Question about Samsung WE356A5W Washer/Dryer Laundry Pedestal
Samsung P1253 Filter Clean
Hi, I have clean the filter and also clean the one at the back where the water come into the machine but I still keep getting the error message E5. The machine goes through the cycles but then stops half way and thats when the error message comes on.
  • gwenshultz May 03, 2008
    where is the filter on a samsung? How do I get to it?
  • Anonymous Oct 09, 2008
    i have the same problem i,ve cleaned the filter and all the drainage hoses and it,s still flashing 5e
I bought a new FI_ICKER
Posted on Feb 10, 2009
How do I correct a 4E error?
try unpluging for 15mins re try
Apr 27, 2015 | Samsung Washing Machines
Hi, The cold water is entering the machine very
Did you clean the filter? There is a filter in the inlet, a little filter that can be removed with a pair of pliers. Rinse it out and put filter back in its place. I think it would not even matter if you leave the filter out. Hot water filter is not blocked because it is not used as often as the cold water one. Clean both! I noticed a big drop in water flow if filter is dirty.
Sep 14, 2011 | Samsung SW62ASP Top Load Washer
Samsung washer P1253 cleans but won't drain right beofre spinning and doesn't spin
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many washers will not go to spin or release the door lock at the end if they detect water is still left inside the machine.
Here are my complete, general pre-typed guidance notes for checking both the filter and the motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Mar 18, 2011 | Washing Machines
Water keeps overflowing, dont know how to clean the filter or where it is .
hi, read about your problem. The filter is located at the bottom of the front of washer. If its not visible, remove the bottom kick panel. Three screws at bottom. Take a shallow pan and place under filter. Slowly turn counterclockwise and water will slowly start to come out. When pan is partially full, empty. Be sure to close filter before doing this. Keep up with this procedure until no more water comes out, then unscrew filter and remove and clean. Reinstall and put kickplate back on. Hope this helps.
Jan 19, 2011 | Hotpoint Aquarius WD640 Front Load...
Describe your 4E problem in samsung front load Problem
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa!!
Sep 19, 2010 | Samsung WF203ANW Front Load Washer
Samsung model WF8602NHS showing error message 4E
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
Sep 03, 2010 | Samsung WF306BHW High Efficiency Front...
I have a samsung 7Kg J845 front load washing mechine, when i turn on, water not fills enough ( only water fills couple of seconds after stops flows. the error shows 4E, Then i clean up all mesh filters...
Aug 08, 2010 | Samsung WF203ANW Front Load Washer
Error 4E + timer countdown is delaying
Sep 02, 2009 | Samsung WF337AA Front Load Washer
My samsung washing machiene keeps coming up with the error 4e. what does this mean?
Mar 15, 2009 | Samsung WF337AA Front Load Washer
4E code keeps apearing
Jan 29, 2009 | Washing Machines
Samsung WE356A5W Washer/Dryer Laundry Pedestal Logo
786 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
