Question about SPL Phantom DK2-1000 Car Audio Amplifier
Car amp Why does this amp have 2 + and 2 - and ** remote?how do you hook it up?
  • 1nomis Mar 10, 2008
    and how come there is nowhere for the remote wire so how do i hook it up?
    Problem Solver:
  • 5 Answers
He is talking about the speaker outputs
Posted on Dec 05, 2008
    Sergeant:
  • 300 Answers
The 2 + and 2 - connections are the same, just split into two. This is usually because, for high power amps, it's easier to route two 4 AWG wires than it is one 2 or 0 AWG wire. Both "+" will go to your battery (through a fuse block, of course) and both "-" will go to a grounding point.
Posted on Mar 10, 2008
Subs make one very loud bang when car starts i have a kenwood kdc 528 deck and 2 pioneer 12in subs an amp
Hook it up properly to the deck remote on wire ,(Dude) End stay off the (Drugs)
Nov 22, 2012 | Pioneer Car Audio & Video
I hooked up a dual mosfet 4 channel amp and i am not getting power to it. the way it is setup is from battery to 100 amp fuse, from fuse to inside cab of truck then to 500 K farad, Split from + to power on...
Bad ground sounds like you may have paint or undercoating stopping the ground from making good contact or unhook the remote wire and run a small wire from the main power to the remote hook up and see if it works ...... May have a faulty remote
Apr 25, 2011 | Dual 2-Channel Bridgeable MOSFET Amplifier...
I have wired everything correctly to my phoenix gold octane 2.5:2 amp and the remote terminal is not working. i have hooked up another amp to check to see if its the remote line and any other problems but...
Perhaps the PG Octane R needs a bit more power on the remote. Check if connectors are well connected to the wire. There might be some resistant present if the connection is not 100%. (oxidation?)
Jan 26, 2011 | Phoenix Gold Octane-R 2.5:2 Car Audio...
My amp does not work
Did you check to see if its grounded well? Try grounding the amp to the battery, also check fuses. I'm not sure how you hooked it up, but I usually connect the amps directly to the battery with a heavy duty fuse. Also try the remote wire, from your cd player to the amp. Thar are usually 2 different remote wires make shure thair hooked up right, if thats all good and the amp power light isnt on then it sounds like your amp is bad.....
Dec 11, 2009 | Kenwood Car Audio & Video
Ok everything is working but the remote wire not
First make sure you have the right wire hooked up, there is a Power Antenna wire, and remote turn on wire, and both are blue, but one has a white stripe.. Just make sure the right one is hooked up.
Now if the right wire is hooked up, and still no voltage there are 2 ways to get turn on power to the amp.
Option 1.
Buy a LVT (low voltage trip), they come with instructions, and arent very hard to use. They will only turn on the amp when signal is sensed through the speaker leads.
Option 2. (I don't care for this one)
Find an accessory fuse in the fuse box (meaning only has voltage when the key is in the on position), and run a wire from there directly to the amp.
WARNING ABOUT OPTION 2. This can be noisy, and cause a whine in your speakers, this should be a last option.
Aug 08, 2009 | Panasonic CQ-C8100U CD Player
Send me info how to connect a 4-channel car amp with 2 12-inch subs rear and 2 front 2-way speakers?
plug two subs in to amp in most powerful channel then your speakers in the less powerfull take your positive from your battery and hook it to your amp your ground wire shud just touch a solid piece of metal take your remote wire and hook it to your deck all other wires shud be with your deck need n e thing else holla
Apr 19, 2009 | Car Audio & Video
High wattage car stereo
positive (1 guage) from main battery to second battery positive terminal. hook all amps positive to second battery and hook 2nd battery ground to frame of car (where amp is now grounded) if you have a 2nd battery a cap is a waste of money. make sure all grounds (battery and amps) are together on same ground point of car, do not ground amps to battery - ground everything to 1 spot on the frame or body of the car ! - yes you can pigtail remote leads.
Jan 01, 2009 | Kicker KX650.4 Car Audio Amplifier
Visonik 350watt Amp Doesnt Come On....
With your multimeter set to DC volts, the black meter probe on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red probe alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Let me know if you have any other questions.
Oct 06, 2008 | Visonik V117SX Car Audio Amplifier
SPL Phantom DK2-1000 Car Audio Amplifier Logo
65 people viewed this question
Top SPL Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a SPL Car Audio and Video Expert? Answer questions, earn points and help others
