Question about Vacuums
I have an Electrolux Lux 7000. My son sucked a small towel into the hose, which is stuck inside the hose close to the attachment end. Can this model blow expel air so I can blow the towel out?
    President:
  • 1,673 Answers
If it does, it should have a door on the top near the back. But if not then something like a plumbers snake or long needle nose plyers may help get it out.
Posted on Mar 10, 2008
How do remove the plastic elbow on the hose. A sock is stuck in hose
put it on the blower and try to get it out backwards. Usually works
Feb 24, 2016 | Electrolux Lux 7000 Bagged Canister Vacuum
Tip
Electrolux Epic 6500: Trouble Shooting I
Electrolux Canister Vacuum Shuts Off During Use<br /> <br /> This actually cover several models of Aerus and Electrolux canister vacuums. Models covered include: 2100, Epic 6000, Epic 6500, Aerus Lux 5500, Aerus Lux 7000, and Aerus Lux Legacy. Be aware that some of these models may still be under warranty. Any disassembly of those machines will void the warranty. Use of non-genuine bags also voids the warranty. Use only Home Solutions Aerus/Electrolux bags.<br /> <br /> First, turn dial on top of vacuum counter-clockwise so the smallest dot lines up with the arrow. See if it stays on. If not, detach hose and turn vacuum on. Place palm of hand over intake. If it turns off, it's possible that the tubes connecting to the CVA are clogged and simply need cleaned. This is most often caused by using "made to fit" Electrolux bags. Dust is sucked through the bags and into the motor compartment of the machine. All interior parts get covered in dust and need to be cleaned. If this is the cause, the vacuum is best cleaned and repaired at an authorized Aerus Electrolux store. If the vacuum shuts off, or won't turn on before placing hand over the intake, it's probable the control valve assembly is bad and needs replaced.<br /> <br /> Another cause is an overheated motor due to clogged screen at back of bag well, full or clogged bag, dirty afterfilter, bad wiring/connections, clogged hose, clogged power head, or bad motor. It depends largely on the type and model of cleaner. Clogged wands are also a possibility, but unlikely.<br /> <br /> Check and clean screen at back of bag well.<br /> <br /> Replace bag. Make sure it's a genuine Electrolux bag made by Home Solutions.<br /> <br /> Check and replace afterfilter if necessary. These should be replaced after every six bags.<br /> <br /> Broken and worn wiring connections are often found in the hose ends due to abuse and normal wear and tear. You can check the continuity of the hose using a continuity tester or multi-tester. If a multi-tester, turn dial to one of the Ohm settings. Place one probe into one of the terminals on the end of the hose. This will be referred to as T1. Touch the other probe to each of the terminals/connections on the other end of the hose. These will be T3 and T4. One of them should read zero, the other should read infinity. Repeat this with the other terminal, which will be T2.<br /> <br /> Drop a marble in one end of hose and let it roll through. If it doesn't roll through, the hose is clogged and needs to be cleared. Plug hose into the exhaust port of the vacuum, place other end in the in port. Turn vacuum on. This provides a blowing and sucking action which should clear the hose.<br /> Detach hose from power nozzle (PN). Drop a marble into the wand end of PN. If it rolls through, it's clear. If not, there's probably a clog behind the brush where the intake opening is. You may be able to reach this through wand end with needle nose pliers, or either end with a knitting/crochet needle or a bent coat hanger.<br /> <br /> If none of these "fixes" provide the answer to the problem, it should be taken to the nearest Aerus Electrolux store for diagnosis. Repairs or checks involving disassembly of the vacuum should always be done by an authorized Aerus Electrolux service technician.<br /> <br /> The store nearest you can be found by following the instructions at the below listed link:<br /> <a href="http://www.aerushome.com/storelocator/">http://www.aerushome.com/storelocator/</a><br />
on Dec 20, 2010 | Electrolux Epic 6500 Vacuum
My power head is spitting out the dirt ,etc instead of sucking up. Auggggh
The most likely cause is a plug in either the hose, wands, or neck of the power nozzle. If there is a plug in the line, the brushes on the nozzle just kick the dirt around. Eliminate each piece by attaching the hose to the unit first to ensure there is strong suction at the end of the hose. Then check each of the wands. Lastly, look down the neck of the power nozzle. Many times items like toothpicks, pine needles, pins, nails or bottle caps will lodge themselves in the lines, causing dirt and debris to pack around them. Most plugs can be fished out easily, but some may require you to take the unit in to a vacuum repair shop.
Jun 29, 2011 | Electrolux Lux 7000 Bagged Canister Vacuum
Aerus Lux 7000: the full bag light keeps coming on but the bag is not full.
Electrolux uses a pressure differential control valve. This valve measures air before and after the bag. There is a orfice or small hole where the hose connects to the vacuum cleaner, and a orice at the back of the bag canister. As the bag fills up the suction pressure reduces at the hose connection and increases at back of the bag canister. When this happens the control valve has a diaphram that closes, which shuts the vacuum off and gives you a full bag light. There is a thin plastic flange that prevents an o ring on the control valve stem from coming off. The flange breaks, the o rings comes off the stem and the vacuum will shut down indicatiing bag full. The after market price is about 22.00. The valve is easy to replace if you are familiar on electrolux vacuums. When I replace these valves, I use epoxy two part plastic putty on the flange of the valve. It takes 2 days to cure, but the flange will not break.
Jun 25, 2011 | Electrolux Lux 7000 Bagged Canister Vacuum
Unit turns off when any type of restiction to air intake. For example when unit is turned if hand is held in front of hose connection unit will turn off
Mar 04, 2011 | Electrolux Epic 6500 Vacuum
Why doesn't my power broom work? My son sucked up water up water from the dogs water bowl. It works intermittantly.. Can it be fixed??
Once water, especially a large volume, gets into the motor of any vacuum, it's shot. The motor needs to be replaced, but this is much cheaper than buying a new vacuum. Take it to an Aerus Electrolux store. They may need to order a motor, but shipping usually only takes a week.
Feb 17, 2011 | Electrolux Lux 7000 Bagged Canister Vacuum
My electrolux ultraone keeps cutting out after a couple of minutes - there are no lights indicating filter or bag?
This is not an Electrolux Lux 7000. Totally different companies.
However, check the hose for clogs. Drop a coin down one end and lift so it should drop out the other. If it doesn't, there's a clog that needs cleared. This can often be done by pushing it out with a broom handle.
Jan 26, 2011 | Electrolux Lux 7000 Bagged Canister Vacuum
Vacuum cleaner Lux model motor fails to start
This vacuum has a 10 year warranty on the motor, and 5 years on everything else. Look in the yellow pages under vacuums, for the AERUS dealer, that is the new name for the traditional Electrolux company.....
Mar 23, 2009 | Electrolux Lux 7000 Bagged Canister Vacuum
When hose is attached vacuum stops
there is a clog somewhere in your hose, wand or head
a plummer snake will get it or even a broom handle
Dec 28, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Electrolux renaissance power hose
If the wires power a motor then it shouldn't actually matter as the motor is AC which has no polarity.
Oct 07, 2007 | Electrolux Lux 7000 Bagged Canister Vacuum
Vacuums Logo
44 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
