Question about HP Officejet Pro L7650 Printer
USB Device Problem after installing new printer
I have an HP PC, plus an external HP DVD burner and a FreeAgent external drive connected by USB connection. I recently replace my old printer with a new HP L7650 all in one (printer, fax, scanner). As soon as I connected the new printer the other USB devices shut down (** longer recognized by PC.) I can pull the printer cable and restart the PC and the other USB devices will be recognized. I'm sure there is a better way...pulling the cable and restart the system is **t an elegant solution. Any ideas are appreciated!
    Genius:
  • 3,587 Answers
Did you get a fresh set of drivers when you got that new hp? try this link, and advise your success on this.
Posted on Mar 09, 2008
External dvd/rw drive wont play on my hp pavillion chromebook
Make sure the USB port(s) are in working order. Check them by using Device Manager? Then check to see if the drive is visible in My Computer?
Jan 12, 2014 | Pc Treasures Digital Treasures External...
LG dvd external drive not recognized by computer
ERROR 43? Check your SATA connection.
HERE'S HOW I FIXED MINE.
(IE. Computer tries to install driver for BD burner, but ultimately fails, and gives the message. "Unsuccessful" and/or "Microsoft Windows stopped device. Error 43") The SATA CONNECTION on my BD burner's EXTERNAL CASE had gone bad.
TO TEST IT. I used a SATA/IDE to USB Adapter Cable I bought for about $10 on amazon.
  • I unscrewed the external case to get at the internal drive, and plugged the SATA adapter cable directly into the internal BD burner drive (bypassing the case assembly), and plugged the other end into my computer USB port.
    • PS My BD burner POWER was working OK, so I left the big white 4pin power adapter connected to the original external case.
VOILA! Both my laptop and my desktop PC recognized the LG BD burner again and assigned it a drive letter (like it used to do).
  • Now I either need to (1) Buy a NEW EXTERNAL case ($10 - $30), (2) install it as an internal drive (could get problematic if "ANYDVD" is installed) or (3) just leave it connected via the cheap adapter cable.
It's super EASY (& inexpensive) to TEST this before spending $$$$ on a new equipment.
Hope this helps someone. It had me miffed for a while there.
Jan 02, 2014 | LG GSA-2166D DVD RW Dual Layer Burner
Usb external
i guess its a windows usb hid driver issue, windows wont load on auto the usb driver needed for your device, you may check it also w/ device manager try to check if you have an exclamation mark there w/c indicates a failed driver generation . go to control panel
go to devices and printers then try to enable the usb unknown device . thanks and happy troubleshooting!!!
Oct 02, 2013 | HP 300e (900956) DVD+RW Burner
My seagate external hdd 500gb is not working and is not detected and regonised in any pc..
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Nov 07, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Can I put internal LG GH22 rewriter inside external GSA-E60N
First, open the external casing.
You'll find an "internal" CD/DVD drive, connected to an adapter, and the adapter connects to the USB cable.
Now, look at the adapter -- it could be a "parallel-ATA" interface, or it could be a "SATA" interface. The new CD/DVD drive will have to have the same connectors (data and power) as the adapter.
You might have to exchange the SATA device for a Parallel-ATA device.
If you have a parallel-ATA CD/DVD drive, look at the back of it.
There is a tiny jumper, and a few labelled settings:
* MA(ster)
* SL(ave)
* C(able)S(elect)
Move the jumper to the 'MA' setting, so that the USB-adapter will recognize the CD/DVD drive.
Connect the drive to the adapter.
Close the case.
You're good to go!
Jul 22, 2010 | LG Dvd Rewriter Gsa-e60n 20x Ext Black...
I have a HP External USB CD/DVD R/RW drive. Stopped working.
First, try a new USB cable. Two, try a different USB port (if using a hub, directly connect to the computer). Three, check if there are any updated drivers or firmware for the drive.
(also make sure that the external drive is self-powered that the cord is undamaged and the power isn't surging or going into a brown-out. If it is one of the new bus-powered DVD drives, make sure that the computer has a good power source (not on battery for a laptop).)
Feb 27, 2010 | HP 8x External Double-Layer USB 2.0 DVD...
SeagateFree Agent Go 120 G.B external portable hard drive When I connect that in to my lap top (HP Pavilion) windows can recognize the hard drive and once I connect that same one in to my desktop windows...
you will need to install the drivers for your drive.
xp doesn;t recognize 2.0 usb unless you install drivers and have a usb 2.0 port
but install the drivers and you should get it to recognize
you can go to control panel, system and device manager.
look for a usb device that is not working and right click install drivers or update drivers.
See if it comes up.
Once it does you will see it in the device manager under disk drives
Jun 05, 2009 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
HP DVD 740e wont burn Dual Layers anymore!
Try re-installing the software associated with the burner, so it installs the necessary drivers and files needed for the burner to work according to your needs.
Also check the connections and cables... sometimes moving it around causes the cables to loose some contacts.
Hope this helps...
Feb 26, 2008 | HP DVD 740VI 16X16 Dual Layer LightScribe...
Mad Dog USB DVD-RW not recognized
The firmware updates and drivers won't help you. You can try turning it off, disconnecting it from your PC, then turning off your PC, turning on the burner and then turning your PC back on and hope that it's recognized. The chances are slim as this is a known issue with Mad Dog external USB DVDRW's and you need to send it in for repair if it's under warranty or put it on eBay as broken (or throw it out) otherwise and get a new one. I have a Mad Dog external DVD-RW and ran into the same exact issue, for a while it was working on and off as long as I didn't turn the burner off while my PC was on but for a while now it's just recognized by the PC as mass storage device rather than the DVDRW that it is and when you reach that point the aforementioned two choices (repair or throwing it out\putting it on ebay) are the only ones you have.
Oct 14, 2007 | Mad Dog Multimedia (MD16XDVD9) DVD±RW...
HP Officejet Pro L7650 Printer Logo
79 people viewed this question
Seeker5211
Seeker5211
