware configuration (display)
  3. Monitor issue (hardware)
In order to determine if it's hardware/software issue, all you need to do is to boot to BIOS and check if the problem replicates. Depending on system, you can go to the BIOS screen by tapping "F2" or "DEL" key repeatedly as soon as you turn on the computer until you see a different screen.
If the problem is present while in BIOS, then definitely the monitor needs to be repaired by an authorized repair center. Otherwise, video driver update or Operating system re-install can resolve this problem.
I certainly hope this helps,
Thank you for using FixYa.
Mar 04, 2011 | HP Vs17 17" LCD Flat Panel Monitor
Vertical lines in my HP screen
Please check if you get those line as soon as you turn it on, If yes, so need to get a replacement for the screen , and if it is no, try updating video driver of your system from the manufacturer website.
Hope this work
Cheers!!!!
May 25, 2009 | HP f2105 Monitor
Sony Wega 27in Randomly Has Block Box Appear On Screen
this means the TV having picture upper part of the screen. problem may be -15 V to vertical deflection ic suddenly gose off and system control gose to stand-by mode resolder vertical out ic , -15 v supply line from the fly back and system control .
Jan 15, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Dec 21, 2008 | LG Studioworks 700S 17" CRT Monitor
HP Pavilion ZD8000 vertical lines issue
In answer to your question. It may be a screen problem. as the screen has a Matrix of vertical and horizontal line configuration.
I,d suggest trying the laptop/computer on an external monitor or screen. if it works fine on an external. then it could be assumed that the TFT Panel or invertor has a fault.
if the picture/display still has vertical lines on an external monitor, then the fault may lie, with the Mainboard.
Process of elimination, before spending any Money :)
Mike @ compurepair.
Jun 09, 2008 | HP Pavilion zd8000 Notebook
KDS Valiant 5350AS (KN5350AS-01) PC Notebook Logo
Top KDS Computers & Internet Experts
Denise
ray
Level 1 Expert
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
