Question about Maytag Atlantis MAV6451 Top Load Washer
How to replace gears myself?
Agitator won't move, repair person said sounds like one of the gears is stripped and that if we want to take it apart we can do it ourselves. How do we get to the gears? It is a Maytag top loader washing machine.
Just went through an agitator problem with my MAV7700AWW Atlantis. You are talking about the main (bottom) agitator, not the corkscrew part up top, right? If so, you can check this site to see how to access parts inside your washer. I found it very helpful: http://www.geocities.com/maytagrepairwasher/
I too, had visions of replacing stripped gears, but after searching the internet for a few days, decided to buy a new transmission, replace it, and then tear in to my old one and repair it and then have the original for a spare.
I found a NEW transmission and tub seal kit for under $120 including shipping to my door.
If you have an Atlantis, then the following information will be very helpful. Otherwise, you may find that you have a transmission that can be serviced more easily.
When I finally got the old transmission out I was very happy with my decision. I cannot see how it comes apart - no screws, bolts, clips, or clamps. It is an upper and lower half that appears to be gooped together by a blue sealant. The new transmission appears to have the halves crimped together - maybe it is a serviceable part, but it is not very user friendly.
If you decide to tackle the job, I can offer a few tips on alternative tools and also on disassembly of the brake.
Posted on Mar 12, 2008
Agitator only moves a little bit and making noise
Most likely agitator dogs / gears are stripped out inside agitator. If it's a double action agitator where the top turns independently from the bottom, the top should turn one way and not the other. If top of agitator turns freely in either direction, then replace those dogs. If it's a single action agitator, then grooves that slide onto transmission shaft in agitator itself could be stripped out. If that's the case, replace agitator
Oct 27, 2017 | Kenmore Series 70 Washer Motor 387780
Will not Agitate (Frigidaire GLWS1233AS1) The washer fills and then stops. If I manually change the timer to the end of the cycle it drains and can spin. I saw on older posts that this might be a...
When ya say after filling "the washer stops" does that mean it is not making any sorta sound?? if it is the transmission,agitator block,or evena stripped gear you will hear the motor running yet it will not agaitate and from reading your question i think it says their is no sounds yet instead it fills then just sits their silent,is that so??
If yes their is no sounds it could be in the area of the timer where the problem lies, since it will drain/spin i am exluding the motor, lid switch or belt as the problem.
If it does make sounds yet just wont agitate it could be a stripped agitator block, or stripped gear but,the belt would be ok since it spins
GENE
Oct 25, 2011 | Washing Machines
Won't agitat under agitator yellow coupling held by 7/16 bolt should this spin freely or does this mean its stripped
it probably means that it's stripped. it grips the spine and allows movement of the agitator. the transmission shaft may be rotating back and forth, but the agitator doesnt move properly. i would remove the coupling and take a look underneath it to see if it's stripped.
Jul 06, 2011 | GE WBSR3140DW Top Load Washer
FILLS UP, DOES NOT SPIN, BUT TRIES WITH CLICKING
master gearbox is stripped a cog it will need to be repaired in most gear box cases the cost outways the replacment of a new washer
sorry
take care
Feb 15, 2011 | Washing Machines
Spin cycle for tub broken - no spin, sounds like gears stripped.
Hi Ed can you please give model # and make so we can give better advice thanks.
Nov 17, 2009 | Kitchen Ranges
LSQ9210HZ0 agitator acts like its gears are stripped.
Replace the agitator dogs in the top part of the agitator.
Mar 24, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Possible transmisson
motr coupling easy to turn??? did you look at closle ( sometimes appears intact, but the center of teh shaft is stripped allowing the motor to "slip" through giving what could amount to a stripped gear sound. the newest motor couplin (285753a) has a meatal sleeve to prevent such a thing from happening
Mar 20, 2009 | Whirlpool Washing Machines
Maytag Atlantis MAV6451 Top Load Washer Logo
132 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
