Question about Refrigerators
Refridgerator is not cooling or freezing
The compressor is hot: the coils were very dirty; I cleaned them, but the fridge still wont cool...does the compressor have a reset button?
  • Papa Huskey Mar 10, 2008
    yes, the fan is running.....the compressor is hot,,,,but how do I know if it is working?
  • Heather Tanner May 11, 2010
    Is the condenser fan running (the fan located right next to the compressor) all the while the compressor is running?
  • 52 Answers
If the compressor comes on, then it is most likely working, unless it makes a loud humming noise. However, if it makes a clicking noise, it could have a bad relay. If the compressor gets too hot, it will shut itself off on overload until it's cool enough to run again, which is usually long enough to defrost your food.
You may have a problem in your sealed system. If this is the case, there may be a refrigerant leak somewhere. If this is the case, you should have a technician come out. Your sealed system should be covered under warranty if your refrigerator is under 5 years old.
Please let me know if you have any other questions about this.
Posted on Mar 10, 2008
  • Heather Tanner Mar 10, 2008
    Let me rephrase about the relay. It will click on then off quickly. It makes a clicking noise normally when it comes on, and then off. If it comes on and off constantly, this is usually a sign of a bad relay.
Not cooling
You can ohm the compressor to see if it is shorted but if the compressor is running it cannot be the overload or relay , if not running sometimes you can pull the relay and shake it if you hear any rattling in it it is bad
Apr 01, 2013 | U-Line 1175BEV Beverage Cooler
My samsung fridge freezer wont freeze and fridge wont cool
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 08, 2011 | Samsung Refrigerators
Problem with our Fridge Freezer RS21NCNS1. Arrived home yesterday to find the unit had stopped freezing. All front panel controls lit and able to be changed. Fluff had built up in the rear grid air...
Hello, I read your problem and a couple things here. First of you said motor was hot and then was built up and dirty. That is why motor is hot, because it was overworking itself. When things get dirty or caked up, compressor will still run slot of times but not go in to high speed full capacity, even after you clean it and must clean coils too real good, you then have to make sure motor is cool, before starting it up again. If it still won't cool and everything is cleaned good, then most likely you will have to replace your capacitor and starter relay, that is the components you see connected to the compressor , its easy to find as just follow the electrical wires that connect to those that are plugged into the motor/compressor. The parts are not to expensive and a do it yourself job. But before you replace the starter relay and capacitor try making sure coils also are real clean and motor cool, unplug fridge for hour or so. Oh and don't forget to unplug when working on it. By the way what the starter relay does is give the compressor a burst or amps to trigger compressor on high. Think of it as a booster. Have a great evening. Mike
Sep 05, 2011 | Samsung Refrigerators
LG GR431SCA fridge will not cool properly and top half of freezer and ice maker section will not freeze. The bottom half of the freezer (below the shelf) freezes well, but above the shelf and the ice...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Sep 04, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
GE refridgerator won't cool
First of all check and see if the compressor is running and if not is it very hot to the touch. If the compressor is not running but hot then the compressor is either locked up or is cycling on its internal thermal overload. If this is the case then either the condenser fan motor is not running and/or the condenser coil is very dirty. If the condenser coil is dirty you need to blow it out with compressed air(watch out for all the blowing dust). If the compressor has been cycling alot on its internal thermal it will eventually lock up permanently and you will need a new compressor. I hope I was of some assistance to you!
Nov 12, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Wont blow cold air
First check and clean the filters, and the evaporator coil. (thats the "inside" coil that has the indoor air sucked through it, cooling it and then pushing it out the vents.
If the filter is clogged or the coils are dirty, it will not cool properly and potentially freeze up.
Also check the condensor (outdoor) coil, if it is dirty/clogged, it will run hot and not cool properly.
If all coils and filters are clean, and the fan motors are running and in good condition and it is still not cooling then you are likely low on refridgerant. (handling/purchasing refridgerant other than R134A requres a CFC certification by law)
Aug 20, 2009 | Heating & Cooling
Freezer is not working but the fridge part is working
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
tryt
May 28, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
Frig is warming while freezer is staying cold.
No, A compressor will get hot for about three reasons.
Low refridgerant.
Lack of airflow, (maybe due to very dirty coils or bad condensor coil fan on modes with a fan)
Or high amp draw. (which would mean you have a bad compressor)
Its more common to be one of the first two, especially low refridgerant.
Dec 05, 2008 | Refrigerators
JENN-AIR REFRIDGERATOR JSD2789AES
HI thanks for your question. remove cover to the compressor relay, check for burnt wires. clean all coils. replace the relay. thanks
Aug 30, 2008 | GE GSS20IEP Side by Side Refrigerator
I have an Amana bottom freezer fridge model ARB2517CSR the freezer stopped working I cleaned the coils and the fan was working and the fridge was making a buzzing sound. The sound stopped, so did the...
If the coils were really dirty, the compressor is probably just overheated. Let it cool down overnight then try again. If it still won't stay running it needs serviced. Could be the start relay or internal overload/overheat sensor in the compressor. If the coils were really dirty and it was used like this for a long time, the compressor could be damaged. It is almost never worth replacing a compressor in a home refrigerator.
Jul 03, 2008 | Stainless Cruise 49 Marine Refridgerator -...
Refrigerators Logo
493 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
