Question about Adtran Tracer 2210/3302 Modem
Can't connect to any router with 2210 Modem
I just have DSL from ATT , I try to connect with my linksys router , I follow every instructions to make it works but I still can**t get the internet( ** red light all are green lights), I though Linksys router had a problem(which worked fine recently), I purchased a Airlink router but same problem, I returned it and get a Netgear router which the salewoman told me that she had the same problem like that before this is one is the best, I bought it and it did **t work either but in the middle of set up it found my connection internet is PPPoE ,and guide me through the long list ,tell me to enter all kind of thing such as IP address ect.. I think my DSL is dynamic type **t static type, I call ATT they said it should work like "plug an play", I do **t see "plug and play" all I see "plug and pray ",can anyone help me ? I really
appreciate it. Thanks.
  • bsage07 Dec 01, 2008
    I have the same problem.  In my case I had a link sys and netgear router at home already, but to no avail.  Please help.
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    ahh..you on a mac by chance? that the one that uses PPPoE..PC's usually on DHCP..can you confirm the type of computer you're using?
    Problem Solver:
  • 5 Answers
Hi, what you have to do is open the router page by typing in the address bar of internet explorer 192.168.0.1 and press enter..
it will ask you for username and password i.e. admin and password....after that you'll be on netgear page there click the one on the left BACKUPSETTINGS below maintenance and after that on the new page click erase tab on the main page..then click yes router will reboot after that click ok and again type in password and press ok....After that you'll be back on netgear page and this time click on first option on the left BASIC SETTINGS and on left change encapsulation to pppoe and under that login will be your username provided to you by your isp and the password as well..eg.(johnsmith@aol.com)..after that scroll
down to the bottom and click apply ....
And then click adsl settings on the left and change multiplexing to llc based and vpi and vci you have to confirm that from your isp and then apply router will go online....
Posted on Mar 11, 2008
My new WRT160N Linksys won't connect ATT Motorola 2210 DSL Modem
For AT&T default IP address for the Motorola modem is 192.168.1.254.
Default for the Linksys IP address is 192.168.1.1.
Have you changed either one? For them to work correctly they need to be in different subnets. An IP Address of 192.168.y.xx, where y is the subnet and a different number for each device, usually 0, 1, or 2.
If they are in the same subnet, change the modem'smag-glass_10x10.gif IP to 192.168.0.254 or 192.168.2.254. Once you do this you will need to use the new address to access the modem.
You should make sure the router'smag-glass_10x10.gif gateway is outside the DHCP rage of the modem.
Dec 06, 2010 | Linksys WRT160N Wireless Router
Cannot connect to att DSL through Linksys router.
hi
I've tried:
Having the router get an IP automatically from the modem.
Changing the router's IP address.
Having the modem pass PPPoE authentication to the router.
Bridging the modem.
Power cycling the guts out of everything.
Jul 02, 2010 | Linksys Wireless-G WRT54G Router
How to bridge my motorola 2210 DSL modem & linksys wrt54g router
Try these insturctions. Jump to page 109. http://www.netopia.com/support/hardware/manuals/SoftwareUserGuideV751Clsc.pdf
Aug 21, 2009 | Linksys Wireless-G WRT54G Router
BRIDGING MODEM AND ROUTER
Your firmware may not support bridge mode, try installing dd-wrt from http://dd-wrt.com/dd-wrtv3/index.php
Aug 19, 2009 | Linksys Wireless-G WRT54G Router
Connectin a linksys Befsr41 wired router to a Motorola 2210 modem
do one thing change the ip address of the LAN in the 192.168.2.1 in the router then you get it after that configuration you done right ok
Apr 14, 2009 | Linksys EtherFast Cable/DSL Router
Have changed to att may I use linksys modem
Yes, you can still use the Linksys router with your ATT dsl modem. Could you provide me with the model or brand of your ATT dsl modem so I could provide you with the steps on how to setup your router?
Feb 27, 2009 | Linksys EtherFast Cable Modem with USB and...
How to add a netgear wgr614 router to dsl modem
The NETGEAR router needs to be configured. Call NETGEAR. Try this also http://technicalsupport.blog.friendster.com
Jan 05, 2009 | NetGear WGR614 Router
Wireless network broken, access to WRT54G & Motorola 2210-02 via http.. denied
I have att yahoo dsl which I installed about a year ago. The process required bridging the ADSL Modem (in my case a speedstream 4100) and accepting dynamic IP addresses and configuring PPPoE on the WAN side of my Linksys router. The ATT support person walked me through the entire process over the phone even though I was comfortable with making the Linksys configuration changes as I had to do the same in China without technical support. The modem configuration was no more difficult than the router configuration as it was performed from a web browser too. The biggest warning was that to reverse the modem change (if desired) required use of a reset button because the web interface was disabled as a result of the configuration change. My advice to you especially if you are willing to attach the Linksys router to the telco modem is to contact the ATT highspeed DSL support line and see if they will walk you through it like they walked me through it. Reviewing your Linksys User's Guide and understanding the configuration of that device would probably be appreciated by the ATT Support person as well as assuring you can access the Linksys router to configure it during the call.
Dec 08, 2007 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
237 people viewed this question
Top Adtran Computers & Internet Experts
Gareth Tomlinson
Gareth Tomlinson
Jax Planet
Jax Planet
Are you an Adtran Computer and Internet Expert? Answer questions, earn points and help others
