Question about Keurig B100 Coffee Maker
B100 Keurig Eric (Burnzy), I tried the new check valve -in line-with the old one and it didn't fix the problem I am having. When you disassembled the pump, was it the pump on the right side or the pump on the left side?  Was is difficult taking that pump apart? Any tips during disassembly/reassembly?  I admire that you were able to get 3 of these back to working.  Thanks for taking the time to assist me with this. I'm not the most mechanical, but I do like my coffeemaker and I like the challenge.  And thanks for the tip on where to get that check valve!!
  • 3 Answers
The pump is on the right side, has two wires coming out of it, and is connected to the check valve with a silicone hose. When you run a cycle, to brew a cup of coffee, that pump should be pumping air out, which pushes the hot water out of the tank.
So to test it, disconnect the hose and run a cycle to listen and feel for air coming from the pump. If it is not working (frozen due to the water permitted to enter from the failed check valve), you must remove it to dismantle the top part of the pump.
Getting the pump out is a little tricky... as you will see. There is only one philips head ***** holding it in, however, it is not easy to get to. I used a 90 degree angled *****driver, which worked well, after trying many other options.
Once you get it out, remove the three philips head *****s on the top of the pump right near where the hose was connected. Then separate the two sections of the pump. Inside there will be a fitting in the center that spins to actuate the pump. This fitting must be freely moving. If it is not, use WD-40 or a similar product to free the motor.
Clean up all the WD-40 from inside the chamber (so your coffee does not taste like oil) and reassemble. Then test it by running a cycle. The pump should now be working, if not repeat the process until the pump operates.
Since my last post, I have fixed another B100 that had the same issue. Keurig will not sell you a replacement pump or check valve, so you must repair that pump.
Good Luck, I hope this works for you. Erik
Posted on Mar 10, 2008
  • madredepaul Dec 22, 2010
    I would love to try this fix, but can't figure out how to open the casing. Simply removing the screws from the bottom don't do it. Can anyone explain the trick to opening the machine for me?
The b 2000 and b2003 have the same pump but different mounting bracket and plug ends
Posted on Apr 08, 2008
Tip
Keurig B100 coffee maker not brewing
KeuSymptom: keurig B100 coffee maker not brewing. If your brewer sounds like it should be brewing but little or no coffee comes out, the problem may be a simple malfunctioning check valve, located on the right hand side of the unit under the plastic cover. If the check valve is clogged or fails, water from the tank leaks into the air pump (located just below the valve) disabling the pump.
The pump that pushes the water out of the tank located on the right hand side of the unit (I included a photo) has a check valve just above it. On my unit the check valve failed allowing water to enter the top chamber of the pump disabling it. The pump was not damaged it just cannot operate correctly with water in it.
Here is the Fix: Disconnect the check valve and make sure it is operating correctly. Mine was clogged with a small amount of mineral deposits, which was cured by a half hour in a glass of vinegar, and a good rinse. Then disconnect the tubing from the top of the pump and run the unit to allowing the water to escape the pump. Make sure there is no water left in any of the tubing between the pump and the check valve, even the smallest amount will disable the pump again. Reconnect everything and it should work.
Good luck and if you find this helpful remember to thump up vote itc3bb7bf.jpg
on Aug 16, 2010 | Keurig B100 Coffee Maker
Tip
BURNZY.....YOU ARE A GOD SEND!! After calling the Keurig Service Center about my...
Symptom: keurig B100 coffee maker not brewing. If your brewer sounds like it should be brewing but little or no coffee comes out, the problem may be a simple malfunctioning check valve, located on the right hand side of the unit under the plastic cover. If the check valve is clogged or fails, water from the tank leaks into the air pump (located just below the valve) disabling the pump. This happened to my brewer two days ago. I have had this unit for about four years and never had a problem. When I called tech support at Keurig they said "it sounds like the pump is shot", but there was nothing they could do and they would not repair it. Instead of the throwing out my $300 coffee maker I figured I would try to fix it myself. After 3 hours of tinkering, I found and fixed the problem, so I am passing on the tip. Since 2.5 of those hours were spent diagnosing the problem, the fix itself is pretty simple. The pump that pushes the water out of the tank located on the right hand side of the unit (I included a photo) has a check valve just above it. On my unit the check valve failed allowing water to enter the top chamber of the pump disabling it. The pump was not damaged it just cannot operate correctly with water in it. Here is the Fix: Disconnect the check valve and make sure it is operating correctly. Mine was clogged with a small amount of mineral deposits, which was cured by a half hour in a glass of vinegar, and a good rinse. Then disconnect the tubing from the top of the pump and run the unit to allowing the water to escape the pump. Make sure there is no water left in any of the tubing between the pump and the check valve, even the smallest amount will disable the pump again. Reconnect everything and it should work. Hope this was helpful. Erik
on Dec 13, 2007 | Keurig B100 Coffee Maker
Keurig B30 model -light comes on but it won't brew
Manual is here...
http://www.keurig.com/help/B30mini_useandcare.pdf?mscsid=4ERVGRF0CN779GJL8ESKBA7FFP6TDX5B
Is the mug clear? It wont like clear glass mugs. or cannt sense offset mugs...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
Apr 19, 2010 | Keurig B100 Coffee Maker
I just bought a keurig model b100 an the water does not come up the tank into the brew cup an was wondering how to fix it
check inside if the water line is not pinched . you may need tools a cross point screw driver and such
Mar 14, 2010 | Keurig B100 Coffee Maker
Tip
Keurig B100 Not Brewing Fix
on Jun 21, 2007 | Keurig B100 Coffee Maker
I NEED A K-CUP COMPLETE HOLDER FOR MOD B30 KEUIRG COFFEE MAKER
Hey
That needs to be ordered direct from keurig
1-866-901-BREW (2739) Representatives are available 7:00 am to 12:00 midnight EST, 7 days a week
good luck & please rate me
thanks
eric
Feb 01, 2009 | Keurig B100 Coffee Maker
I want to register my new Keurig one cup coffee maker
Hey !
try this for your needs.
Keurig Customer Service
1.866.901.BREW (2739)
thanks and please rate me
eric
Dec 06, 2008 | Keurig B100 Coffee Maker
Keurig b100
It sounds like one of two things happened when you disassembled the unit. Either the hose that controls the mechanism for the piercing arm (the part that puts the holes in the k-cup) became disconnected or pinched, causing the water to pour out over/around the k-cup. Or the k-cup holder is clogged or not seated correctly, which would cause the same problem. As for the little button you may have pushed, that can't cause the problem you're experiencing, so don't worry about that. Good luck, let me know if need more help. Erik
Jun 25, 2008 | Keurig B100 Coffee Maker
B100 only dispences about 2 ounces of water
I removed the top from the hot water tank & repaired the split hose on the intake side. I also disassembled the the right side air pump & freed up the motor that was frozen. apperantly the check valve leaks very slightly & causes some rust build up on top of the pump motor. Should any one need a new motor you can find a universal hobby motor that you could make fit. these motors run on 3 to 18 volts which should be ok. After the repairs I did a good cleaning with whit vinagar. The machine now works as good as new. Hope this helps out other people with the same problem.
Frank Urbano
May 21, 2008 | Keurig B100 Coffee Maker
Keurig B100 Coffee Maker Logo
1,118 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
