Question about Symphonic SC3913 13 in. Combo
Connecting to an RCA DTA800 digital converter?
Having trouble trying to connect my 1999 Symphonic SC3913 13'' to an RCA DTA800 digital to analog converter. Tried all given program codes but none worked.
  • Anonymous Jun 14, 2008
    set up for more chanels
  • James Gordon Wolfe
    James Gordon Wolfe Jun 20, 2008
    Thank you to everyone for your suggestions and assistance. I found out what the problem was. I live in a trailer and the material of the trailer was blocking the signal. I solved it with an outside antenna. Thank you again.
I got the new RCA converter box I followed the on screen info but i'm not getting a signal from my antenna so it doesn't show any channels
Posted on Apr 22, 2008
Hit menu , configuration, search for channels and i think it ask for language to
Posted on Jun 20, 2008
173 worked for mine. I just entered everything starting at 001 and when I got to 173 it finally worked. I have a Symphonic WF719.
Posted on Jun 19, 2008
Im having trouble hooking up my sound bar to my monitor E196FPf
As far as I know, the E196FPf monitor does not have speakers or an audio out. Thus you'll need to connect the sound bar to the audio out of your computer or other source. On a laptop, this will be the headphone jack. On desktops, you use the lime-green 3.5 mm jack on the back of the system.
Depending on the sound bar, you might need a Aux (3.5 mm M to 3.5 mm M) cable, a 3.5 mm M to dual RCA (red/white) adapter cable or an analog to digital audio converter with the 3.5mm to RCA cable and appropriate digital audio cable.
Please add a comment with the model of the sound bar and the audio/video source, if you want more information on the best solution for your application.
I hope this helps.
Aug 07, 2016 | Computers & Internet
What is the codes for a sanyo tv that will connect to a rca/dta800 converter box. I have lost my manual and need to the codes for a Sanyo television.
not for sure but try 007, i have a different brand converter box hooked to a sanyo tv and it's code is 007, i will try and find out more if i do i will post it
Nov 19, 2009 | Insignia Digital-to-Analog Converter for...
RCA DTA800 TV Converter Box I need TV codes for the remote to work. The TVs are a GE, phillips magnabox
Good day,
I might be missing something, but you are describing a converter box that converts digital signals from an antenna to analog.
The converter box will be set to channel 3, and you should set your tv's to channel 3 as well.
Using the remotes that came with the tv's go into setup and if available as an option, you will find an option to select cable/antenna or automatic. Select automatic or antenna and save. If there is a selector switch on the back of the tv's, set to 3.
Connect antenna cable into input, and use supplied cable to connect from the output of the converter to your tv.
plug in power supply for converter box, tune tv to channel 3 then follow instructions to setup converter box including channel scan.
When done, the converter remote will control everything. However, the tv volume control will work even though the converter remote will have volume as well. The tv remote as well is needed to shut off or turn on tv. These functions can on most tv's be performed on the set as well.
No codes are required. The converter remote will work on any tv.
If you want to use both tv's then you will need a splitter on the output of the converter to send the signal to both tv's. Only one channel can be viewed at a time.
Viewing separate Chanel's requires a second converter box and a splitter connected to the antenna cable for viewing separate channels.
More options are possible, but I hope this helps you get started.
The converter box takes place of the tv's tuner and in essence disables it.
Nov 05, 2009 | Tablets & eReaders
When I hooked the DTA800 to my RV atenna
My understanding is that the Digital signal is weaker than the analog, so need a stronger antenna to pick up the digital signal, and MAY still not get any reception at all. Have you considered satellite for you RV? Won't need the converter at all then.
Feb 22, 2009 | Insignia Digital-to-Analog Converter for...
Need sanyo tv code to connect rca/dta800 converter box
sanyo 037,082.083.124.198,268.274 Press program, three number combo, ok, check volume control for function
Jan 01, 2009 | Insignia Digital-to-Analog Converter for...
Need a progam code for rca dta800
I just tried their web site and it worked! They have the codes. www.1800customersupport.com/rca
or here is the direct link: http://www.1800customersupport.com/productdocuments/DTA800B1_Program_Codes.pdf
Hope this helps others who have had the same problem. Mine did not even come with these codes!!!
Jul 07, 2008 | Hitachi 57F510 57" Rear Projection...
The instructions for our DTA800 digital to analog converter box for over the air waves for TV signals say since the signal is too weak that we need a SMART ANTENNA. What is that and what do you...
Hey boykinpierce,
The phrase "Smart Antenna" is often used to describe a multi-directional antenna or antenna array. These types of antennas are able to detect and automatically adjust to any changes in the TV signal strength you receive, and can generally be obtained through most major retailers. They primarily are used in areas where digital signals are weaker or somewhat inconsistent, and will attempt to optimize the signals they do receive before sending them to a TV or digital converter box.
Please keep in mind that while some DTV digital-to-analog converter boxes may have built-in Smart Antennas, this particular model (RCA DTA800) does not appear to have this feature.
If you're still not quite sure what to look for, please remember that you can always speak with a home theatre sales agent at your local Best Buy™ store for more information.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 19, 2008 | Televison & Video
Denon AVR-2105
If the Cd is wired digitally, it will only play through the main zone, because the Denon cannot convert down to RCA to cater for the zone 2. If you plug RCAs from Cd to Denon, Main zone will STILL play from digital, and RCA connection will allow zone 2 to play Cd from RCA input....same with dvd, Satellite Blah blah... no stress, any nasty RCA will do if you want to try before you splash out on really costly cables...perhaps you can help me...want to run AVR 2105 with 2 speakers in zone 2, manual says cant do it - only ably to surround back or biamp...dont want either, dont have stereo yet to try it out...did you have any trouble with that?
May 26, 2008 | Denon AVR-2105 Receiver
Televison & Video Logo
232 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
