Question about HP DeskJet 820Cse Printer
Printer Won't Print
Had a paper Jam, got the paper out and now the printer won't print at all and shuts off. The power light, and all the other buttons are blinking and the cartridge slams to the left.
  • 3 more comments
  • Anonymous Apr 04, 2008
    what & where do u change the encoder?
  • Anonymous Aug 26, 2008
    The exact same problem. Had a paper jam, pulled the paper out towards me, now it will not print. All the lights blink and the cartridges slam to the left.
  • nohelp618 Sep 01, 2008
    The "Encoder"?  Does anyone on this site have **useful** info that the average user can actually put into practice to try and solve the problem???
  • Anonymous Sep 08, 2008
    Post Solution
    Work Queue
    --> Have the same problem?
    Work Queue --> Have the same problem? -->
I had the same problem all you have to do is in the left side there is a black sorta arrow looking piece. You have to get this back in alignment... There is a white wheel right across from it push the the wheel down till you get it to the top where there will be a triangle like cut out.. You then need to push the point of the black arrow like piece to the left of the wheel so it below the wheels level... This is what is causing the smacking noise it is getting caught on this black arrow like piece.
Posted on Feb 16, 2009
    New Friend:
  • 159 Answers
Change the encoder
Posted on Mar 10, 2008
Red light is constantly blinking and when try to print, there is always a paper jam
Every time there is paper jam, the printer knows the job is not completed and hence tries to re-print after the paper is removed and cover is shut.
Clear the print job from computer.
Power off the printer and Clear the paper jam (if any)
I would try to use different tray. The paper pickup roller in one path may be worn out.
eg Sheet feeder or multipurpose tray.
Load paper in new tray
Set the application to use new tray
Ensure you sue the right thickness (gsm) of the paper. Quality of paper is crucial. Too thin; too thick can affect functioning.
Mar 16, 2016 | Ricoh Aficio Sp 3300DN Laser Printer
Brother 540cn Printer won't print and displays unable to print 50. The photo capture button also flashes
The error code 50 indicates a paper jam condition. Whether there's actually still paper jammed or not, it's sensors are still indicating a jam. Check again for a bit of paper, or there may be a faulty sensor.
Check out this link: Brother for further information.
Feb 10, 2013 | Office Equipment & Supplies
Printer won't print after clearing a paper jam
I use to have an HP All-In-One Laser Jet printer that, for reasons unknown to me, wouldn't print after clearing a paper jam until I replaced the ink cartridge.
Jan 13, 2013 | Canon IMAGECLASS MF-6530 Multifunction...
I have error light on. Computer won't print. I just bought the printer and it printed just fine twice. Then I turned off the power when I did not use it. When I tried to print again. the error light is...
The error light that is blinking is actually blinking out a error code. In the back of your manual under troubleshooting there should be a list.
On a printer this new about the only error you should see is a paper jam. IF anything else is wrong I'd just put it in the box and take it back. Rarely do you see something fail this new these days. It happens but not that much.
Once you look up the error code you will know what the problem is. It could be a cable unplugged or a paper jam etc. I can;t see it being serious.
Sep 11, 2011 | Brother HL-2040 Laser Printer
I have a paper jam many pieces went through the printer and won't budge. I don't see a way to get to where the paper is stuck
Unplug the printer from the power source to turn it off. Open the printer cover to access the cartridge area. If you see the paper jam, slowly and carefully pull the paper out of the printer. Avoid tearing the paper or avoid leaving torn pieces in the printer. This will cause future paper jams in the printer.
When all is clear, re-plug the printer into the power source. Load some paper and try to print again.
Jul 24, 2011 | Lexmark X2600 InkJet Printer
My printer says it has a paper jam, even though the paper jam has been cleared. It won't print. Any ideas?
Hi, Try pulling out the plug for 1 hour and then try again. Pulling the plug may reset the printer.
Good luck.
Jun 27, 2011 | HP DeskJet 3740 InkJet Printer
Printer will not print, says that there is a paper jam but there is no paper in the print, and when we add paper the printer won't take it and the power light is blinking
you need to remove the black plastic on the back wipe the rollers that feed the paper put it back together plug it back in switch on and it should work some times u get a small corner of paper stuck so it tells the machine that u have a papaer jam
May 25, 2011 | Lexmark X1270 All-In-One InkJet Printer
The red and green lights are flashing continously and it won print
The lights continually flashing indicate a paper jam or the printer being out of ink. Check/clear any paper jam and verify the ink cartidge is set correctly.
Mar 05, 2011 | Epson Stylus C48 InkJet Printer
Power light flashes and won't let me print - HP3650 no paper jam
Go into your control panel, go to your printer, right click it, then choose "Cancel all print jobs". You may also have to uncheck the "Pause Printing" function.
If all else fails, get the cd. remove the printer and reinstall the software after shutting the printer down and start from scratch just like it was new. If neither of those solve it, go to http://www.hp.com and download your owners manual. There you will find a troubleshooting section that will help walk you through what to do. Hope that helps.
Kevin
Sep 12, 2009 | HP DeskJet 3650 InkJet Printer
Lexmark x2600 printer
Pull the tray out at the bottom of the printer. This is causing the printer to think it has a paper jam. It is simply the paper feed button.
Any other issues email me at derrickfoster3@gmail.com
Feb 21, 2009 | Lexmark X2600 InkJet Printer
HP DeskJet 820Cse Printer Logo
359 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
