Question about Aiptek MPVR Digital Camera
I found a digital camera how can i find the model number on it
Riding bike on side of road and found digital camera it seems to work fine however i would like to know more..how do you turn it off..just close the lens??
    Scholar:
  • 63 Answers
2002 Vstar 1100 is bottoming out with passenger
Replace the spring with a heavier duty should do the job.
Have you tried adjustments in the spring load to stiffen it up.
The rear shock on your Yamaha V-Star 1100 motorcycle assures that the rear wheel is always in contact with the ground and makes your ride much more comfortable by absorbing road vibration and shock while you ride.
But your shock needs to be adjusted for different riding styles, so depending on whether you ride fast or cruise slowly and how quickly you take turns, you may want to adjust the shock to get the most out of your ride.
Remove the passenger seat by loosening and removing the rear passenger seat mounting bolt with a socket wrench.
With the passenger seat removed, you should see two larger rider's seat mounting bolts.
Remove these bolts and pull the rider's seat off of the bike to expose the internals of the motorcycle. 2
Detach the quick-release clips of the ignitor unit found just beneath the seat using a screwdriver. Pull the ignitor unit up and to the right of the bike to move it out of your way.
Remove the mudguard quick-release clips in the same fashion, then pull the mudguard out of the bike to expose the rear shock adjuster. 3
Look for the small numbers on the rear shock adjuster.
On most 2002 V-Stars you should see the numbers 1 to 9 printed on the shock adjuster.
These numbers give you an idea of the current setting of the shock.
The higher the number, the stiffer the adjustment. 4
Loosen the shock by turning the shock adjuster counterclockwise to a smaller number using a spanner wrench.
This makes the shock softer and more forgiving when riding over bumps and uneven pavement, but will feel slower in turns and accelerations.
Tighten the shock by turning it clockwise to a higher number.
This makes the shock stiffer, increasing road response in turns and giving you a better feel of road conditions at the expense of comfort. 5
Replace the mudguard, ignitor unit, rider's seat and mounting bolts, and the passenger seat and mounting bolts.
Take your bike for a ride to feel the difference a turn of the shock adjuster makes.
Nov 10, 2013 | Patch Products Sid The Science Kids Why Do...
On my pipes one side is hot and the other is cold
Check the pipe right where they come out of the heads. It depends on what type of exhaust system you have on your Road King. If the stock exhaust is on the bike, the rear cylinder exhaust is directed to both mufflers. With the exhaust from the front and part of the exhaust from the rear cylinders going to the right side muffler, it gets more exhaust than the left side and runs hotter. Like I said, check the temp of the exhaust pipes at the cylinder heads. If one of them is cold, that cylinder is not firing. As long as both of the pipes are hot there, you're fine. Just ride the bike and have fun.
Ride Safe.
Stevev
Apr 09, 2011 | 2000 Harley Davidson FLHR-FLHRI Road king
Can you please provide me a list of all major bike types?
I have listed the most famous bike types: BMX Bicycle
Bicycle Moto Cross (BMX) bicycles are designed for rough off road riding and are typically single speed. People also use them for stunt riding, and you may see some fitted with stunt pegs.
Mountain Bike (MTB)
A mountain bike is designed for trail riding and downhill riding. It can also be ridden on the road. They come in many shapes and forms. Some have no suspension, whilst others have front and rear suspension. A mountain bike without rear suspension is usually called a hard tail bike.
Most MTBs use 26 inch wheels which is the standard. This size wheel is fairly strong, especially when coupled with the large off road tyres that are fitted to MTBs.
An MTB is suited for off road riding and will handle rough terrain quite easy. It is very stable on rough terrain, but is a lot slower to ride on the road when compared to a road bike. It is also suitably geared for climbing hills.
Hybrid Bicycle
Another style of bike that has a similar riding position to a mountain bike, but better road speed is a Hybrid bicycle. Hybrids are a cross between a mountain bike and a road bike. They have an upright comfortable position, road tyres, and are usually a lot lighter than a mountain bike.
Hybrid bicycles are typically used for commuting.
Touring Bicycle
A touring bicycle is designed for loaded cycle touring and has the capability to be fitted with mudguards, racks, panniers and extra water cages. They are typically fitted with wider road type tyres that are suitable for gravel riding also.
They usually come with a stronger frame and longer chainstays so that the back of your feet don't hit the rear panniers. They are usually fitted with a relaxed drop bar style handlebar. The geometry of the frame is also different and allows for much more easier steering and handling when loaded.
Expedition Bicycle
As above for touring, but usually fitted with Trekking bars and MTB gear and is designed for extreme off road conditions.
Randonneur or 'All Rounder'
A rare beast in Australia where we like to specialise. 'Randonneur' is a French term, coined to describe a bike that can do a bit of everything - you can ride with the pack or take a doddle with the kids, you can ride light or carry a load, you'd use it to visit Gran on Sunday then pick up some groceries on the way home. They are the 'family station wagon' of cycling. However, like any Jack of All Trades, they do everything well but the specialists do it better. They can carry a load but not like a heavy tourer. They are fast but heavier than a racer and with more comfortable geometry. They have wider wheels and tyres to ride on rough roads but wont handle true off road work.
Typically, they look like any other racing or flat bar road bike ... until you look at the details. Most randonneurs start life as a touring bike or hybrid, and are then modified by the owner over time to reflect how they are used.
Dec 21, 2010 | Cycling
2003 HD Road King - starts fine, idle normal. Once it is warm, idles at 2000 rpm. Does not come back down, even after riding for an hour or two. Only idles normal when cold. Help??
If you bike is equipped with a carburetor, the idle stop screw is located at the top of the carb on the right side. Counterclockwise turn slows the idle speed.
If you bike is fuel injected, a dealer or shop will have to set the idle speed electronically.
Good Luck
Steve
Sep 16, 2010 | 2003 Harley Davidson FLHRCI Road King...
Lighted floor board inserts inop
was the Y connector used with resistor
if not need a resistor in the circuit to cut down current possible led's are dead an need to replace
here's a how to make your own led tree
Apr 05, 2009 | 2006 Harley Davidson FLHRI Road King
Engine cuts out on same stretch of uphill road every morning. Sit for 2 mins, then try starting again. Rough idle for a couple of seconds then all fine as if nothing happened. Is this fuel starvation?
WHEN I ROAD YEARS AGO I,HAD A 1941 INDIAN "80" AND LATER A 1948 HARLEY "74" BACK THEN ON THE HANDLE BAR, ONE SIDE OF COURSE WAS YOUR GAS WHILE THE OTHER SIDE WAS FOR SPARK CONTROL , AND IF YOU DIDN'T ****** THE SPARK RIDING UP HILL ,THE BIKE WOULD STALL . FOR SURE NOT THE SAME , BIKE'S HAVE CHANGED SINCE MY TIME , BUT I BRING THIS UP JUST BY CHANCE SOMETHING WHITHIN YOUR BIKE IS CAUSING THE PROBLEM WITH SPARK CONTROL . SHOT IN THE DARK ! GOOD LUCK ! jerry
Apr 02, 2009 | 1984 Honda CBX 750 F
I don't know if my sony trinitron kv-2742 27" tv needs a box
Given the history of the aquirement, I checked the model number and there is no reference to be able to receive digital. You can buy a convertor box anytime they are available to use on the set. There is no deadline to hook it up.
Feb 15, 2009 | Sony KV-27V42 27" TV
Aiptek MPVR Digital Camera Logo
60 people viewed this question
Top Aiptek Cameras Experts
mohamed salim shaikh
Are you an Aiptek Camera Expert? Answer questions, earn points and help others
