Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Whirlpool Icemaker Swith has ** light
Hi
My whirlpool conquest model is not making any ice. When I see the icemaker switch and the optical emitter, there is not light of any kind being emitted. What do I need to do to fix the emitter?
    Genius:
  • 1,073 Answers
The kit number is 4389102 it has both the emitter and reciever as one part, change both in the kit
Posted on Apr 11, 2008
I have a Whirlpool Model GD5YHA. The icemaker is not making ice. The red light is blinking.
Your have not given the full model #. Anyway most likely you have the Ice Maker Optical Level Sensor.
Just red light blinking does not mean faulty here. There is a Optical Sensor check sheet. You have to follow those instructions.
Google "Whirlpool Ice Maker Optical Sensor check sheet". You will get the instruction sheet and/or youtube videos on the subject.
Not making Ice means either the ice maker is faulty or Optical sensor faulty or water valve cannot feed water due to malfunction or line frozen. Also freezer should be below - 12C to ice maker sensor to work.
Oct 25, 2017 | Whirlpool Refrigerators
Icemaker on side by side not working
Change out your ice maker. If your icemaker has worked for 6 years, you got lucky! They normally have to be changed out every couple of years. We have an unlimited inventory of appliance parts for Whirlpool, so please call us to send your parts out and we'll get them out right away!
Sep 17, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Whirlpool icemaker microswitch location
If the icemaker is still in the refrig ,(easily removed with 1 screw ) pour about 2/3 cup of water into it . Also check the black fill hose which is above the icemaker fill cup , to see if it is frozen closed . If the icemaker dumps the cubes , and doesn't refill with water , replace the water inlet valve behind the refrig . If it doesnt dump the ice , replace the icemaker . My parts site is down , or I would give you part numbers for the water inlet valve and the complete icemaker .
The laser light should flash 2 times , pause , flash 2 times etc , if working correctly . If the laser light is not on , then the icemaker is in the harvest mode . If it stays off , icemaker is bad . If you close the flap on the left side of the freezer , the light should go off , until you release the flap . If these factors are ok , then the optics are ok .
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge won't make ice
There is an optics test procedure you can perform on your own to confirm what the repairman says. Assuming you have a whirlpool-made Kenmore (if you have a Pur water filter at the bttom left of your unit, you do), see here:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
Basically, the icemaker won't initiate a harvest (dump) cycle unless the electric eye through that cutout at the top of your icemaker can see across the top of the dispenser. If the lens is dirty, or if either the emitter or receiver boards are bad, the optics won't connect. There's a simple diagnosis procedure in that pdf above. Since your fridge is from 2005 like mine, refer to the "post 2002 redesign" optics procedure. Basically the test is to open the fridge and look at the LED, then to close the flapper on the left wall of the freezer and see the change in LED behavior. This can confirm or deny an optics issue. Also, if you remove the little plastic grille at the bottom of your fridge, there'll be a piece of paper folded and stuffed in there with the diagnostic procedure in it as well. To do the full diagnostic procedure, you'll need to remove the icemaker and install a jumper, but to debug optics only, all you need to do is open the door, close the flapper, or maybe push in the door switch and look at how the LED responds.
Mar 11, 2009 | Kenmore 53642 / 53644 Side by Side...
GD2SHA WHIRLPOOL ICEMAKER NO ICE
The most likely cause is the water solenoid behind the fridge. Take an ohm meter and test across the two terminals and it should NOT ohm out (beep). If it does not ohm out I would replace the P.C. Board kit, emitter & receiver icemaker control
Dec 30, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool Gold Conquest IceMaker
HAVE YOU CHECKED YOUR WATER VALVE LOCATED AT THE BACK BOTTOM RIGHT OF THE APPLIANCE THAT MIGHT BE THE CAUSE OF THE ICE MAKER NOT WORKING.LET ME KNOW IF YOU REQUIR FURTHER ASSISTANCE.GOODLUCK.MOHAMED
Sep 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold refrigerator icemaker leaking water
hi there,
sounds like the ice or water actuator or paddle is broken. purchase a new paddle and replace it.
the reason you have leak is because you have warm air entering through the broken part into the freezer.
can you provide me with the model # and i will send you a part breakdown.
Sep 09, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Icemaker not making ice
The same thing happened to my Whirlpool gold. Defrost it for 24 hours and the ice maker now works.
Apr 12, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool icemaker not making ice
optics would not gon bad from frozen water, strictly a computer watching ice level in ice bucket. it should however be lit blinking at least, if it set ot on positoin and no indicator light is on at all sounds like a bad emiiter/ reciever.
Mar 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
157 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
